Old 05-20-2010, 11:40 PM   #226
SCOTI
SCOTI's Avatar
Re: Project: Recycle
Originally Posted by aggie91 View Post
That is my same issue with the fawn color at this point. I will continue to look for a vinyl that is a good match before I change my direction...
Original stuff might be available from SMS but the price for the OE fabrics is getting on up there. I got enough material to do the 3 buckets w/some left over for the visors & a sub box for less than a c-note.
Ken, the entire interior is getting color. It's mostly stripped down; still need to gut the dash (tomorrow).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-21-2010, 02:22 PM   #227
aggie91
I'm just glad to be here!
aggie91's Avatar
I most likely will not use an "original" material because of the cost. Once I get a panel painted, I will go down to the local upholstry shop and look thru his stacks of samples and find one that is close enough...
I can't wait to see your interior color and the seats...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-21-2010, 03:29 PM   #228
SCOTI
SCOTI's Avatar
I'm doing the same thing only sdrawkcab.... I bought material I liked based on color, grain texture, & durability. I'll match the paint to the material so it's about as close as it can get. I put pics of the seat on a thread here before but the search didn't turn anything up (the pics are on my home computer).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-24-2010, 12:11 PM   #229
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
neat project.
I missed what the bed floor was out of , what is it from?
Old 05-24-2010, 12:15 PM   #230
SCOTI
SCOTI's Avatar
Originally Posted by jonzcustomshop View Post
neat project.
67-72; raised 6".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-27-2010, 11:30 PM   #231
SCOTI
SCOTI's Avatar
Progess..... but no pics (gulp). The interior is in primer & blocking has started. I purchased some heater delete plates for the engine compartment (Vintage air or nothing....).
I brought the gauge cluster home to get some creative juices going. Leave it as is.... retro-fit something different..... aftermarket (nostalgic) . . .... choices to be made.
I also picked up the majority (all??) of the 're-assembly' hardware for the chassis. Still have alot to go but moving along regardless!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 09:03 AM   #232
N2TRUX
Happy to be here
N2TRUX's Avatar
Sorry bro, post pics or it didn't happen. Lets look at your cluster so we can offer advice to confuse you even more.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-28-2010, 11:05 AM   #233
SCOTI
SCOTI's Avatar
Originally Posted by N2TRUX View Post
....Lets look at your cluster so we can offer advice to confuse you even more.
Retro fit = warning lights to 'gauges' or this to this . . ...
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 11:06 AM   #234
SCOTI
SCOTI's Avatar
Or, aftermarket . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 11:40 AM   #235
Jonboy
Slots go on anything!
I would retrofit the gauges, and source an old Sun tach and air gauge. That would fit the theme the best to me.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-28-2010, 11:59 AM   #236
ol_skool_chevy
ol_skool_chevy's Avatar
I like the aftermarket but its too but you can't utilize that space below where your key, light, wiper switches were before....I always wanted to cut that section out and open it up more. and mount my key , light, wiper swtches lower.
I like the clean look...
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 05-28-2010, 12:03 PM   #237
SCOTI
SCOTI's Avatar
Gauges for bags are tucked away, out of sight. I was looking to do the OE style in dash air gauge just for the 'rare' factor & use it for the tank pressure.
Because of the cost factor (300+) for 'restored' OE style gauges w/a re-pop tach, it's a harder decision w/brand new gauges (speedo, tach, oil psi, h2o temp, fuel level, & volts) coming in @ about $400 & change. Less than $100 difference in price but the OE look uses 45yr old gauges vs. the aftermarket units being new....
I'm just not a fan of tachs on the column. I prefer everything to match.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 12:05 PM   #238
SCOTI
SCOTI's Avatar
That's just a random pic to show possible gauge layout. Mine would be gauges w/a 60's look, in a tweaked OE bezel, w/the standard OE switches & knobs in place.
I absolutely would not use the Autometer style gauges for this build.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 02:23 PM   #239
aggie91
aggie91's Avatar
I really like the guages vs. the lights. That factory clock dash gets my vote...but I do see your point with the cost of new aftermarket gauges...
