Old 05-15-2021, 01:48 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Dana 60 3.54 in the '68 Chevy C20
Well, I finally finished up the Eaton HO52 / Dana 60 rear end swap. The Dana was a coil spring rear end so that made the swap pretty easy. I had a few delays but it worked out good. I didn't have to cut my drive shaft. There are two different length rear shaft sections. The Eaton was 35 inches long and I had 4 or 5 different shafts I had saved and one of them had a rear section that was 33 inches long, it fit perfect. The front section of the original shaft used the small "U" joint at the carrier bearing and the front of the 33 inch rear shaft used the large "U" joint. All I had to do was purchase a Precision Brand #348 Combination "U" joint, and everything fit right together. It made a world of difference in the driveability of the truck. Now I can hear the radio over the engine.....
Part number list is in post below
All of the pictures are of the Eaton rear end as I was taking it out.
LockDoc
Leon
Old 05-15-2021, 02:06 PM   #2
factorystock
factorystock's Avatar
Re: Dana 60 3.54 in the '68 Chevy C20
Thanks for the post! We need to see more of these simple swaps that involve little or very little modifying. Or we could wait and wait and wait till the aftermarket decides to manufacture a HO 52 3.54 ring and pinion set for '48 thur '72 Chevy C 20's. Those 16.5's with correct era caps look great!
factorystock is offline   Reply With Quote
Old 05-15-2021, 03:11 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
That should be a great upgrade for drivability.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-15-2021, 08:06 PM   #4
LockDoc
LockDoc's Avatar
Thanks. I don't look for anyone to make a gear set for the Eaton any time soon. Someone would have to make brake drums also....
I need to get some stock type lug nuts before I can put the rear caps on. The ones I have on there are too long.
Thanks Eric. I drove it to town and back this morning and it ran really good.
LockDoc
Leon
Old 05-16-2021, 08:21 AM   #5
You're a half a turn ahead now. Let it roll!
I wish someone would make ring and gear sets for HO52s while there are still so many out there. It's such a great rear. Brakes are no problem as long as there are 14-bolts all over the place. A simple swap. Someone (Patrick's) made gear sets for the HO32/33s way back in the '80s to help the '50s 1/2 tons run hiway speeds. As it is our choice is rear end swapping. That's why I keep a collection of rears.
Old 05-16-2021, 08:19 PM   #6
Dave
DND Trucks
Great job Leon! Was the HO52 a 4.57 open rear
Dave is offline   Reply With Quote
Old 05-16-2021, 09:36 PM   #7
LockDoc
LockDoc's Avatar
Believe me Tim, It's rollin'. I've been lookin' forward to driving it for quite a while...
Not sure at this time Dave. I couldn't find any numbers on it and I haven't removed the cover yet.
LockDoc
Leon
Old 05-17-2021, 04:57 PM   #8
LockDoc
LockDoc's Avatar
Here are the different part numbers for the Dana 60 coil spring rear end.
Brake Shoes = Bosch BS419R
Hardware Kit = Raybestos H7128
Wheel Cylinders =
CENTRIC 13462015
Rear Right; Rear Leaf springs
CENTRIC 13462016
Rear Left; Rear Leaf springs
Yes, I know they say for Leaf Springs but they fit the coil rear end and were exactly the same as the ones I took off....
I ordered these wheel cylinders on the first try and they were the wrong ones.
CENTRIC 13466009
CENTRIC 13466010
LockDoc
Leon
Old 05-18-2021, 07:45 AM   #9
KevinK7
KevinK7's Avatar
...Thanks again for including the part numbers here.
('interesting' that the wheel cylinders that didn't fit, are listed for coil spring)
Did you by any chance replace the wheel seals? (I ordered Timken 455860 from RockAuto, hoping they are the right ones.)
Thanks again,
Kevin
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 05-18-2021, 09:40 AM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice swap. The D60 coil rear ends are probably a little more rare aren't they? Most were in leaf spring trucks from what I've seen because they were camper special big block trucks. I've seen pics of coil spring 6 lug D60s in these but never found one in the wild yet.
Ryan
1969 Chevy milk truck
Old 05-18-2021, 09:52 AM   #11
KevinK7
KevinK7's Avatar
I'm relatively new on these trucks and learning as I go along, and it seems odd, the Dana60 rear doesn't show on the SPID?
