Old 04-03-2022, 05:27 PM   #1426
PJ66C20
PJ66C20's Avatar
Re: What did you do to your truck today part IV
Replaced the turn signal switch on my '66 C20
PJ66C20 is offline   Reply With Quote
Old 04-10-2022, 05:40 PM   #1427
derek1387
Fixed my rear LED turn signal/brake lights. Found out last night that I had no turn signal or brake lights when my headlights were on.
Spent 5 hours on them today. Got frustrated. Went to a buddies house.
“Try swapping the two connections around. See what happens”
…..damnit.
derek1387 is offline   Reply With Quote
Old 04-10-2022, 06:00 PM   #1428
forestb
forestb's Avatar
…..damnit.
Have you replaced your mechanical blinker out for an electric one. If not your LEDs will not work. If you have done that than I would suggest checking all of your grounds.
forestb is offline   Reply With Quote
Old 04-10-2022, 06:02 PM   #1429
forestb
forestb's Avatar
Originally Posted by Railroadman View Post
Thank you! I have been bellyaching about winter's return for a few days (after hitting 70 degrees a week or two back). Now after seeing what you have, I don't feel bad at all!
I can only wish it was still winter. It was 101 here last week.
Old 04-10-2022, 06:38 PM   #1430
derek1387
Yes. It was a screw up on the original builders part. The Tail and Brake wires were switched and I overlooked it.
Everything works fine without the headlights turned on.
Turn them on….and no brake lights or turn signal, but DRL are full brightness. Should have caught it.
Now I have it. Swapped them around and g2g.
Old 04-11-2022, 05:35 PM   #1431
Railroadman
Railroadman's Avatar
Whoa, talk about going to extremes! I have heat in the shop, but no AC.
Railroadman is offline   Reply With Quote
Old 04-11-2022, 09:33 PM   #1432
pdxhall
pdxhall's Avatar
My Sanity has left the building. The '66 is off to the painters to get the roof painted. It should be done in about a week.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-14-2022, 11:16 PM   #1433
WTX-65LWB
Assembled and installed a Craftec cover on the ‘65. Nice product!
WTX-65LWB is offline   Reply With Quote
Old 04-15-2022, 12:33 AM   #1434
cwcarpenter98
cwcarpenter98's Avatar
Ooh, I like that. If you could, please start a thread about your installation and experience. That would be great for folks considering purchasing one.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-15-2022, 07:36 AM   #1435
WTX-65LWB
Thanks Christian! Will do; I didn’t take any pictures during the assembly but I will grab some more of the installed product and put together a thread.
Old 04-17-2022, 09:41 AM   #1436
derek1387
Bought fender emblems, and installed a new thermostat. Cant get the truck to run over 140*, so purchased another thermostat to try.
Old 04-17-2022, 02:52 PM   #1437
forestb
forestb's Avatar
Where do you have the sensor for the water temperature gauge installed in the engine? When I first installed my electric fan, I installed the thermostat for it in the back side of the intake manifold on my 350. The fan never turned on because it was not getting hot enough because it wasn’t making contact with water. So I moved it to the thermostat housing and it started getting a proper reading. All that to say, maybe your gauge is not getting a proper reading.
Old 04-18-2022, 07:49 PM   #1438
derek1387
Front of the intake just next to the thermostat housing. Edelbrock RPM intake
Old 04-18-2022, 08:59 PM   #1439
forestb
forestb's Avatar
Ok, yah, that’s where I have mine also. It was just a thought.
Old 04-23-2022, 09:17 AM   #1440
derek1387
What AM I going to do today?
Drill holes in my upper fender shroud things to mount the emblems…..gotta talk myself into it though.
Old 04-29-2022, 08:22 PM   #1441
MT65
Took my latest project in for front end alignment, all good to a point, all systems functioning, brakes bedded, clutch a bit stiff, will take some getting used to or adjust later, corners like a go cart, only glitch, 78k mile transmission seal decided it want to leak….easy fix, new seal will be here tomorrow…
MT65 is offline   Reply With Quote
Old 04-30-2022, 10:44 AM   #1442
caseyjones
Looks great Mike!
caseyjones is offline   Reply With Quote
Old 04-30-2022, 12:41 PM   #1443
jayoldschool
Moderator
Went and got it from storage! Started right up, great drive on country roads home.
jayoldschool is offline   Reply With Quote
Old 05-06-2022, 11:01 AM   #1444
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great feeling. There should be a song about that.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-09-2022, 06:47 PM   #1445
LostMy65
LostMy65's Avatar
Cleaned up the taillight connections.
Lights are a lot brighter now.
Had to use PB Blaster to get the old bulbs out.
Old 05-09-2022, 11:33 PM   #1446
TJ's Chevy
TJ's Chevy's Avatar
Tried out a set of flowmaster super 44's. She's stinkin loud haha
https://flic.kr/p/2njDQJ8
Old 05-10-2022, 06:46 AM   #1447
Nice TJ!
Old 05-10-2022, 09:11 AM   #1448
The Rocknrod
Moderator
The Rocknrod's Avatar
Sounds Awesome!
Old 05-10-2022, 09:32 AM   #1449
roll_the_dice
roll_the_dice's Avatar
Sounds great TJ! Looks great too! Glad to see I am not the only one that uses Spray Max 2K clear coat in a rattle can!
roll_the_dice is offline   Reply With Quote
Old 05-10-2022, 10:44 AM   #1450
forestb
forestb's Avatar
Sounds pretty rowdy. Not what I would expect a straight 6 to sound like.
