Old 12-14-2009, 11:44 PM   #226
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: [Project] "Fnlow69" PART II
Originally Posted by FnLow69 View Post
no, but im going to cap them once i remove the bed from the old frame.
Ok. Cool man.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 12-15-2009, 12:29 AM   #227
Rokcrln
Rokcrln's Avatar
Wow you sure are jumping al the way in now aren't you? Looks good, like the dash! On the chop (I have never done one of our trucks) would it have been easier to cut out the headliner in one piece, set it aside. Then do the outer roof work so you could hammer and dolly the welds out and then replace the headliner in 1 piece and add fillers to the sides? Like I said I have not done one of these but on the others I have done I always like full access to the roof skin until I am finished welding it all off.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-15-2009, 01:29 AM   #228
Inverter
Inverter's Avatar
That is one sexy bracket.
Roof line looks great! It really forces you to look twice to figure out whats diff. about it. Just the right amount of chop. Thanks for the photos.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 12-15-2009, 02:16 AM   #229
FnLow69
FnLow69's Avatar
Kevin
LFD Inc.
Kevin your right if i were to do this again i would cut the headliner in one piece. thanks im jumping on this now because i moved closer to where it's at, Its at my parents house and i now live like 10 min from them. before it was 35 mins away.
FnLow69 is offline   Reply With Quote
Old 12-15-2009, 02:17 AM   #230
FnLow69
FnLow69's Avatar
thanks inverter, i like the front mount but the rear one im not to sure on? any input is welcome.
Old 12-15-2009, 12:27 PM   #231
Inverter
Inverter's Avatar
Your welcome,
can you try and mimic the front ? The ears are just beautiful.
TROY
Old 12-16-2009, 11:04 PM   #232
Ronm909
67GMC Slammed
Ronm909's Avatar
wow what made you change it to a parallel 4 link?? looks killer
Ronm909 is offline   Reply With Quote
Old 12-16-2009, 11:09 PM   #233
FnLow69
FnLow69's Avatar
thanks Ronm909, i just didnt like the old link setup. Wanted something simple and clean.
Old 12-22-2009, 12:50 AM   #234
FnLow69
FnLow69's Avatar
Well got my panhard bar kit today so i got that installed and built the frame end mount. still have to gusset the back side like i did the front with the speed holed plate. also im changing the tube gusset to a plate with a speed hole in it. so it will flow better. anyways heres the pictures.
More this weekend and next week as im off tell next year.
Pictures....
laidout
speed holed gusset
Justin
Old 12-23-2009, 02:08 AM   #235
little nick D
hell ya man frame looks really nice, but i do have a ? why did you run a panhard bar as opposed to a watts link? just a ?..keep up the good work !
"Down to Earth"
little nick D is offline   Reply With Quote
Old 12-23-2009, 02:38 AM   #236
FnLow69
FnLow69's Avatar
cause its simplier i guess, i never really thought about a watts link to tell you the truth. Also theres not much clearance between the diff housing and that rear crossmember. Plus with the canti/rocker arms theres already going to be a lot going on back there.
Old 12-25-2009, 03:32 AM   #237
little nick D
thats cool man i was just wondering because i always see axels shift when the suspension travels with a trace bar like that.....ok thats just wat i ve seen an that just my opin....keep up the clean work
"Down to Earth"
Old 12-26-2009, 08:11 PM   #238
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
When you weld the brackets to the axle, is there fluid inside?
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 12-26-2009, 10:03 PM   #239
nuke1
nuke1's Avatar
Justin, i have not checked in a while, and i just have a few things to say, the truck is looking amazing, greatly thought out dash, just amazing. Keep it up!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-28-2009, 12:32 AM   #240
FnLow69
FnLow69's Avatar
im not sure if theres fluid in there, im going to have it rebuilt when i get the welding done.
Thanks man
Old 12-28-2009, 12:37 AM   #241
FnLow69
FnLow69's Avatar
Well on saturday i got the canti/rocker arms cut out with the plasma at my work and then i drilled the holes in them with a series of hole saws (not fun, lol) anyways today i got the holes all finished and got one tacked together. My hiem joints will be in tomorrow, so i should have them mocked into place tomorrrow.
Heres the pictures
Pieces cut and drilled...
and tacked together....
Justin
Old 12-29-2009, 12:15 AM   #242
little nick D
o man the joys on hole sawing!!!! ...are you going to mig them or tig them??..looks good
"Down to Earth"
Old 12-29-2009, 12:57 AM   #243
FnLow69
FnLow69's Avatar
mig i dont have a tig yet, i really want to get one there just a little expensive
Old 12-29-2009, 10:23 PM   #244
FnLow69
FnLow69's Avatar
Well i got the canti arms mounted today, now im just waiting on my heims to come in which is suppose to be tomorrow. im in the progress of figuring out a clean way to mount the bags. when the bags are in place and deflatted they will be flat and level.
Anyways heres the pictures.
Justin
Old 12-29-2009, 10:30 PM   #245
LooseCannon
Nice work. Keep at it.
LooseCannon is offline   Reply With Quote
Old 12-29-2009, 11:12 PM   #246
VA72C10
VA72C10
VA72C10's Avatar
Looking great...love the dash and canti setup
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-29-2009, 11:40 PM   #247
Inverter
Inverter's Avatar
They look B/A!
Im surprised your attaching the axle end,inboard the frame.Wont that make for excess body roll?
TROY
Old 12-30-2009, 12:20 AM   #248
FnLow69
FnLow69's Avatar
Originally Posted by Inverter View Post
They look B/A!
thank, i hope i wont have excessive body roll. there not much room to mount them outboard the frame, ive seen a couple setup this was so i hope it will work. Maybe nate will see this and give me some tips...
Justin
Old 12-30-2009, 12:11 PM   #249
Inverter
Inverter's Avatar
Theres no question it will work,I was just thinking you were going to run the arms parallel w/the axle tube w/the link bars reaching over the frame. I think 1badsvt has that kind of setup,,dont remember exactly.
Im not a suspension guru,by any stretch,I just know that its best to attach the load supporting links as far out as possible so the transfer of weight isnt accentuated as the vehicle turns.I almost sound like I know what Im saying
TROY
Old 12-30-2009, 12:47 PM   #250
FnLow69
FnLow69's Avatar
ya that was the oringinal plan but theres not much room, i might try something else today but will see. Nates going to call me so ill wait to hear what he says.