I think that I am going to keep my stock idiot light dash in mine, shooting for a no frills look on the interior...but with the updates like yours hidden (air management, a/c, stereo..etc).
Karl
The LST Challenge:
Old 05-28-2010, 02:52 PM   #240
SCOTI
SCOTI's Avatar
I do like that 'gauge' dash in the posted pic..... but I'm not a fan of clocks used to fill gauge spots. That's why I've been looking for the air pressure gauge. The only air-press gauge I've found is cost prohibitive which sways the decision making toward brand new aftermarket gauges.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 05:20 PM   #241
aggie91
aggie91's Avatar
A dash done with the SW gauge you picture would be very cool too. Just no billet for the panel to mount them in. An aluminum panel that was PC with a satin black or black wrnkle finish would look good.
Karl
The LST Challenge:
Old 05-28-2010, 05:30 PM   #242
SCOTI
SCOTI's Avatar
Stock panel that's modified is the intent.
I dislike the billet gauge panels that are commonly offered. There is one that I 'kind-of' like, but even it would require tweaking to fit my taste (I don't care for shiny/blingy stuff in the interior). Considering the price of the one I semi like, & then it still needs those tweaks.... I'll tweak the OE piece & still look good for ~$200 less.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2010, 11:21 PM   #243
bubba327
HOW long until spring??
bubba327's Avatar
I was just thinking the same thing . ..What to do with the holes if you moved the key and switches and lighter down ...or somewhere else ..I thought of maybe under the dash or in the space behind the ashtray (hinge the door)
Scoti -I had not thought of a insert panel with angle bend forward to hide the holes I just had seen the flat insert plate. Thanks for the idea ......
I saw a dash plate made from stainless plate from a commercial entry door (Toe kick plate). It was really shiny looked nice and I bet it could blind a driver if the sun hit it just right..
There was a white powder coated insert shown here on the forum a while back that looked OK I suppose you could powder coat just about any color or paint/ pinstripe /flame ETC around the gauges...
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 06-01-2010, 11:39 PM   #244
SCOTI
SCOTI's Avatar
Well, I was down for the count this weekend w/my neck locked up & immobile (slept wrong & it went downhill quickly from there). So I did only minor stuff playing around w/the gauge layout. Looks like the cost effectiveness of new gauges trumps the 'cool' factor of originals.
I went by my buddies place today to check out the color on the interior. I'm very happy w/the results! It dawned on me today that the color is very close to 'silly putty'. There's still a little more to go but it's definitely moving @ a good pace. Working on getting the glass locally & still investigating seals (glass & doors; weatherstripping/felts/window channels) as I would like to get everything high quality from one source.
Couple of pics sent to me....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2010, 11:43 PM   #245
joe231
joe231's Avatar
Nice!!!
CHEVY ONLY
Old 06-02-2010, 12:04 AM   #246
lolife99
67-72 parts collector,…
lolife99's Avatar
SCOTI,... let me know what you find out on "quality" windhield gaskets. (brand)
I need a set for my '70 stepside.
Keith
Convert to disc brakes.
Old 06-03-2010, 01:24 PM   #247
98L150
///Relaxed Atmosphere
98L150's Avatar
here is a pics of my gauge cluster for reference. got the panel from an advertiser in Goodguys and put in my Mooneye gauges
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 06-03-2010, 02:06 PM   #248
SCOTI
SCOTI's Avatar
That's what I have laid out on my template. I started disecting the wiring groups so I can use some of the OE plugs & routing for 12v, lighting, & turn signals.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2010, 02:10 PM   #249
SCOTI
SCOTI's Avatar
General concensus is Precision Rubber or Steele Rubber products are the way to go. N2billet had issues w/the 'Soft Seal' brand gasket for his front glass.
The 2 different 'old school' glass guys I'm waiting on quotes from said they would only use one of the two I listed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2010, 02:19 PM   #250
8mpg
8mpg's Avatar
Im a fan of vintage style aftermarket gauges. I really like the Autometer Street rod gauge sets. I think I will be using the Antique beige gauges in my truck.
8mpg is offline   Reply With Quote
