10-16-2019, 11:13 PM | #1 |
WTB: Overdrive Cable Clamp
I'm looking for the overdrive cable clamp that secures the cable at the solenoid.
I've included a pic of what I need and my current setup. I could probably end up making one, but while I'm at school and don't have access to the stuff I need to make one, I figure I'll see if there's one out there somewhere
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-16-2019, 11:50 PM | #2 |
Re: WTB: Overdrive Cable Clamp
I have a over drive trans in a 65 will look and see if it has a clamp
10-17-2019, 01:39 PM | #3 |
Thanks!
10-17-2019, 04:10 PM | #4 |
Moderator
10-17-2019, 07:39 PM | #5 |
Thank you for the suggestion Rocknrod. I just went out to look at the size, and unfortunately the clamp is much bigger than the OD cable
10-21-2019, 12:01 PM | #6 |
Still looking
10-21-2019, 05:05 PM | #7 |
Mine is gone sorry I could not help you
Posted via Mobile Device |
10-21-2019, 07:35 PM | #8 |
Thanks for looking, I appreciate it
10-28-2019, 01:09 PM | #9 |
Just make your cable larger by adding some fuel line over it nice and snug, then stick that into the park brake cable clamp and tighten. a few rounds of Black Gorilla tape on the OD cable would also work
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
10-28-2019, 01:26 PM | #10 |
That is a good idea. I'll have to see if I can make it work next time I go back home. I don't have all my spare parts and such down here at college
01-10-2020, 02:48 PM | #11 |
Still looking for the clamp
03-08-2020, 05:02 PM | #12 |
Maybe someone has one that I could get some measurements off of so that I could make my own??
03-08-2020, 06:54 PM | #13 |
I have one on a four bolt over drive that I am going to sale. I will make one for you. Thanks for help me on my overdrive.
03-08-2020, 08:54 PM | #14 |
Thanks! I'm glad I could help ya with it. It was good talking to ya again as well
