BlahBlahBlah
In cab gas tank question
I don't know jack about the tanks in our trucks. I do see threads where folks are talking about vented cap or no vented cap. My guess is there must be some difference in the tanks themselves.
Are the tanks all the same but the piece where the sending unit goes in different? Or is the vent a part of the fill tube? Anyway Im just curious about stock tanks and how you tell the differences in years, and what years have a vented cap vs. pressurized (right terminology?)
![]() Join Date: May 2022
Re: In cab gas tank question
I just did a in cab replacement on my 72. From what I learned (or think I learned lol) during the process, there are three types of original tanks.
67-69 non-EEC 70-71 with EEC and 72 with EEC. The 72 had a smaller ID fill neck and cap. EEC systems require the non vented cap and non EEC systems require the vented style. Appears most all replacement tanks with EEC are based on the 71 design. Which has the larger ID fill neck and cap. I did not find an exact replacement 72. I used the 70-71 style EEC tank. As far as the sending units and small blocks go.. I read that in 72 the return line was introduced on automatic trucks to help with vapor lock. These are the sending units that have two lines on them along with the three line fuel pump. 67-71 have the single line 5/16 sending units; 72 manuals had single line 3/8 and 72 auto had dual line with 3/8 supply. This pic shows a tank with EEC. Note the vent lines. Last edited by jnewt; 06-12-2023 at 04:10 PM. |
BlahBlahBlah
Lots of good info for me to chew on, thank you!
72, at least mine, has a EVAP canister so venting is to that. The cap appears to be non vented. Mine is a 3 OTT
![]() Join Date: Dec 2014
To complicate matters, 3/4 and 1 ton trucks do not seem to have made the change to EEC. Possibly because whatever laws that GM were abiding by for the half tons they were able to sidestep for those "heavy duty" vehicles: I don't think that evaporative cannisters were standard on them.
http://67-72chevytrucks.com/vboard/s...d.php?t=645283
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
![]() Join Date: Jun 2005
My 70 with 250/3OTT had an evap can. It is a Fremont built truck
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#7 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Buying a gas cap for my 72 GMC 2500 was a really confusing experience until I found this out.
my 72 big block C-20,Fremont built truck has no evap canister or a EEC vented tank.there are 3 ports on the fuel pump,3/8's fuel in,3/8's fuel to the carb and a small 1/4 i believe return hose to the sender.
All about them K’s
![]() Join Date: Jun 2014
And to muddy it further my 72 K20 has only one line on the sending unit, and just an in and out on the pump-no return, and no evap. 1/2 tons were the only ones that had the evap stuff as far as I know.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
20' Daredevil (Ret)
Yessir, same with my '72 K20.
Observations on the 3/4 and higher trucks are correct. They are considered and licensed as a commercial vehicle in California which tends to drive most emissions rules for cars this age. In the seventies California exempted commercial vehicles from emission devices and the feds followed. I still have to license my 1972 3/4 with a commercial plate costing a few bucks more than a 1/2 ton truck. You can get an exemption from the commercial status if you have a permanent camper attached. You will get a ticket if a cop notices the camper is removed but most do not know this rule on the older trucks and would miss the citation.
Yet my 1972 K20 Suburban, with California emissions, has evaporative emission system with a charcoal canister.
For same reason you can register a c20 non commercial if you have a camper on it. The burb is a passenger car. It's the weight and intended use that classifies if a vehicle is commercial or not.
#15 |
![]() Join Date: Mar 2005
70 3/4 ton non etc, no evap canister vented cap. Also no air pump
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#16 |
Also, as was briefly mentioned by jnewt, the neck size of the two tanks were different as can be seen below. So there are two different grommets, and you have to use the one that matches the tank:
67-70 71-72 |
#17 |
My Fremont 71 C/20 has no EEC items .
71 C-20 07 Magnum RT AWD |
