Old 06-15-2021, 01:02 PM   #1251
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: What did you do to your Blazer/Jimmy today?
It was delivered Friday from CA to MA.
I replaced the vent windows with some from Roger Koop that I was going to use on my 2 wheel drive Blazer, I ordered a pair of replacements.
I replaced the sweeps and fuzzies, I can never get them perfectly straight.
Replaced all the locks with a set from Leon including the glove box lock.
And I took the top off today, outside by myself!
The Blazer as it should be!
Pics or it didn't happen
Old 06-15-2021, 01:46 PM   #1252
Thealien
Thealien's Avatar
I posted pics, it happened!!
Or these?
Old 06-15-2021, 02:04 PM   #1253
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Oops. The photos are blocked here at work. Sorry! I can see these on my phone - glad this buy went better than the last member buy. Enjoy, that's a great buy.
Old 06-17-2021, 08:25 PM   #1254
scf100
scf100's Avatar
Nothing, it’s up on Jack’s!
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 07-20-2021, 02:09 AM   #1255
mcmlxix
Collector of Projects
mcmlxix's Avatar
Pieced together and test fit the Hydro-Boost system again. Made a bracket for the Wilwood proportioning valve to hang off my CaptainFab firewall mount. I was going to use -AN flex lines but hard lines will be cleaner and take up less space. I still need to plum the -AN Hydro-Boost lines and they would take up the same space ...
Rich
1972 K5 Blazer CST Click HERE
Old 07-21-2021, 02:35 PM   #1256
AsianBlazer
Active Member
AsianBlazer's Avatar
Dropped it off at Alaska Marine Lines in Seattle to load onto a barge for the trip home to Alaska.
AsianBlazer is offline   Reply With Quote
Old 07-21-2021, 06:14 PM   #1257
YellowK5
Active Member
Nice looking K5..I really wish I hadnt sold off the orig front seats for mine
YellowK5 is offline   Reply With Quote
Old 07-21-2021, 11:43 PM   #1258
AsianBlazer
Active Member
Thanks! Those seats are original, never recovered. The only parts of the truck untouched.
Old 07-22-2021, 01:36 AM   #1259
Tuff Gong
Tuff Gong's Avatar
Are those utility bucket seats?
Tuff Gong is offline   Reply With Quote
Old 07-22-2021, 01:54 PM   #1260
YellowK5
Active Member
Major depression just sets in....I took my orig number matching engine block and heads in for machining and the guys just called and said my block is cracked....I need to have a drink now
Old 07-22-2021, 02:06 PM   #1261
72gmguy
72gmguy's Avatar
On the bright side, small blocks are fairly cheap and not having the original drivetrains doesnt effect the value of these trucks the way it does on some muscle cars. Don’t be too depressed.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 07-22-2021, 05:56 PM   #1262
AsianBlazer
Active Member
I believe they are, but I don’t have access to the SPID at the moment to confirm.
Old 07-22-2021, 06:52 PM   #1263
Blazer690
Blazer690's Avatar
I have 2 3970010's one 30 over 1 standard around he 605 210 area so cal standard block $150 30 over short block $100
Blazer690 is offline   Reply With Quote
Old 07-22-2021, 07:47 PM   #1264
YellowK5
Active Member
That may be a option...I will let you know..I am going to think on this for a couple of days.
Have they been checked for cracks and any issues?
Old 07-22-2021, 08:07 PM   #1265
Blazer690
Blazer690's Avatar
The long block was in my truck with low oil pressure. I've had the other so long I cant remember, but I wouldn't have saved it
Old 07-23-2021, 11:35 AM   #1266
YellowK5
Active Member
690 I will send you a PM with my number.
I chilled for a bit and feel better. lol ..I decided to pull out a core motor for a different build and I will take it apart to see if it is good...I will still need a block to not waist all the other good parts.
looks like the core motor is the same block so it will work if good
Old 07-25-2021, 11:33 AM   #1267
scott123
Pics to follow but priming the new fenders and hood for my 72 K5. Switching back to the 72 from clip vs. the 68 that is there now.
And kudos to the kid in Taiwan that put the adhesive backed foam shipping pads on the fenders. I am not sure what type of adhesive was used but it would hold the space shuttle together.
I used everything I had and ended up sanding it off with a DA and 80 grit.
That guy is onto something with that adhecive foam pad.
Scott
scott123 is offline   Reply With Quote
Old 11-21-2021, 09:21 PM   #1268
best view
To the top
best view is offline   Reply With Quote
Old 02-12-2022, 02:11 PM   #1269
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Dreamed of it coming home to celebrate it's 50th anniversary...
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-18-2022, 09:54 PM   #1270
7D2N
7D2N's Avatar
I finished up seat frame repairs with new springs and paint.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 02-18-2022, 10:56 PM   #1271
mcmlxix
mcmlxix's Avatar
Building a seat base for the late model seat swap...
Rich
Old 02-18-2022, 11:06 PM   #1272
davischevy
davischevy's Avatar
I changed the brake booster and master cylinder on my son in laws Blazer.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-06-2023, 10:23 PM   #1273
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Had reproduction dealer license plate frames made based off a photo I have of an original. Still chasing an original example.
Old 03-13-2023, 11:23 AM   #1274
396ci
396ci's Avatar
those are cool. which vendor did you use for yours?
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 03-17-2023, 08:11 AM   #1275
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you. Brad Barrie made these. He's got a site on FB. If you need his email address shoot me a PM.
