Which way would you go?
I've installed the wheel/tire combination I want for my truck. These are 15"X8" 6 lug X 5.5 truck Rally wheels with 255/70/R15 BF Goodrich Radial TAs.
Now I need to make a decision on trim rings. Looking for the opinions on what I should do and why. Should I leave it alone and not run a trim ring? If I did go with trim rings, which size? 2" or 3"? I'm already wishing I had not put the white letters out and will probably change that soon. Please keep the ribbing to a minimum for the Martha Stewart ruler. Thanks! Chuck |
Almost Satisfied
![]() Join Date: Mar 2002
Re: Which way would you go?
Need a pic of the whole truck
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Sorry I guess whole truck pictures would help. Here you go!
One is with the old wheel/tire combo which I hated and one with the new wheel/tire combo, but before I added the correct center caps. Note: I replaced the springs & shocks over the winter which is what raised the ride height. I expect it will settle down a few inches. Thanks! |
Almost Satisfied
Beautiful truck. Since you have the chrome trim I would say go with the beauty rings, but I like the rally both ways.
personally I like the 3" on the trucks but bottom line is it is your truck so do it the way you like it. You get to look at it every day so make it what you like best
![]() Join Date: Dec 2014
I grew up in the 80s and 90s so I like having white letters out, and I run without trim rings because I can't bear to scratch up the rim, even if you can't see it and it does no actual harm.
But: for a nice, subtle stock looking truck like yours I would do 2" with black tire. Just my opinion.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
I went with 2.5 inch rounded from Coker tire. They are about as close to original I could find.
I like the trim rings... maybe the 2"?
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
Here are my 3" trim rings on what must be 7" rims. Hence they look too deep. They may look fine on your rims if they are 8".
Wow, those completely cover up the square holes in the wheels! My rims are 8" inches. Took a long time to find them in 6 lug. Bought 2 other sets in my quest before finding the exact look I wanted. I'm leaning towards the 2 1/2" trim rings from Coker tire. Thanks for the photo! Are those square edge or rounded edge trim rings?
Florida Edition
![]() ![]() Join Date: Oct 2010
3" rings on 15x8 Rallys with white letters out. I personally love this look, like back in the day.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Here are the Coker tire 2.5 inch rounded trim rings I mentioned earlier.
BlahBlahBlah
Personal opinion here, Rallies need trim rings or they look like someone stole your trim rings.
#15 |
#16 |
#17 |
Just FYI, I ordered two others sets from other vendors claiming to be rounded trim rings, only to return them because they were not.
When I found the Coker version they were on back order so I had to wait for them to arrive and I am glad I did. |
#18 |
SLOW BUT SURE,BUT CLOSER
3" on mine same tire. Timeless look
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#19 | |
Here’s mine. I think they’re 3” rings. I need to replace them and repaint the wheels, but I’m keeping mine in this configuration. Posted via Mobile Device |
#20 |
Brokoli Wad,
Where did you get those rims? They look like car rims which I thought only came in 5 on 4.75 and mostly 14"? I prefer those over the 73 up truck rims. |
#21 |
![]() Join Date: Aug 2019
My vote is the old school look. 3" trim rings with the letters out. But I am planning on running Craiger SS on mine.
#22 | |
It was an artistic junkyard swap. Posted via Mobile Device |
#23 |
Wheel Vintiques has “car rally’s” in 5x5 and 6 lug
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
#24 |
If it were my truck...
flip the tires so no white letters show, and add the beauty rings
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
#25 |
Old member
This was back in 1986/87 time frame. My truck has seen 2 other sets of wheels and tires since then.
15" x8" all 4 wheels. Trim rings are a must if you run the Ralley wheels. They just don't look right without them. Sorry about the pictures they are pictures of old 35mm camera pictures. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
