Old 01-02-2020, 11:59 AM   #1
FAKKY
TIG weld stainless exhaust purge
So getting close to a point where I will need to build my stainless exhaust.
I dont really have a way to easily setup a purge.
Since its not structural - If I tig without a purge - any issues ? Thoughts ?
This thread says --- yES .... NO ..... lol
https://weldingweb.com/showthread.ph...out-back-purge
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 01-02-2020, 12:42 PM   #2
Gippetto
Re: TIG weld stainless exhaust purge
Back when I was working, if it was a certified sanitary piping system as used for dairy or pharmaceutical applications it was purged. Otherwise every other general use weldment was tig welded without worrying about the inside of the piece.
I wouldn't worry about it.
Gippetto is offline   Reply With Quote
Old 01-02-2020, 12:43 PM   #3
FAKKY
Thanks - kind of the way I was leaning.
Old 01-02-2020, 12:56 PM   #4
mongocanfly
mongocanfly's Avatar
We have miles and miles of piping at work....every piece is purged while welding...on stainless it will "sugar" on the inside if not purged...may not matter on exhaust
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-02-2020, 12:58 PM   #5
FAKKY
Thx mongocanfly ....
I havent welded much stainless ...... but the stainless I have joined I do see the sugaring .... but figured on the 3" exhuast going out --- should be strong enough with the amount of weld to hold up ...... just wanted to see if there was a consensus .... seems most guys in trade say backpurge and do it right ...... but most guys how just hobby say they have had no problems for just exhaust .....
Old 01-02-2020, 07:22 PM   #6
mr48chev
mr48chev's Avatar
I did the maintenance purchasing in a fruit juice/apple sauce plant that every sanitary stainless tube weld was purged. The guys doing the welding and the outside contractor's welders had plugs to plug the ends of the tubes with one plug having a hole for the hose to connect to.
I'd say that both Gippetto and Mongocanfly will say that it is far more to prevent contamination of the product that the line carries than appearance. Sanitary stainless welders (the people) lay down some of the prettiest welds you will ever lay eyes on though.
My ongoing truck projects:
Old 01-03-2020, 08:07 AM   #7
Oldtruckwelder
Oldtruckwelder's Avatar
IMO:: If your gonna go to the expense to use Stainless, do it right..
A brass y at the bottle, little bit of hose, roll of tape, bam your done..
JT
From
SC
Oldtruckwelder is offline   Reply With Quote
Old 01-03-2020, 10:35 AM   #8
olcarguy
As a retired millwright/welder in a brewery.....when welding stainless that product went through it was purged, If it was for other then human consumption, it was not purged. Nobody sees the inside of exhaust pipe and the strength of the weld is not effected. Extra effort is often wasted effort.
Just my humble opinion....
olcarguy is offline   Reply With Quote
Old 01-03-2020, 10:47 AM   #9
slammed57
slammed57's Avatar
I just finished mine. I did it in 409 stainless not 304. I did not purge it at all. Almost no sugaring inside ( you won’t see it anyways) I did my research like you. You do need a tri gas( not cheap) if you are doing it in 304. All the supply shops would have to order it for they did not have it at hand. I was happy with the 409 ss , should last 20 years probably more for most of us do not use as a daily driver. 304 ss should have been about $500 more. But it all depends on you on which route you want to go. Don’t get me wrong I love 304 ss . But I put the extra $500 to other things for the truck. Hope this helps
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 01-03-2020, 01:05 PM   #10
mick53
I build dry ice manufacturing plants. Almost all the piping is stainless. Some up to 3' in diameter. It is not practical to back purge such a large pipe. I will have as many as 30 TIG welders on site at a time. They all use Solar flux on the inside of the weld. It's not super expensive and goes a long way.
https://www.amazon.com/Harris-S0FB01...Sn5QhoCH8EQAvD
mick53 is offline   Reply With Quote
Old 01-03-2020, 02:09 PM   #11
jwhotrod
you do not need trigas to tig 304 ss. I use straight argon wit a cerrated tungsten and it works fine. I do not purge its too much hassle and the sugaring is minimal if your fit up is good. fit up in the joints is much more important. I have done quite a few ss exhausts in streetrods. a compression bender puts more restriction in the pipe than not purging.
jwhotrod is offline   Reply With Quote
Old 01-04-2020, 10:27 AM   #12
slammed57
slammed57's Avatar
Thanks for that info about the tri gas. I did not know that. I learned something today.
