1967 core support bracket mod to fit PS box - Pics?
Can anyone post a picture of how much they cut off their core support bracket to fit their power steering box? Ive done a few searches but have not come up with a good pic of the bracket itself.
Power steering conversion requires me to trim some of the bracket away for the PS box to fit. It looks like I would need to remove most/all of that lip on the edge, which gives the piece a lot of support. Debating on cutting off rivets to remove the core support bracket for modification. That way I can reinforce it assuming I do have to remove the lip. A good picture would help me solidify a decision. Thanks
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations Last edited by May70; 07-16-2022 at 09:32 AM. |
![]() Join Date: Mar 2003
Re: 1967 core support bracket mod to fit PS box - Pics?
No core support modification should be necessary for a power steering install. None that I recall
The Older Generation
I will be headed back out to the shop in a while. I will see what I have. I thought there was just a half moon bent up in that area for clearance.... LockDoc
Maybe somebody could post up a pic of what is being talked about.
![]() Join Date: Dec 2009
Here is a picture of my C-30 frame with core support off.
Hope this helps. ![]()
I looked at my trucks and did not see any interference with the core support. Just the inner fender notched out. I have about 1/2-3/4'' room around the mount
no cutting of core support or any bracket. I just trimmed inner fender for clearance access. 72 C10
67 has different core support brackets.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
On my 67 frame (that I no longer own, putting my 67 stuff on a 72 frame, thankfully!!!) the core support FRAME bracket needed a little chopped off the back to clear a 68-up power steering gear box (this would NOT have been needed on a 67 because of its old timey hydraulic ram steering assist setup).
Here is what I notched on the 67 Panel Truck with a '73 box in it. It isn't hitting but I could have trimmed the corner off a little bit more. Second & third picture is an extra '67 frame and cab I have. It had a later steering box bolted in it but I don't know if the truck was ever on the road or not.... They actually cut the frame notch back a lot farther than they needed to. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-16-2022 at 05:11 PM. |
Thanks everyone. With 1/4" spacers made up, it fits right in with a little trimming of the core support. Just shy of an 1/8" gap between the frame and the round housing of the steering box.
Something new for me as I've apparently never come across this. I have had to use spacers b'cuz of the non-dimple frame however.
#13 | |
I purchased the readhead 2856 (3 Turns): 1980-1991 (for o ring stile fittings to match ls pump side). Which is a 4 bolt direct fit up to a 67 c20 frame. For reference the bolt patterns are the same at least up to 70 that I have physically confirmed. Some manual boxes are only three bolt but again the pattern is the same. 7/16" bolts.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations Last edited by May70; 07-17-2022 at 08:57 AM. |
I have a winter project to convert my 67 to power steering. Any issues with spacing the box out versus dimpling the frame?
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#15 | |
I spaced mine out on my '67 Panel Truck. If I remember right I used 3/16" spacers. The only thing I noticed was that the truck turned a little sharper to the right than it did to the left. I removed the pitman arm and filed a groove in the flat area inside so that the pitman arm could be rotated to any position.... Centered the wheels, centered the steering wheel, put the pitman arm on and tightened everything up. LockDoc .
#16 |
![]() Join Date: Feb 2016
The issue is minor but it exists. When you space the steering box out the Pitman arm moves with it and as a result the wheels get turned to the left. This of course can be compensated by adjusting the steering links and repositioning the steering wheel.
Once that is done your steering will work fine with the exception of the truck won't turn as sharp at full lock one direction compared to the other direction. (To left if I remember correctly) This occurs because there are internal stops inside the steering box. As there are hundreds of steering box configurations your particular box may allow enough travel to hit the stops on the control arms before the internal stops. Some folks never notice it other folks can't stand it. Gosh that Leon has fast fingers. Must be how he got to be a Moderator
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#17 |
![]() Join Date: Dec 2013
Don't use spacers you'll just create problems for yourself , The amount the 67 frame needs to be "dimpled" is so minimal it can be done without any evidence to the top rail of the frame .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#18 |
All back together - next up im thinking is the rear end.
