Old 05-11-2022, 01:54 AM   #1451
TJ's Chevy
TJ's Chevy's Avatar
Re: What did you do to your truck today part IV
Nice TJ!
Thanks Palf!
Originally Posted by The Rocknrod View Post
Sounds Awesome!
Thanks!
Originally Posted by roll_the_dice View Post
Sounds great TJ! Looks great too! Glad to see I am not the only one that uses Spray Max 2K clear coat in a rattle can!
Thanks! Yeah, I restore chainsaws when I can these days and that spaymax has proven to be good stuff!
Originally Posted by forestb View Post
Sounds pretty rowdy. Not what I would expect a straight 6 to sound like.
Thanks! Yeah I'm pretty stoked with the sound. Tried to get as much of the raspyness out of it as I could. Those mufflers helped alot and next will be decently long tailpipe tips a good inch bigger in diameter to mellow it out more.
Old 05-11-2022, 11:12 PM   #1452
60short
Revitalizing a 6T C10
60short's Avatar
cleaned up some trans linkage, organized the toolbox and installed my (unofficial) front plate
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is online now   Reply With Quote
Old 05-12-2022, 01:46 AM   #1453
62bagger
62bagger's Avatar
I like the front plate.
62bagger is offline   Reply With Quote
Old 05-12-2022, 12:49 PM   #1454
60short
60short's Avatar
Thanks, I figured it answered the 2 most common questions, what year? and why isn't it painted yet?
Old 05-12-2022, 01:11 PM   #1455
roll_the_dice
roll_the_dice's Avatar
NICE! I hate the statement, it's going to look great when you paint it. I look over at my truck and say, you don't like my custom paint job?
roll_the_dice is offline   Reply With Quote
Old 05-12-2022, 01:14 PM   #1456
roll_the_dice
I didn't do anything sexy to my truck but I had a small transmission leak at the mechanical speedo connection. Finally (hopefully) fixed the leak! Leaks are super annoying!
Old 05-12-2022, 01:15 PM   #1457
forestb
forestb's Avatar
You probably secretly love it also. I know I would.
forestb is offline   Reply With Quote
Old 05-12-2022, 01:16 PM   #1458
forestb
forestb's Avatar
Is it a 350 trans
Old 05-12-2022, 01:20 PM   #1459
roll_the_dice
haha..a little. What I really love is when they think cause it "needs" a paint job it is junk...so I open the hood to show off the engine candy! LOL
Is it a 350 trans
No, it's a Tremec T56 Magnum 6 speed. Love the trans...hated the leak. I finally bought a new mechanical speedo adapter from Bowler (has multiple Orings). Pricey, but worked!
Old 05-12-2022, 01:30 PM   #1460
forestb
forestb's Avatar
No, it's a Tremec T56 Magnum 6 speed. Love the trans...hated the leak. I finally bought a new mechanical speedo adapter from Bowler (has multiple Orings). Pricey, but worked![/QUOTE]
Okay. I only asked because I had a 350 that I could not get to stop leaking from that location.
Old 05-16-2022, 11:10 PM   #1461
jweb
jweb's Avatar
Picked up my Suburban body on Friday after blasting and primer. A little rougher than I thought.
Spent the weekend assembling my suspension, also cleaned and painted the engine. Not quite the color I wanted but it will work.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 06-11-2022, 09:55 PM   #1462
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Moved my engine forward around 1/2 inch to 3/4 inch to give me more space between the distributor and the firewall.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-15-2022, 02:11 AM   #1463
TJ's Chevy
TJ's Chevy's Avatar
Brought Crustine the GMC home from the shop finally. Now onto driving again!
Old 06-15-2022, 12:39 PM   #1464
UTSA
UTSA's Avatar
Been doing this for a while. Replacing rusty rockers on the 65. Already have the passenger side done, these are pics of the Driver side.
moving on to seam sealer soon.
1965 C10 350 combo
UTSA is offline   Reply With Quote
Old 06-16-2022, 03:41 PM   #1465
LostMy65
LostMy65's Avatar
Chased an electrical issue until I finally figured out that there was a grounding issue for the bulb socket to one of the tail light housings. Putting the housing on the negative post didn't work. I had to run a wire from the bulb socket to the metal housing to complete the circuit. Strange, just on the one side. I could have just bought a new housing, but a short chunk of wire was cheaper.
Old 06-17-2022, 05:32 PM   #1466
62bagger
62bagger's Avatar
Bled the brake and clutch systems, replaced the leaking air bags with springs and shocks and got it back on the ground.
Old 06-24-2022, 03:08 PM   #1467
LostMy65
LostMy65's Avatar
It's been some days, but I wanted to post this.
First time using my new tractor to do something with my truck.
Boy oh boy - perfect fit with the bucket.
Old 06-24-2022, 04:48 PM   #1468
The Rocknrod
Moderator
The Rocknrod's Avatar
Cool. Tractors are the best.
Old 06-24-2022, 05:33 PM   #1469
LostMy65
LostMy65's Avatar
It's about time..
I used to be able to just lift the hood off by hand by myself. Seriously.
Old 06-26-2022, 01:28 PM   #1470
Braunschweiger
Clever
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 07-02-2022, 05:55 PM   #1471
forestb
forestb's Avatar
I modified my finned air filter cover so that I can us a center stud instead of the complicated way it was originally attached. I might end up stripping the paint and having it polished to go better with my new aluminum heads on my new 355.
Old 07-04-2022, 04:30 PM   #1472
Soupsdad
Washed the truck so I could take a picture of the new shoes.
Soupsdad is offline   Reply With Quote
Old 07-04-2022, 05:52 PM   #1473
forestb
forestb's Avatar
After looking at the photos I think I need to even it out a little better and paint it black.
Old 07-08-2022, 10:20 PM   #1474
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm digging that truck, end of story. If I had it, it would be all black, except for the Ed Hubbs style flame job.
~Steven
Simi Valley, CA
Old 07-17-2022, 11:00 AM   #1475
Fastgramps
Welded in some bed rails, most I haul in the truck are motorcycles😉
Fastgramps is offline   Reply With Quote