My 57 current build
Old 01-04-2020, 12:05 PM   #13
Kevin Mac
Kevin Mac's Avatar
Always use a as brush designated just for SS. If you use it on carbon steel then on ss it will rust because it will deposit carbon on the surface. I will second a good fit and straight argon. Also I brush my tacks and weld while it is hot, it shines much easier. Keep a sharp tunston and clean surface with flapper wheel or wire wheel and the weld will flow much better. Purge is not needed for exhaust, yes it will sugar, but not necessary. The sanitary tubing (.065 wall I think) is only washed together, no rod needed with a perfect fit. If you have a gap on one side, more than likely it will pull to that side after welded. Here are a couple pics of 2" sanitary tubing I welded up last week and just hand brushed right after welded. Good luck
Mac
Kevin Mac is offline   Reply With Quote
Old 01-05-2020, 08:14 PM   #14
FAKKY
Good enough for me.
Old 01-05-2020, 08:16 PM   #15
FAKKY
Awesome. Yes will be the cheapest SS 3" I can get on ebay. Just something a bit better that other options.
Nice setup.
I wont be able to run twin tubes at least down each side.
Ill either have to cross over behind trans and join tpo a single pipe ..... or run both down the drivers side.
Any thoughts on that ?
Old 01-05-2020, 08:17 PM   #16
FAKKY
Compression bender ? Just mean the bend of the tube ?
Old 01-05-2020, 08:19 PM   #17
FAKKY
Mac
Nice ..... Im really enjoying TIG ...... when I finally get the truck built Im going to put more time into TIG - stainless or aluminium fence gates ... so on.
Old 01-05-2020, 09:07 PM   #18
slammed57
slammed57's Avatar
Nice setup.
409 ss is what you look for if your not going with the 304 ss its the only 2 choices for stainless ,as for the way you want to run either way is fine , going 2 into 1 you lose performance especially with a performance motor , but no one says you cant. Iam just trying to figure out your set up with out a picture to see why you cant run one exhaust tube on each side. let us know how you do.
My 57 current build
Old 01-05-2020, 09:10 PM   #19
FAKKY
409 ss is what you look for if your not going with the 304 ss ,as for the way you want to run either way is fine , going 2 into 1 you lose performance especially with a performance motor , but no one says you cant. Iam just trying to figure out your set up with out a picture to see why you cant run one exhaust tube on each side. let us know how you do.
Fuel tank on the passenger size takes up all the space ..... only 1" of clearance between fuel tank and hwere driveshaft will go .... only option would be outside of frame that side.
Old 01-06-2020, 08:14 AM   #20
olcarguy
How about running the pipes along the underside of the running boards....like lake pipes and dump in front of back wheels. depends on ground clearance of coarse.
Old 01-06-2020, 10:17 AM   #21
FAKKY
Had to google lake pipes
I think ground clearance should be ok unless I bottom out hard ... fuel tank is lowest point currently ... but still well above bottom of rims without tires ...
I'll find a pic ....
Be mostly concerned about noise. When I start it up with just the short headers on - sounds like a bomb.
https://www.jalopyjournal.com/forum/...pipes.1100132/
Wonder if t hat would help ..... #post6.
Old 01-06-2020, 10:20 AM   #22
FAKKY
Dont have a great pic from backside ...... but this will give an idea
Old 01-06-2020, 12:48 PM   #23
jwhotrod
if you go to the local exhaust shop and they bend pipe for you, they use a compression bender. That bender wrinkles or reduces the pipe diameter in the bend, because the internal diameter is not supported with a mandrel. the mandrel bends you buy are bent with a internal mandrel or "pig" that follows the bender thru the bend and supports the diameter for smoother bends.
Old 01-06-2020, 01:43 PM   #24
FAKKY
Gotchya. Thanks.
Was just planning on buying 3" straight and mandrel bend SS on ebay Cheaper than anywhere locally.
Old 01-06-2020, 06:45 PM   #25
olcarguy
Yes that is exactly what I was referring to. You should have enough clearance for a resonator in front of your pipes or an internal baffle as was suggested on the hamb.
