Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-01-2014, 06:30 AM   #1226
2000Limited
2000Limited's Avatar
Re: Crash's 69 K10
Very Nice!!!
2014 Dodge Charger SXT 100th Anniversary Edition
2009 Chevy Silverado Z71
1978 Chevy Scottsdale 4x4-Project "Colonel"- Build
http://67-72chevytrucks.com/vboard/s...d.php?t=632039
2000Limited is offline   Reply With Quote
Old 05-11-2016, 11:37 PM   #1227
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Crash's 69 K10
Just went through you're build and noticed it's been a while since you posted on here. Any updates? Also what size and brand wheel and tire is on that?
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-12-2016, 01:09 AM   #1228
swamp rat
swamp rat's Avatar
Re: Crash's 69 K10
I may have to do the same rivet replacement in the future i think a couple are getting loose.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-18-2017, 11:09 PM   #1229
kehstr
kehstr's Avatar
Re: Crash's 69 K10
I just looked through your thread, and everything that you have done on this rig is TOP NOTCH! Way cool truck!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-24-2020, 12:02 PM   #1230
Duck1
Re: Crash's 72 K10
Originally Posted by Crash_OK View Post
Today was a long day… Went early this morning to pick up some parts that MCBassin machined for me… Once Again Thinks Mike… Left there and headed to the shop. First task was to install new tail shaft in the 4L60e.
First step is to remove the bell housing. The bolts are a T50-Plus.. If you ever need to remove these bolts do not use a regular T50… you will see why a little later.
The bolts are installed with thread lock from the factory. Applying heat helps to break the bolts loose. Just put a little heat on the bolt. Don’t overdo it.. You can also put it on the outside of the case where the bolts attach.
Working by yourself requires some riggin…
Bellhousing is off..
Now you can see what happens when you try and use a T50 in place of a T50-Plus. I had to drill the head off of the bolt.
Remove the pan and filter.
Remove the TCC solenoid. You have to remove this solenoid to get to the TCC solenoid.
Pull the front pump.. this can be done many different ways.. I usually use a couple pairs of vice grips on the outer part of the front pump.. just pull up and work the vise groups back and forth.
This oil ring needs to be removed before pulling the pump.
Next remove the band and then grip the input shaft and lift the entire assembly up and out of the case.
Remove the rest until you get down to the snap ring.
Snap ring removed.. this is the one everyone talks about.. it is not that easy to get out, unless you have had some practices
The shaft could be removed at this point from the rear … however I went ahead and pulled it all out to look at the clutches and other parts..
Shaft is out.
Old vs new.
New shaft ready to go in…
Back together we go…
It is important to use lent free rags and also remember to use white lithium grease to help hold the thrust washer and bearings.
Time for the snap ring.. the shaft will fall out the bottom without this ring..
Install the band and then set the assembly back into the case. This is heavy and you need to make sure it gets seated correctly.
Next lower the front pump back into the case. Make sure the trust washer does not fall off. I used a couple of drill bits to help line the pump up..
Run all the bolts down.. just snug them..
Make sure you have some end play with the input shaft. If not, then something is wrong.. Everything was good in my case… Torque the front pump bolts to 18 ft/lbs
Don’t forget to install the o-ring…
Install solenoids and filter..
Clean pan and install gasket..
All finished..
Time to install the 4L60e to 700R4 adapter.. this gets us back to the TH350 4bolt flange for the transmission to transfer case adapter.
Now the fun part… I need to cut .500 inches off of the power coupler..
Success…
Transmission is complete..
Time to mate it to the engine..
And then the progress came to a complete stop… The input seals for the transfer case are to big… Got to have them to continue..
Decided to move forward with the Dirty Dingo Sliders…
All we need now is the seals and we can install the Transfer Case into the frame, and then install the transmission and engine…
Hopefully NAPA or O’Reilly’s will have the seals I need… But I doubt it…. If not, I will install some new u-bolts on the DANA 44, and install the rear Brake hose. Maybe I will start on the wiring..
Good night..
You have to love the interchangablity of GM. That output shaft is from a 700-R4 81-92 the predecessor to the 4L60E. You can see the teeth that the governor would have meshed with
Duck1 is offline   Reply With Quote
Old 04-24-2020, 01:16 PM   #1231
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Absolutely..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 04-25-2020, 06:32 PM   #1232
Richard
Re: Crash's 69 K10
Just purchased a set of t50 plus sockets in anticipation of tearing down my 6l90 to change the output shaft from 2wd to 4wd. Still trying to decide what I want to change out while I am in there. Trans has just over 50k on it.
Richard
Old 04-25-2020, 09:11 PM   #1233
57taskforce
All about them K’s
57taskforce's Avatar
Re: Crash's 69 K10
Not to hijack but Do you have the Camaro 90??
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-26-2020, 01:57 AM   #1234
Richard
Re: Crash's 69 K10
No. Maybe a Camaro some time in the future. The 6l90 is going in my 72.
Richard
Old 04-26-2020, 11:39 AM   #1235
57taskforce
All about them K’s
Re: Crash's 69 K10
Pm sent to avoid further thread contamination. Sorry Crash!
Tyler
Old 05-24-2021, 12:26 PM   #1236
Duck1
Re: Crash's 72 K10
Originally Posted by notsolo View Post
Hey Mark ...Just got thru 3 1/2 pages of your adventure, how to make (remake) a junk yard truck into a show piece. anybody would be proud to own. Wow That's going to be a super nice truck.....Oklahoma Crude to Oklahoma Gold.. Ed.
that output shaft looks surpisingly similar to the TH350 output shaft. especially with the splines for the mechanical speedo
