Old 09-11-2021, 09:49 AM   #1
68PanelTruck
68PanelTruck's Avatar
Mud flap behind rear wheels?
Hi guys. I have a 68 Panel and I have a question about what I think is a mud flap. I saw this picture below (not my truck) and it looks like some sort of mud flap behind the rear drivers side wheel. Did this come on the truck originally? If so, anyone know the dimensions? Is it steel? I'm guessing that Suburbans might have only have one behind the driver side wheel due to the spare tire wheel well on the passenger side.
I know that I probably won't find any originals so I think I'll just make them out of some steel. Or, maybe make them out of a semi truck mud flap? It would be great if someone can tell me a rough dimension.
It's not rust, it's called patina
Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust.
68PanelTruck is offline   Reply With Quote
Old 09-11-2021, 12:04 PM   #2
pwdcougar
pwdcougar's Avatar
Re: Mud flap behind rear wheels?
Here ya go! They are stamped steel and a pretty heavy gauge. Thicker than the body panels.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-11-2021, 07:01 PM   #3
68PanelTruck
Hey Paul, thanks so much for the pictures! Sure will help me fab something up. Thanks again.
Old 09-11-2021, 08:50 PM   #4
pwdcougar
pwdcougar's Avatar
Dude you got so lucky. I just pulled this out to sand blast it!
Old 01-04-2022, 08:23 PM   #5
68PanelTruck
Just a little update on how they turned out. I used 16 gauge sheet metal and a slightly different design. I had to wait until the floor was in before I could install them. Thanks again for your help.
Old 01-04-2022, 11:22 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Looks good! Yours should give more protection than the originals.
LockDoc
Leon
Old 01-05-2022, 10:40 PM   #7
68PanelTruck
LockDoc
Yes, I made them wider than the stock ones. They go from the quarter panel to the frame. The original ones look like they are the width of the tire.
