#376 | |
Re: My 56 build
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#377 |
Re: My 56 build
So I decided to make the center console removable. Welded nuts to strips then welded those to the back of the console. Also finished the placement of the vents and welded up the previous holes. I would of liked to put the outer 2 all the way to the ends, but I need a flat surface. So this is where they are going to be
#378 |
Re: My 56 build
very nicely done.
Thanks for the pics
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#379 |
![]() Join Date: Mar 2007
Re: My 56 build
Is funny to see all of the AC work your doing when considering how cold it has been in MI as of late....ha ha.
Good work tho. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#380 |
Re: My 56 build
Thanks! I know… it’s been about -10* here for about a week. 20* today and it feels like a heat wave. Typical January this far north.
#381 |
Re: My 56 build
final assembly and future tinkering, i think that waterfall being removable will be money
#382 |
Re: My 56 build
So the big brown truck brought me a wire harness. So I’ve been tinkering with that for 2 days. Still looks like a mess, but everything is in place and temporarily run. Figured I’d work out as much under dash wiring before I weld in the dash!
#383 |
Re: My 56 build
Dash is welded in. No problem getting the vintage air unit in. I have a good start on the bed wood.
#384 |
Re: My 56 build
Nice metal work on the console and dash extension. The curves in the steel are nice, and and they blend together perfectly. That's tricky stuff to do. The entire box is looking pretty darn sharp too!
#385 |
Re: My 56 build
Thanks, after the box and seatbelts I’m going to start laying body filler.
#386 |
Re: My 56 build
Finished up all the bed wood and strips. 2nd picture is a sample of how I plan on staining the wood. Should look petty sharp with the dark blue body paint. Finally welded in the cowl too.
#387 |
Re: My 56 build
Looks very nice and I agree the wood stain should match the truck perfect. It's amazing how much hardware there is in the bed of one of these trucks. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#388 |
![]() Join Date: Mar 2011
Re: My 56 build
Bed wood color should look great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#389 | |
Re: My 56 build
Thanks Jim
#390 |
Re: My 56 build
Love it!!! What did you use for that stain? I’m also thinking off black stained wood for mine
#391 |
Re: My 56 build
It’s just minwax water based stain. I’m using semi-transparent because I still want to see the grain. I choose to use pine for the same reason. Oak grain is much finer. First pictures of the wood has one coat and the last picture has two. I’m planning on one coat. I don’t want to loose the grain in the dark stain.
#392 |
Re: My 56 build
Spent some time in the basement today. Outside temperature was only in the single digits so not a good day to heat the garage. So I got all the bed wood stained. Next is the clear.
#393 |
![]() Join Date: Apr 2016
Re: My 56 build
That's going to look great.
#394 |
Re: My 56 build
Nice, I like it. I was thinking about doing pine, and burning it with a torch.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#395 |
Re: My 56 build
Thanks guys. I’m really happy with the way it’s coming out. I believe the burnt wood process is called shousugi ban. If I were going black I’d definitely do it! Hope it turns out bigglass. I’ll probably start clear coating tomorrow.
#396 |
Re: My 56 build
that wood came out pretty!
#397 |
Re: My 56 build
Looks very nice!! Steve
#398 |
Re: My 56 build
Burnt pine is very stripey... if you want that look, then pine is definitely the right choice! If you want a consistent dark tone, a hardwood will burn more evenly. It's a good choice though, naturally weather-resistant!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#399 |
Re: My 56 build
Thanks guys. I put the first coat of clear on the bottom and didn’t like how much blond wood was still showing. So I applied a second coat of stain. Now it may be too dark.
#400 |
Re: My 56 build
![]() ![]() this one takes a lot of will power ... i re-did a bathroom and got the drywall JUST right, only to have the wife gouge it in a few spots while painting. drove me up the wall! but no one ever noticed with the room finished, even i stopped noticing after a few weeks, and it simply didn't matter. since then i really try to step back on some things and think "will anyone but me (and my buddies who nitpick everything just to give me sh!t) notice?" |
