#51 | |
Re: Cgt project
#52 |
Re: Cgt project
Almost done my fabricating, details. Battery box and transmission cooler mount.
#53 |
Re: Cgt project
Please help. Going out of my mind with my rear wheels. They are 22 x 12. I went with this backspace because sometimes when you have little backspace you loose the look of the wheel as all you see is lip. Not sure if I have enough lip. Am willing to change out the rear wheels but I cannot make up my mind. What do you think? Opinions...
#54 |
Re: Cgt project
Looks good from here.
What are the F/R back space numbers?
#55 |
Re: Cgt project
F is 5.5 on a 9" wheel. Has clearance lock to lock, at this ride height.
R is 7 on a 12" wheel. If I change it would go down to 4" backspace. |
#56 |
Re: Cgt project
Yikes.... 4" backspacing on a 12" wheel is closing in on race car/Pro Street territory. I'm ok w/about 4"BS on a 10. Beyond that the wheel detail seems to be lost (especially on these 6x-66 trucks). So 10"/4"bs; 11"/5"bs; 12"/6"bs.... You're pretty much spot-on where I feel the 'look' is now but thats a personal thing.
#57 | |
Re: Cgt project
I want my truck to handle. Yes 22's are not optimal for that, but I like the look. My front track width is 59" so when designing my frame I went with 59" for the axle because somewhere I read this is good. Set the B.S. on the wheels to fit my suspension. ( some do it the other way around). Last edited by vet57air; 04-08-2020 at 10:51 AM. |
#58 |
I'm just glad to be here!
Re: Cgt project
Personally I like your set up now with the lesser lip so the detail of the wheel center is more clearly seen. I agree with Scoti's comments on bs measurements.
I think the big lip trend is going to play out at sometime, but the lesser lip/more center detail is timeless.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#59 | |
Re: Cgt project
My front track width should be 60-61" (OE truck disc brake fronts @ 64; PB Dropmember -1.5", PB 1" narrowed arms, & CPP modular spindles -.5 x2= 60.5"). Wheels will be 8-9" w/5.25 - 5.50"BS. I think your set-up will work well.
#60 | |
Re: Cgt project
#61 |
Re: Cgt project
20's & it's a 64 short fleet.
#62 |
Re: Cgt project
Finally received the parts I needed for the steering. Never had to use 4 joints before ( two doubles). My frame manufacturer laid back the rack making the conntection more complicated.
#63 |
Re: Cgt project
Wow.... You had to utilize two different support bearings.
#64 |
Re: Cgt project
#65 |
Re: Cgt project
I guess they figured exhaust would be easier w/the steering routed low & under the motor-mount tower.
#66 |
Re: Cgt project
Doing body gaps. Pretty happy with door and fender gaps. Have the hood and cowl pieces left. I like the gap between the hood and fenders but the cowl is high. Anyone have any tricks besides me slicing the cowl piece?
#67 |
Re: Cgt project
Just found your build. Nice work!! Do you have enough clearance to allow for a 4" back space on the rear wheel?
Rick |
#68 |
Re: Cgt project
#69 |
Re: Cgt project
My new full time job.....my body and paint. Done all the body work and gaps. Just put some high build on the cab and now some blocking.
#70 |
Re: Cgt project
Nice, How did I miss this?
#71 |
Re: Cgt project
Well.... I guess that's good. Work detail should easily pass ownership QC. But then again I've heard when the same person wears both hats (owner & QC) there can be a struggle.
#72 |
Re: Cgt project
Don't get me wrong, I hate body work. I do it out of necessity. I'm pretty picky detailed kind of guy and can't afford to pay someone to do it.
#73 | |
Re: Cgt project
My #1 problem always was knowing when to stop & that it was 'good'. Heck, it still is. This also is a factor in why I seek out clean, patina, survivors so I can live w/how it came from GM ![]()
#74 | |
Re: Cgt project
[ATTACH][/ATTACH] |
#75 |
Re: Cgt project
Beautiful work, its as simple as that.
