Old 08-23-2020, 02:49 PM   #1
OUbesto
OUbesto's Avatar
Replacement radiator source
Any recommendations where to buy quality replacement rad for ‘70 C10, 402, HT 400, A/C? Prefer American made. What specs etc do I need to know to order correct replacement model? I also notice there are transmission lines in/out of my current set up. I believe current rad appears to be original. It does have an overflow plastic container that is mounted on the drivers side Near the front inner fender.
Any threads to remove and replacement instructions would be greatly appreciated.
Thanks to all!
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 08-23-2020, 08:07 PM   #2
notsolo
notsolo's Avatar
Re: Replacement radiator source
Champion C 369 no complaints with a standard 350.....use the search box.......others have used the same.
notsolo is offline   Reply With Quote
Old 08-25-2020, 05:24 AM   #3
tinman_local2
I got mine from a local radiator shop. It's a 4 core copper and steel. Has the correct connection for the lower hose that curves up like the frame does. I'd have to ask them what brand it was. I'm sure any quality radiator shop can get you one. It's made in the U.S.A. and no plastic tanks. Should last another 50 years.
tinman_local2 is offline   Reply With Quote
Old 08-25-2020, 05:57 PM   #4
OUbesto
OUbesto's Avatar
Smile Re: Replacement radiator source
Thanks guys....just ordered a Champion (American Eagle EA369) 2 row x 1 inch with 14" dual fans and a relay.Yikes, glad I had room on my visa account his month
