07-13-2018, 09:20 AM | #1 |
It followed me home?
What is needed for 22" on dually
What needs to be done to clear 22" wheels on a dually? Everything I read says a standard 22" "semi" wheel will be too wide to clear stock rear fenders. I know Tennessee wheel tires makes a townasty wheel that is supposed to clear but damn they really only come in one style. I know that wider fenders are available but a lot of truck I see out there have original paint. Are all of the trucks I see on instagram.. using a narrowed axle?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-13-2018, 09:53 AM | #2 |
Re: What is needed for 22" on dually
C&C rear ends are narrower & allow using the milled 22's.
The Tow Nastys allow using 22's @ the outer wheel position w/factory 16's @ the inner position on a stock width dually rear end & are supposed to fit under the fender lip (the disclaimer is that all set-ups are different so there is no absolute). As you noted, they only come in one style.
07-13-2018, 10:10 AM | #3 | |
07-13-2018, 10:20 AM | #4 |
67-72 parts collector,…
I think most are swapping to a c20 suburban or truck rearend.
Check out @lowboymotorsports on Instagram. He's done a bunch of these and has good pics. Under bed c-notch, flip kit and relocated rear shocks. I believe they also "face" both rear wheels to lessen the overall width.
07-13-2018, 10:51 AM | #5 | |
Also check w/site member 75dually. He actually did the swap on his square.
07-13-2018, 01:06 PM | #6 |
I actually told you to look at the wrong guy.
Check out @michaelstruckworks on instagram. I’m sure you could also contact them with questions.
07-13-2018, 01:12 PM | #7 |
I believe @lowboymotorsports uses a modified “flat face” wheels in some applications
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-13-2018 at 02:00 PM. |
02-17-2021, 01:15 PM | #8 |
Bump...
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
02-17-2021, 10:25 PM | #9 |
A standard Dually (DRW) rear end is about 72" WMS to WMS (Wheel Mounting Surface)
A single rear wheel (SRW) one-ton 14b full floater rear end is about 67.5" WMS to WMS which gives you about a 2" tuck on each side. A C&C rear end is about 63.5" WMS to WMS - I have been told that a C&C will work without a lot of frame work and I have been told that it wont - so that's not much help! The SRW have an Outboard style hub and the C&C and Dually rear ends have the Inboard style hub - and I still am not sure what those are!! SWR and C&C rear ends use the same housing, but different hubs, a C&C rear is a SWR housing with dually hubs. The Suburban 3/4 ton semi-floater rear ends have different spring perch dimensions but you would usually end up cutting those off anyways with a drop kit.
Sent by the random thoughts from the voices in my head... Last edited by EricU; 02-17-2021 at 10:32 PM. |
02-17-2021, 10:27 PM | #10 | |
02-18-2021, 10:28 AM | #11 |
a c&c rear works with 16"duallys without hitting the springs. the only problem is the wheel well edge will have to be moved in so the wheel doesn't hit it. I ran a c&c rear with duallys on my 4x4 awhile and it tucked the duallys under a standard bed. but If I had been low, the inner wheel would have hit the wheel well.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
02-18-2021, 10:43 AM | #12 | |
How does one make it work with standard, NOT C&C rear end, DRW AND still tuck under the rear fenders? Flat face rim on the outside rear?
02-18-2021, 10:55 AM | #13 | |
