Old 12-11-2019, 04:06 PM   #1
1981_c10
1981_c10's Avatar
Static Drop
Friends, I am going to installing a 2.5/4 inch drop on my 81 C10 over the Holidays and would love some pro tips before starting. here are the plans and parts i currently have:
Front:
2.5 drop spindles
stock replacement coil springs
New ball joints
Stock replacement shocks (didnt think i needed lowering shocks due to spindle)
Sway bar
Should i replace the bushings in the control arms? (i have not purchased new ones yet)
Rear:
2 in hangers
2 inch shackles
Drop shocks or stock? (havent purchased yet)
Should i replace the bushings in the leaf springs? (havent purchased yet)
This will be my first time doing this so any info is helpful!
Thanks!
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 12-11-2019, 07:49 PM   #2
wixthedog
wixthedog's Avatar
Re: Static Drop
I am a fan of refreshing and making things 'new' whenever I get into them. That being said, I would definitely replace what was needed while you are in there.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 12-13-2019, 10:37 AM   #3
SCOTI
SCOTI's Avatar
Re: Static Drop
Bushings are likely toast if it's been used & not a yard queen (the last Square trucks built are 40yrs old now). inspect them & plan accordingly. Your plan for the front seems good & you're correct the shock travel won't change w/the spindle swap.
For the rear, same rules apply for the leaf bushings. I would opt for relocating the lower shock mounting point w/shock extension brackets to get a better angle on the shocks & to allow using stock spec replacement shocks vs. 'drop' shocks.
When you get it aligned, the 'book' will call for +.5 Camber. Request 0 (zero) to -.5 Camber & as much Caster as they can dial in w/that new Camber set-point. The lower center of gravity & updated camber spec will be an improvement.
Check the other steering parts while you're in there. The tie-rod ends, Idler, & Pitman arms need to be in good shape as well. Summit Racing offers the Moog product line & they're usually 50% less than your local parts place on the price.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-13-2019, 11:02 AM   #4
1981_c10
1981_c10's Avatar
Re: Static Drop
Thanks for the helpful info! Luckily my truck only has 120K miles on it so I will give it all a good look. Alignment tips are super helpful! Will keep everyone updated on my results.
Builds:
1981 C10
Old 01-02-2020, 04:22 PM   #5
1981_c10
1981_c10's Avatar
Re: Static Drop
See the attached pictures for the update. Almost finished...ran into every problem you could imagine from having to break my wheel locks off to couldnt get the new shock in because the gasket was big...now i am fighting bearing race. Once i finish those, i will do the sway bar and rear.
Builds:
1981 C10
Old 01-02-2020, 04:22 PM   #6
1981_c10
1981_c10's Avatar
Re: Static Drop
Old shocks...
Builds:
1981 C10
Old 01-02-2020, 06:31 PM   #7
wixthedog
wixthedog's Avatar
Re: Static Drop
It's coming along well! I always run into issue, its kind of expected at this point.
I assume you have the 1" brakes? The spindles look different.
Mike
Old 01-09-2020, 03:37 PM   #8
1981_c10
1981_c10's Avatar
Re: Static Drop
Thank you! And yes you are correct in the 1 inch spindles. I honestly bought the spindles on CL for a really good deal like 5 years ago and didnt check if they were the correct ones...but my luck paid off this time!
Builds:
1981 C10
Old 01-22-2020, 10:07 PM   #9
marcoman
Smile Re: Static Drop
So how'd it end up coming out? I'm looking to do a static drop in the future and I'd like to see your results.
marcoman is offline   Reply With Quote
Old 01-31-2020, 06:27 PM   #10
1981_c10
1981_c10's Avatar
Re: Static Drop
Front is done, minus the sway bar i need to install. Pretty happy with the front. Honestly, will probably end up cutting a coil off the springs i installed to try to lower the front one more inch.
Rear should be done in the next week or two. i will post updates.
The steering is way better with the truck lowered though. With that said, need and alignment lol
Builds:
1981 C10
Old 02-01-2020, 12:30 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Static Drop
1/2 coil = 1” of drop.
That’s a rule I go by.
1 full coil will get you about 2” of drop.
Keith
Convert to disc brakes.
Old 02-11-2020, 12:15 AM   #12
MikeB
MikeB's Avatar
Re: Static Drop
How much net drop did you get on the front? I installed 2.5" spindles with new Moog coil springs (the softest they had), but ended up with a net drop of around 1.5". Turns out the new springs are the same extended height, but a little stiffer than the basic OE springs. Anyway, the truck has settled another 1/2" or so since then. I think my avatar picture is before the drop.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-18-2020, 03:27 PM   #13
1981_c10
1981_c10's Avatar
Re: Static Drop
I ended with the same 1.5 net drop as you. That is why i want to eventually cut part of a coil off. Did you do hangers and shackles in the rear? Any advice?
Builds:
1981 C10
Old 02-18-2020, 03:27 PM   #14
1981_c10
1981_c10's Avatar
Re: Static Drop
That is good to know. Better to start small haha.
Builds:
1981 C10
Old 02-19-2020, 08:12 PM   #15
Scott91370
Scott91370's Avatar
Re: Static Drop
Wish I would have sen this sooner. I'm right up the road and have a small press for removing and replacing the bushings. I just did the rear springs and shackles this past weekend. Took about 20 minutes to r&r all 6.
Hoping to do the fronts this weekend.
Scott
1982 GMC Sierra
Scott91370 is offline   Reply With Quote
