Wheel and Tire help - 66 4x4 Suburban
Long time board member with very little 4x4 wheel/tire knowledge, please bare with me. Hoping the 4x4 guru's can provide some guidance/recommendations based on the below:
1.Want to run radial over bias ply 2.Want the tall/skinny offroad look (keep wheel/tire inside fender wells) 3.Vehicle is 66 4x4 Suburban (stock height, no lift) 4.Wheels will be new OE style GM truck steelies. Either 15x6 or 15x7 so I can run dogdish caps. Want the tallest/skinniest radial 4x4 tire I can safely run and try keep that "close to stock" look. Thanks in advance.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#2 | |
Re: Wheel and Tire help - 66 4x4 Suburban
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
Fair question Short 3/4. Vehicle is 66 4x4 Suburban (6 lug) which as I understand it makes it a 1/2 ton. Apologies, I don't yet own the vehicle so am unable to validate.
![]() ![]() Join Date: May 2015
not sure how bigga tire you can run , but thisll help you with what is what for tire sizes
https://tiresize.com/chart/
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-28-2022 at 02:36 PM. |
I had 35s on my 62. Weren’t tall n skinny but fit just fine. A 255/85/16 is a skinny tire, smidge over 33” I think.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
("A 255/85/16 is a skinny tire, smidge over 33” I think.")
b454rat..they are... i have 2 sets of those but hes wanting 15s
BFG used to make a 235/85r15, probably not anymore. If I had lots of money I would get custom 16" wheels made for the 6 bolt pattern and run the 235/85r16 tire. They may already make those wheels but not cheap.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Appreciate the responses all, thanks. I am taking a slightly different approach and am going to go with a 16x6 wheel rather than 15". It will be a few weeks before I have the vehicle and a few more to obtain the new wheel/tire combo. I will do my best to update with pics here once I get there.
it may be hard to find a taller tire for the 6in wide rim...i wanted the tall/skinny , so i went with 255/85-16s..but i had to step up to a 8in wide rim to run them
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-01-2022 at 07:41 PM. |
Thanks mongocanfly and understood. I am not set on tire size or wheel width yet but do know I am going to go with a 16" wheel. Any chance you can post a pic or two of the wheel/tire setup you mentioned above?
I have always used a 235/85 16 radial and I think it’s a nice stock look on these era trucks, and still fairly easy to drive with manual steering. Have mainly used 70-80’s steel take off rims, but mine always 8 lug, so easier to find.
BTW I just learned that all Suburbans are 1/2 ton, so my first post was kind of redundant. Have fun with the new project Tom
this is the set with black rims...i have the other set mounted on white rims, ill add a pic of those tonite
Thanks for the pic, that does look good! To confirm the wheel/tire sizes in that pic?
wheel = 16x8 Tire=255/85R16
yep...
#15 |
20' Daredevil (Ret)
![]() Join Date: May 2003
For the record, 255/85-16s fit perfectly on 7" wide wheels too. That's what I have (on Ford wheels) on my K20.
Tire Rack shows a recommended rim width of 6.5"-8", and a measured rim width of 7".
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-01-2022 at 07:43 PM. |
#16 |
I looked for a set of those Ford rims, but never found any
#17 |
20' Daredevil (Ret)
I got lucky, found mine in a junkyard about 6 years ago.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#18 |
Wernt those rims just on Ford vans?
#19 |
[QUOTE=Stocker;9073908]For the record, 255/85-16s fit perfectly on 7" wide wheels too. That's what I have (on Ford wheels) on my K20.
Tire Rack shows a recommended rim width of 6.5"-8", and a measured rim width of 7". Appreciate the info and pics, Stocker. That is one nice truck and a sweet wheel/tire setup.
#20 |
20' Daredevil (Ret)
No sir, they were on F250s up until 1996. Ford changed them to a metric bolt pattern in 1997. Van wheels didn't change until later, but I'm not sure which year.
Thanks! It should be out of paint prison soon and I'll post up some fresher pics.
#21 |
Heres a pic of the set I have mounted on white...really like the way these look
#22 | |
20' Daredevil (Ret)
#23 |
As promised and thanks to all the board members that chimed in with helpful info. 16x6 smoothies arrived 4 1/2 months after ordering, currently at the powder coater. Next post will be before/after shots.
#24 |
Before/After shots
Wheels = 16x6 smoothies, powder coated Tires = 255/85R16 BFG KM3 BEFORE: AFTER:
