Old 01-12-2022, 01:25 PM   #1
vet57air
vet57air's Avatar
66 cowl seal
Final details on my truck. Pictured is what I know as the cowl seal. Seals between the back of the fender to cowl. I was very specific when I ordered the rubber but not sure if is the one I need. Anyone have input, tips pictures of the install?
vet57air is offline   Reply With Quote
Old 01-12-2022, 06:07 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 cowl seal
Looks like a great seal laid back and all. Your going to have to cut in your own bolt holes? Take your time.
Old 01-12-2022, 06:47 PM   #3
vet57air
vet57air's Avatar
Re: 66 cowl seal
Seal has a groove that will allow it to mold over the lip allowing me to glue it. This seal won't cover all the way to the cowl. Looking at the stock seal in pictures it is not much wider. Are they suppose to "fill the whole void"?
Old 01-13-2022, 01:32 AM   #4
AcampoDave
AcampoDave's Avatar
Re: 66 cowl seal
I've always thought a cowl seal is the one that seals the grated panel (below the windshield) to the back edge of the hood when it's closed. I'm not sure what seal is in the picture, but looks like it's not for the metal fender supports in the pic. I just had my fenders off and the ones that go on the support in the pic are more of a rigid formed piece which is shaped to fit the void. They are held to the supports with 3 or 4 metal fasteners. They are there to keep tire spray out of the door jamb area.
AcampoDave is offline   Reply With Quote
Old 01-13-2022, 08:16 AM   #5
The Rocknrod
Moderator
Re: 66 cowl seal
Now I'm not sure what seal that is.
Old 01-13-2022, 08:09 PM   #6
val1gonzales
Re: 66 cowl seal
That seal or weather-strip is used to put between the inner fender well to the firewall. I used 3M weather stripping glue from a tube. Measure twice cut once.
val1gonzales is offline   Reply With Quote
Old 01-13-2022, 08:20 PM   #7
vet57air
vet57air's Avatar
Re: 66 cowl seal
Yes thank you. I may try to use the rubber I have as long as it "bridges the gap".
Old 01-13-2022, 08:33 PM   #8
val1gonzales
Re: 66 cowl seal
The gap is cause the steering cover already had its seal stapled to it. They send "just enough" to fit what you need done. you'll need it on outer side of hood hinge as well.
Old 01-14-2022, 01:41 PM   #9
vet57air
vet57air's Avatar
Re: 66 cowl seal
My truck is a little custom and has different inner fenders. I am working on the seal between the back of the fender to cowl.
Old 01-14-2022, 06:30 PM   #10
val1gonzales
Re: 66 cowl seal
Whoa! It seems like that truck isn't going to see any bad weather anyway. Looking awesome!
Old 01-14-2022, 06:32 PM   #11
SCOTI
SCOTI's Avatar
Re: 66 cowl seal
Come on man.... Just a little?? LoL. That's one bad boy right there
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-16-2022, 04:56 PM   #12
vet57air
vet57air's Avatar
Re: 66 cowl seal
So I used the seal they sent me. Actually made for the stock inner fenders. It was easier to install as it has a groove that I just glued to the steel. No staples to deal with.
Old 01-16-2022, 07:49 PM   #13
The Rocknrod
Moderator
Re: 66 cowl seal
So now I find the thread on fender seals. - http://67-72chevytrucks.com/vboard/s...t=fender+seals
Old 01-16-2022, 11:58 PM   #14
val1gonzales
Re: 66 cowl seal
Interesting. But is the fender seal wide enough to close the gap to the firewall when installed?
Old 01-17-2022, 12:08 PM   #15
vet57air
vet57air's Avatar
Re: 66 cowl seal
I checked before I glued and it is. I also cut off the bit that goes behind the lower fender mount. It makes installing with the fender on way easier.
Old 01-17-2022, 11:07 PM   #16
val1gonzales
Re: 66 cowl seal
Excellent! Going to do the same fix. The staples are out of my capacity and glue is easy. Looks to be a better seal as well. Thanks for the info.