My truck came from the factory as Cab & Chassis, with Utility body installed (most likely from day one) with it's original 396, NP435 4-speed and a Dana60 Coil spring rear. Along with Special paint, I guess I was lucky to find it : )
https://imageevent.com/hvclassics/au...=1&n=1&l=0&z=9
'68 C10 50th
Old 05-18-2021, 10:24 AM   #12
chevmn
The Dana 60 was not necessarily an optional rear axle. On my truck it did have a powerloc (G87 option code) so that option shows on the spid, but otherwise the Dana 60 was a standard axle for the truck in my case ('72 C20 402/400), thus standard axle was Dana 60 with coils. If it would have been a GMC I believe same would apply, but standard would have been leaf spring rear with the Dana. Someone else might be able to comment on the small block trucks, but this was research I did with regard to my truck, and aside from the G87 option, Dana 60 was standard for it, thus does not appear on the spid.
chevmn is offline   Reply With Quote
Old 05-18-2021, 12:17 PM   #13
Dieselwrencher
From the research I did a while ago, big block trucks got the D60. I'm guessing that was because the Eaton's did not have a 3.54 gear ratio available.
Ryan
Old 05-18-2021, 12:37 PM   #14
LockDoc
LockDoc's Avatar
Thanks again,
Kevin
No, I didn't replace the seals. There was no sign of leakage so I just left well enough alone. I got all of the parts from Rock Auto.
Yes, the Dana 60 coil spring rears are hard to find.
I'm not sure what the reasoning was but I'm glad I found one....
LockDoc
Leon
Old 05-19-2021, 03:36 AM   #15
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
LockDoc
Please someone correct me if I'm wrong but I believe Centric 123.66024 is the correct drum for the Eaton HO52. Multiple vendors list them as in stock.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 05-19-2021, 10:45 AM   #16
LockDoc
LockDoc's Avatar
I honestly can't tell you. It has been posted on here that some people had trouble finding them. That's what I was going by.
LockDoc
Leon
Old 05-19-2021, 02:09 PM   #17
chevmn
If we assume that only the Eaton HO52, and Dana 60 was on those trucks (C20), that is likely true. Centric and Rock auto list two drums 123.68001 appears to be for the Dana 60 (12 inch dia), and 123.66024 shows 11.2 diameter. If in doubt check diameter of your drums. I made the mistake of ordering a set of shoes from Rock Auto for "coil spring" rear axle, and appears I have a set of Delco shoes for the H052, and cannot use them. Probably also why the brake hose going to the rear axle also would not fit, but I "engineered" an adaptor fitting and am using it anyhow. Hope this helps, but I would go by drum diameter and cross reference the part as necessary. It would seem just going by coil or leaf springs is not a good indicator as they apparently built coil and leaf spring axles in both Eaton H052 and Dana 60, and they are significantly different. I am learning as I go but it is expensive. Need a set of AC Delco shoes for the H052??
Old 05-19-2021, 02:34 PM   #18
KevinK7
KevinK7's Avatar
Good info, ...my truck (68 C20) is an original BB (396) so Dana60 rear, and that matches what you note. Thanks
'68 C10 50th
Old 05-22-2021, 12:13 PM   #19
factorystock
I believe the odd ball bigger drums came out on '72 only 3/4 tons. There is the possibililty that '68-'71 drums are one part # and the '72 drum is the other another part #. In '73 GM abandoned both axles for their own inhouse corporate axles.
Old 05-22-2021, 06:33 PM   #20
chevmn
Just received Napa UP UP419R Brake shoes yesterday, and as someone else posted both front and rear shoes (have not figured out which are supposed to be rear facing) are the same length. They are correct for the 12 inch drum and 2.5 inch width, but I have never seen this. Normally the rear shoe lining is longer. Not so here. These are riveted relined, labeled "made in china". I am done testing, and these will go on the truck, as this truck will not see heavy use or high miles, but am disappointed, as they have far less lining than what came off. I will try to get a photo of old and new when I attempt to figure out which is which -- the linings are not centered on the metal that the lining is riveted to, which leads me to believe it does matter on placement. Perhaps FLT FT419R (fleet) would have been correct???
Old 05-22-2021, 07:35 PM   #21
jocko
jocko's Avatar
short shoe forward
Old 05-22-2021, 07:43 PM   #22
chevmn
short shoe forward
agree, but what in my case where both are same length?
Old 05-22-2021, 07:44 PM   #23
LockDoc
LockDoc's Avatar
I don't know, It's hard to tell by the pictures.
LockDoc
Leon
Old 05-22-2021, 07:46 PM   #24
LockDoc
LockDoc's Avatar
It looks like one shoe has the lining closer to the top and one shoe has the lining closer to the bottom on each side.....
LockDoc
Leon
Old 05-22-2021, 07:58 PM   #25
chevmn
LockDoc
That is correct. Any idea which I should place to rear? As I said, this is my first experience seeing both same length.
