Old 01-18-2021, 11:24 AM   #51
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Saturday my son and I painted the interior of Darel, Platinum gray. Turned out really nice. Dash, front of seat riser, door jams, back of cab.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-18-2021, 11:31 AM   #52
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
looks great, ........keep it going !
Tempest67 is offline   Reply With Quote
Old 01-18-2021, 11:51 AM   #53
vintovka
vintovka's Avatar
Re: 1950? S-10 tdi
Great work. Keep it up and we'll keep watching.
Be sure to post mileage when you get going. The incredible MPG with our 2012 Passat SEL was about the only thing i liked about it. Darn near 60 MPG on first cross country trip!!!! Still wonder where it is after VW literally forced us to sell it back.
vintovka is online now   Reply With Quote
Old 01-18-2021, 01:39 PM   #54
youngrodder
youngrodder's Avatar
Re: 1950? S-10 tdi
That color has some great metallic to it...Looks great.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-19-2021, 12:43 AM   #55
oldman3
oldman3's Avatar
Re: 1950? S-10 tdi
Bob, very nice...Jim
oldman3 is offline   Reply With Quote
Old 01-19-2021, 08:17 AM   #56
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Thankyou I will
Thanks glad I can help you kill time. I will, I'm guessing between 30-40mpg but ??. Ya kina sucks they are probably over seas.
Marc
Ya it's the same color as my 2010 Jetta, made it easy to find a color.
Thanks Jim
1951 MG TD
Old 01-19-2021, 01:31 PM   #57
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
Originally Posted by lower50's View Post
Today I did a few little things, but my trans cooler came in so I got it tacked in before I had to go to work. It's a Derale 16 pass with a 10" fan. I tried a few spots behind the cab and thought this should give some air flow while driving.
[ATTACH]2074416[ATTACH]
that's exactly where/how i've been planning to put some coolers too, here's hoping we know what were doing!
6DoF is offline   Reply With Quote
Old 01-20-2021, 08:19 AM   #58
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
I have seen lots of people put them under the floor boards on cars and seem to work ok we will have much better air on the trucks.
1951 MG TD
Old 01-21-2021, 08:41 AM   #59
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Fuel tank is in and hooked up down to the fuel filter. Peddles, steering column, ebrake peddle and speakers. It's all going to plan so far.
1951 MG TD
Old 01-22-2021, 08:40 AM   #60
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Started laying out the fuse panel plate so when I run a wire I will know there to cut it off. Wow way less circuits needed in this truck than my other truck.
1951 MG TD
Old 01-26-2021, 12:27 AM   #61
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
On the weekend I put the front clip on to get some stuff figured out. Rad is out to be modified and I can work on turbo fitment stuff as well as body mounts.
1951 MG TD
Old 01-26-2021, 12:36 AM   #62
oldman3
oldman3's Avatar
Re: 1950? S-10 tdi
Looking good...Jim
Old 01-26-2021, 10:08 AM   #63
youngrodder
Re: 1950? S-10 tdi
Nice progress....theses all sorts of room for activities in that engine bay.
I feel your pain on the wiring. I have been wiring mine for what seems like weeks.
Marc
Old 01-26-2021, 02:18 PM   #64
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
when i was building my 02 WV Golf TDI, i found a junkyard in The Netherlands (yes, in Europe) that was really good. it was cheaper for me to buy a complete 5spd transmission swap kit from him and ship it over-seas than buy anything local. i also ended up buying a complete custom tuned ECU shipped cheaper than anyone in the US would tune mine. had him send me the bigger AFN injectors with it. just his tune and injectors made that car super fun.
http://www.dutchautoparts.com/index.php
i always worked with Franz, great dude. TONS of great feedback from everyone who uses them. but they can be slow to reply and respond, gotta have patients.
Old 01-26-2021, 02:45 PM   #65
vintovka
vintovka's Avatar
Re: 1950? S-10 tdi
When your done you may pull up at stoplight and cars around you will be looking for a VW !!
Old 01-26-2021, 02:54 PM   #66
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
hopefully not like this??
Old 01-26-2021, 03:44 PM   #67
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
stock would ramp in the boost and RIGHT at peak RPM it would hit 16psi for like 1sec. mine was tuned to basically 18psi all the time. the only smoke from mine was a bad PCV that would fill the intercooler with oil. then when i'd get to ripping on it she'd suck that oil up into the intake. had an oil separator on it for a while, but was too much trouble to empty it that often. so instead i just stopped changing the oil and added some now and then. haha
Old 01-26-2021, 03:48 PM   #68
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
do you have any plans to build the motor at all? i did a bunch of research and was just about to build my ALH for 300hp before it went in the '55 ... then the 12V fell in my lap.
Old 01-27-2021, 12:33 AM   #69
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Looking good...Jim
Thanks Jim
Marc
Wiring does seem to take forever. Yes total contrast to my other trucks engine bay.
I'll look him up. All of the parts, adaptors and tune I use are Canadian which is nice.
Ha that will be great
No I hope not!!
This one should work well with the setup I've got together. My Jeeps ALH runs 20psi all the way through this one has a different but bit bigger turbo.
Stock internals are more than enough for even stage 3 which is what I'm thinking I will run. 140whp and 240wtq. I'll have to do injectors tho. I run a stage 2 in my Jeep and it pulls great, not like a 12V tho.
1951 MG TD
Old 01-27-2021, 09:31 AM   #70
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
Stock internals are more than enough ...
but it's just so entertaining to say "block girdle" ... why not need one?
Old 01-28-2021, 12:01 AM   #71
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Yes it is.
Today I got the front end hanging on it's own, front clip body mounts are tacked in. I need to do a bunch more work to the inner fenders before I can take them off to clean and paint.
1951 MG TD
Old 02-01-2021, 06:33 PM   #72
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
On the weekend I got the cold side of the intake put together. Then put in a crossmember and bumper supports. 2x4 1/8" then 2x2 1/4", I added a lower brace but forgot to take picture. The bumper is the tow truck bumper that came with this truck it is 1/4" thick it will never dent that's for sure. It is now sitting at what will be ride height, bumper at 7" and running boards will be at 6".
1951 MG TD
Old 02-01-2021, 06:40 PM   #73
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
I think you are having too much fun, enjoy, looks great
Old 02-02-2021, 04:15 PM   #74
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Maybe
1951 MG TD
Old 02-05-2021, 05:13 PM   #75
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Working on getting the running boards installed. Brackets are 1x2" tube getting bolted to the frame. I cut all the old bracket off.
1951 MG TD
chevy, custom, diesel, gmc, s10
