09-04-2021, 07:27 PM | #51 |
Re: 1968 C10 Suburban
Thanks! I still think it needs a little "altitude" adjustment. Maybe a couple three inches lower ?
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
09-12-2021, 07:54 PM | #52 |
I used a 71-72 TH400 kickdown switch by making a bracket for the firewall side of my accelerator pedal assy.
09-24-2021, 01:01 AM | #53 | |
10-17-2021, 01:12 AM | #54 |
I replaced the heater core and blower motor with wheel this week.
10-17-2021, 01:16 AM | #55 |
I just replaced the water pump , thermostat and hoses three weeks ago.
10-17-2021, 01:22 AM | #56 |
I bought a set of rear springs to lower a pickup two inches, I think with the added weight of a suburban it may lower it more. Anyone have any experience or opinions ?
10-17-2021, 10:01 AM | #57 |
A C10 Suburban is 800 to 1200 lbs more than a comparable pickup depending on options. So my guess is that it should sit about 1 inch lower than a pickup with the same springs would.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-17-2021, 11:16 PM | #58 |
Thanks , That's what I was hoping for . My 67 Step side had 4" drop springs and it would bottom out sometimes. I would like to avoid that if I can.
11-11-2021, 02:14 AM | #59 |
I installed some Jeep JK headlights I found at a yard sale . Now I can replace the bulb instead of the whole headlamp.
11-11-2021, 10:40 AM | #60 | |
The Older Generation
I used those in my '67 Panel Truck with the relay upgrade. They work good. LockDoc
11-11-2021, 12:55 PM | #61 |
Proprietor of Dale's Corner
Do those have glass lenses? They look really nice.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-11-2021, 02:00 PM | #62 | |
They are Lexan.
11-11-2021, 07:24 PM | #63 |
11-12-2021, 09:21 AM | #64 |
Those look really nice. Do you know what year they are for?
11-12-2021, 02:22 PM | #65 |
I used Jeep Wrangler headlights in my '67 Panel Truck. Jeep JK Wrangler headlights ('07-up) are a direct bolt in swap for the old sealed beam headlights in our trucks. They even have the 3 lugs on the back for alignment and use the stock '67-'72 trim rings. I went ahead and bought the headlight conversion pigtails for the swap too. I bought both on e-Bay. Here are the actual pigtails I bought and the headlights I bought were from a private seller that changed his over to something different. They are in excellent condition. You have to be careful because there are a lot of look alikes. They do make exact replacements too but you have to watch, some of them come with bulbs and some don't. The easy way to tell the OEM's are by the back. I think the lights are the same from 2007-2015. https://www.ebay.com/itm/13094045132...78.m1438.l2649 Sorry about the hijack..... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-12-2021 at 02:35 PM. |
11-12-2021, 11:27 PM | #66 | |
Thanks. I bought mine at a yard sale from a guy that said they came out of his 2010 Jeep JK.
11-21-2021, 11:57 AM | #67 |
Dont take it apart.
12-17-2021, 01:52 PM | #68 |
12-27-2021, 09:03 AM | #69 |
I had truck lowering springs at first and it drove terrible, rear of truck was very soft. Switched to cpp 4.5" hd springs meant for the suburban and it drives awesome now
03-02-2022, 01:57 AM | #70 |
I had a backup light acting up. I figured out it was the socket connector. What I was sent from LMC would not work so I modified my light with a sleeve to hold it and it works well . I did not change anything that can't be fixed correctly if I do find the correct part(in picture 2 ,which is part of a harness).
03-14-2022, 01:23 AM | #71 |
My oldest Granddaughter helped sand and prep the brackets for the new mirrors I will be installing.
03-14-2022, 09:26 AM | #72 |
Well, tell her she did a great job! With the paint on there they look like new. LockDoc
03-16-2022, 12:52 AM | #73 |
Thanks, I will let her know. I put them on , they look like they belong there.
03-16-2022, 12:53 AM | #74 |
Now I need to get the holes from all the other mirrors patched up.
03-16-2022, 12:58 AM | #75 |
I need to get a lot of things done this spring . I'm running out of storage for the parts I have to install .
