![]() Join Date: Dec 2012
Brake system
I am in the process of bending/routing my brake lines/hoses. I was looking for information on my next steps regarding Master Cylinder and proportioning valve. I found the below link as a good read just as an overview of the braking system. This is probably known knowledge for most but thought I would share it.
Brake Line bending tip Brake system design
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 01-09-2020 at 01:03 PM. |
![]() Join Date: Jul 2010
Re: Brake system
This image shows the use of both, a Combination valve (also known as a Metering block), as well as aftermarket valves (residual and proportioning valves). This can get you into trouble.
If you are doing a stock restoration using OE replacement brake parts, use the OE Metering block. If your build is NOT a stock resto, then DO NOT use the Metering block. Use aftermarket valves only. Here are the rules. Use a 2lb residual valve for disk brakes, use a 10lb residual valve for drums. One for the front, one for the rear. Install an adjustable proportioning valve in the rear line. Valves should be as close to the master as reasonable.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#3 | |
Re: Brake system
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 01-10-2020 at 01:37 PM. |
Re: Brake system
Not to mess up the original post but why the 2 lb residual valve in the front line when running disc/disc?
On my last few LS swaps I've used C5 discs front and rear without a residual valve and they have worked very well. I have always used an aftermarket prop valve mounted right under the master cylinder. Few medium and higher stops to adjust and it's been good to go. |
#5 | |
Re: Brake system
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
Re: Brake system
How about those of us using a newer master. I'm putting a 99 disc drum unit in my 62,disc drum,and I am unsure if the newer master is front port to front brakes,rear to rear.
Re: Brake system
Residual valves are are basically ball-spring check valves. They keep a small amount of fluid pressure in the lines.
If the fluid level in the master cylinder is lower than any other part of the brake system (bleeder screws, lines, etc.), then the fluid can gravity feed back into the master cylinder. This makes you pump the pedal to get the fluid back up and build some pressure. |
#8 | |
Re: Brake system
Re: Brake system
If your master cylinder is on the firewall (fluid level higher than caliper/drum bleeder screws), you don't need residual valves.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Brake system
I had a pair I was going to put on, a local guy with a 64 did not put them on. He insist they're not needed also. He drives his daily.
Re: Brake system
Thanks Bob and Rockn, I appreciate the info. I don’t plan on using them for now as long as I don’t have any pedal pumping action needed in the future. I am learning the braking system is quite complex, but I’m enjoying learning.
