#226 |
Re: Cheap Tricks
This one is good and definately works well, but it does have a shelf life so mix as needed.
"Lifetime" 72 C10 Project |
#227 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Cheap Tricks
Man, you guys are slick. This thread turned out better than I thought it would.
I'm working on a index for it by tools, tips, products, situations, etc. Any ideas from you all would be a great help. Thanks again for sharing your knowlege.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#228 |
Florida Edition
Re: Cheap Tricks
By the way.....we have had almost 7,600 views of these ideas, I know we have helped a few folks out and that was the original idea going in.
Thanks again everyone! ![]()
#229 | |
Professional Crow Bar Tosser
Re: Cheap Tricks
Btw, I love the animated gif for your avatar...I want one! Lol.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" |
#230 |
Re: Cheap Tricks
Hey guys new to the site and I I'm considered a youngster but I have a couple. For u guys w the icy windshields and mirrors try rain x they also make a product for motorcycle helmet visors that keeps them from fogging works pretty good here I'n ga not too sure how either would hold up for u guys w REAL winters. Also if any of u r running air ride suspension a little antifreeze I'n the tank will keep the tank and lines lubed up as well as the valves so rust or freezing weather won't stop u from riding. And if ur ever I'n a pinch w an air leak and have no Teflon for a fitting a platic grocery or sandwich bag will work to get u home or to a shop.
Posted via Mobile Device |
#231 |
Re: Cheap Tricks
This one I have used. Can't get a bearing race out of a hub etc? Run a (welding) bead on the face of the race and it will fall out of the hub. I know, logic says the heat will expand the race and lock it in tight, but running a bead shrinks it and will fall out.
#232 | |
![]() Join Date: Jun 2005
Re: Cheap Tricks
block.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#233 |
Re: Cheap Tricks
If you have body hammers (use this on the Martins and works great) or other lightweight hammers with wooden handles and the heads get loose put them in some antifreeze overnight. Will swell up the wood and make the heads tight again. Won't weaken the handles either. Plus the antifreeze keeps them from rusting unlike water.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#234 |
Re: Cheap Tricks
I should have mentioned that i use rain x in all my windshields and mirrors. After you use it you will not go with out it.
Trueman |
#235 | |
GMC's n H.D.'s too!
Re: Cheap Tricks
![]() I have used Rain-X in the past too, and works great, especially with questionable wipers! |
#236 | |
Re: Cheap Tricks
Trueman |
#237 |
C/10 junkie
Re: Cheap Tricks
If you are looking to buy rear drop shocks buy some front stock height shocks from your local parts store should be less than $20 each. Check the CPP catalog, the part number for their rear drop shocks is the exact same part number as their front stock shocks. I've done this for two of my lowered trucks and have saved a lot of money and they work great.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#238 |
Florida Edition
Re: Cheap Tricks
^ Good post Shawn!
#239 |
Re: Cheap Tricks
#240 | |
Re: Cheap Tricks
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
#241 |
Re: Cheap Tricks
I just thought of this and I dont think I mentioned it but when reusing coolant, like after hose replacement etc, put a paint filter in a funnel and it will keep the bugs and dirt out of your cooling system. They are cheap and are made of paper so just trash it when done.
#242 |
Re: Cheap Tricks
Add to the above- if you don't have a paint filter, and old t-shirt works great for this,too. Ask me how I know. Also works good for filtering gas into the dirtbikes!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#243 |
Re: Cheap Tricks
And I just threw away a bunch of paint filters that were just taking up space on my shelf,OH well, now I know better .
#244 |
Re: Cheap Tricks
While pulling apart my shifter linkage today I noticed there was a bit of a gap where it connected to the column. The bushing was 1/2" and the hole in the bit on the column was 5/8"! Went to home depot and got a bushing for about $0.50. I don't have everything back together yet(fixing a couple problems at once and haven't ordered all the parts yet), but that should tighten up the shifter a good bit!
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#245 |
Re: Cheap Tricks
A coffee filter will work great for the coolant or gas also. If u see a trashed coffee pot or before u trash one take the filter housing out, makes a great filter holder with a handle and somewhat of a funnel. Also u can fold a round coffee filter in two or more halfs and then open one of the folded pleats and also have a funnel filter. As a pleat gets dirty close it and open one of the other folded pleats and keep pouring.
#246 |
Re: Cheap Tricks
the filtering reminds me of another cheap trick, not really automotive related tho.....
You can take cheap rum or vodka and make it taste almost as good as stuff that costs twice as much! You can run it through a brita filter, but its SLOW and doesn't seems as effective. I build my own filter using activated charcoal and cheesecloth. You can find the activated charcoal in the fish section at pet stores or walmart. Make sure you clean up the charcoal really good first or it will turn your liquor black. I typically run it through 2-3 times to get the best taste. I did this with gold rum and I was able to notice a LARGE color change the first 2 times through.
#247 |
Re: Cheap Tricks
I'll definately remember that.
I also make my own Kahlua - I use a bottle of cheap vodka (Clear Springs or Everclear tastes better tho) 12 cups of very strong coffee, 1-1/2 lbs dark brown sugar & 5 tablespoons of vanilla extract. Yealds about 3-1/2 bottles of home made Kahlua. Total investment about $8.50 |
#248 |
Re: Cheap Tricks
make your own wine! all you need is frozen juice concentrate, sugar, yeast and water! I've made it a couple times before, its very drinkable, but leads to bad hangovers because of all the sugar.
http://www.wikihow.com/Make-Cheap-Wine
#249 |
Re: Cheap Tricks
While working on the shifters for my Mountain Bicycle a while back my teenage daughter came up with a great solution for faded indicator needles. Nail polish. Any Color imaginable, comes with a brush so it is super easy to control. I will be using this when I refurb my dash in the coming weeks.
Also, everyone who has been (or in my case still is) in the military remembers Neverdull on the brass or metal work... The stuff works great for removing rust streaks and such from chrome. Of course, if you neverdull your bumpers and the rest of your truck looks like mine, you will look rather silly Last edited by tpost01; 02-12-2012 at 10:53 PM. |
#250 |
I am a Referee of life.
Re: Cheap Tricks
Wanted to bring this to the top.So here's a "Keeping Momma Happy" tip.Ladder socks.I use an old pair of crew/work socks to cover the feet of my ladder when I bring it in on the carpet in the house.I use it in the garage and the yard and some times the feets ain't clean.With the scks I don't gotta xlean carpets,too.I do have to duct tape them most times if I'm moving the ladder around.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
