03-05-2021, 10:43 PM | #2376 | |
A guy with a truck
Re: How to: Ruin a perfectly good C10
In other news, as if by some glorious accident, what was supposed to be a primer coat on the tubs actually looks pretty good, maybe. I’m not sure exactly how I feel about it, but I’m pretty sure I don’t hate it. In fact, I think I might kinda like it. Plan was to paint them blue, but for now they’re gonna stay like this. For now. I maintain the right to change my mind on this at any moment
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-05-2021, 11:41 PM | #2377 | |
03-06-2021, 08:38 AM | #2378 |
It looks clean.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
03-07-2021, 07:07 PM | #2379 |
A guy with a truck
Glove box is back in, and along with it mounted the ECM and handheld. What this really means is that all of the under dash ac stuff is back in place and working. Just needs plumbed under hood and charged and the cold air will be blowin’ again. Forgot how much ‘fun’ it is laying on your back on the floorboard plumbing ducting, wiring, and cables...
03-07-2021, 07:08 PM | #2380 | |
A guy with a truck
Thanks! It’s growing on me
03-10-2021, 11:39 PM | #2381 |
A guy with a truck
No big news, but here’s a pic of the bed with all of the bolts installed and snugged down. If I had more time, I might do some things differently, but I don’t, so here it is:
03-11-2021, 12:26 AM | #2382 |
What would do differently just out of curiosity. Where I'm sitting it looks like you nailed it out of the park! Just a phenomenal job, it looks so clean!
03-11-2021, 09:50 AM | #2383 |
A guy with a truck
Thanks Kyle. I do like it and think it looks pretty good, but the attention to detail is not to the level I typically prefer. Given more time, I would either 1) cut my own boards for the outside edges or 2) use a flange to bolt through at the bedsides. There is an unsightly (and uneven) gap where the wood meets the bedsides. I also would paint the tubs and rear sill blue for a more ‘factory’ look, just personal preference. I also can’t shake the idea of a clean, painted (or color matched bedliner) metal floor. This will do for now, though. I need to move on to getting the front tubs installed...
03-11-2021, 10:12 AM | #2384 | |
03-11-2021, 11:35 AM | #2385 |
Get those installed! Can't wait to see them all done.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-12-2021, 09:32 AM | #2386 | |
03-12-2021, 03:25 PM | #2387 | |
A guy with a truck
Up next! ...along with a million other things around the house...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-12-2021 at 03:30 PM. |
03-13-2021, 02:02 AM | #2388 |
Mine is Black. I considered Red for a nano-second. But if the RED faded.... It might appear pink & that is a no-go.
03-19-2021, 05:34 PM | #2389 |
Wow, Chris! I've been gone for 3 months and you've done a lot. I love your build. I'm fighting home deficiencies from winter storm that us Houstonian's aren't prepared for, and a drivetrain update on my GTO, otherwise I'd be doing similar things, like the latches and door rebuilds...
Your bed floor turned out great! My plan is what you still think you want to do... metal floor with bedliner, which I currently have. The liner the PO used was a cheap one, so it's flaking, and there's some rust that needs to be tackled before I do anything, but I've considered paint matched, since everyone is right, a black liner is always dirty, unless it's brand new. Even my new GMC, which came with one from the factory, and now has a tonneau cover, is still filthy. Not sure if a body colored liner would be any different, just that it wouldn't look as dirty as quickly... Just like your current color vs a black truck. Oh, and the color fading, like Scoti said... a non-color matched liner would look funny regardless of the color (light blue instead of medium blue?). But, pink would be awful...
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-21-2021, 11:37 PM | #2390 | ||
A guy with a truck
Made some progress on the front tubs: got the passenger side bolted in and fitting nicely. Also started the process of modifying the drivers side and after removing and reinstalling the fender and inner at least 37,000 times, I have finally got it fitting the way it’s supposed to and have the panel tacked together using my new toy. Finish weld, grind, and hopefully body work tomorrow, then paint sometime in the future?... The new Hobart welder was long overdue. I don’t know how I’ve survived this long without it. When I welded the passenger side fender the Eastwood was being weird and blowing through. When I did the exhaust it would not penetrate and just piled up. When I welded the bed floor mounts it made embarrassing looking not so sticky boogers. Last straw. There was no way I was attempting to mod this fender with that “welder” after how it had been acting. The difference between the Hobart and the Eastwood junk is astounding. Smooth as butter, making all the right bacon noises and nice little puddles...
03-22-2021, 12:18 AM | #2391 |
Very Nice!
03-22-2021, 07:50 AM | #2392 |
03-22-2021, 09:05 AM | #2393 |
That looks nice. I hear you on the welder thing. Sometimes I hate mine. But then again it could be the Operator.
03-22-2021, 10:19 AM | #2394 |
A guy with a truck
Thanks all, looking forward to wrapping this up. I felt the same way, like, did I forget how to weld? Are the settings right? Am I out of gas? Polarity reversed? Power feed problems? Nope, turns out it was a junk-a$$ welding machine. Not sure what happened, it seemed ok at first, but got worse with time. So happy to find out it wasn’t completely my fault and that I can still lay a decent bead.
03-22-2021, 06:13 PM | #2395 | |
03-22-2021, 06:13 PM | #2396 |
67-72 parts collector,…
Love the inner fenders!
03-22-2021, 08:49 PM | #2397 |
A guy with a truck
Do it. Don’t think, don’t look back, just do. The last ten years of my life would have been soooooo much better if I’d just bought the good welder to start with. Not joking. Do it.
Me too! They are a ton of work, but the look is unbeatable
03-22-2021, 08:53 PM | #2398 |
A guy with a truck
Tack, tack, tack. Grind, grind, grind. Repeat. It’s a process...
PSA: Harbor freight $2.99 moving blankets are highly flammable
03-24-2021, 08:33 AM | #2399 |
A guy with a truck
After MUCH swearing, it is bolted back together. Not perfect, but it’ll do for now...
03-24-2021, 08:42 AM | #2400 |
That looks very nice.
