07-09-2011, 03:12 AM | #226 |
Re: 72 Suburban Build
Great to hear you'll be out this way in October, this is one I want to see in real life.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
07-09-2011, 08:14 AM | #227 |
I don`t know, I`d be more scared if the wires were all the same color.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
07-09-2011, 09:50 AM | #228 |
Restoration Virgin!
So THAT's where the brake booster and MC are when I see a smooth firewall looking good Chief!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-09-2011, 01:00 PM | #229 |
New home for the master cylinder reservoir.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
07-09-2011, 01:29 PM | #230 | |
low n' slo
man that looks nice..im in the process of shaving mine too
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
07-09-2011, 03:02 PM | #231 |
07-09-2011, 03:06 PM | #232 |
looking sweet brother, keep up the good work
07-09-2011, 06:07 PM | #233 |
Looks good - hard to reach? How about a custom flip open panel on the inside driver fender (you have excellent skills so just throwing that out there).
07-09-2011, 06:11 PM | #234 |
Great idea...however, it needs to be higher than the top of the master cylinder in order for that pesky gravity thing to work.
07-09-2011, 07:16 PM | #235 |
And we're SMOOTH!!! I have a tiny bit more sanding to do and it won't be 100% done until I get my new swivel ball column mount but it looks good now.
07-09-2011, 07:56 PM | #236 |
nice!!!!!!!!!!
07-09-2011, 08:42 PM | #237 |
67-72 parts collector,…
VERY NICE!
Where will the brake lines exit the inside of the cab/body? I assume you have bulkhead fitting for this? Love your burb!
07-09-2011, 09:19 PM | #238 |
Thanks! I have a bulkhead but I'm still trying to figure out if/where I'm going to put it.
07-09-2011, 10:18 PM | #239 |
sweet
07-09-2011, 10:44 PM | #240 |
67cheby
looking good man
07-10-2011, 07:08 PM | #241 |
"something witty here"
Have you checked the hood clearance on that res? it looks close...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
07-10-2011, 07:14 PM | #242 |
I'll modify as needed. I've got bigger problems than that right now...
07-10-2011, 07:43 PM | #243 |
Finished up the firewall (until my column gets here). I was going to get the drive train in but it doesn't look like that's going to happen. I don't think the motor mounts I was given will work. If its not one thing its 20 f-in others.
07-10-2011, 08:24 PM | #244 |
PROJECT 7DEUCE
I'm pretty sure that remote reservoir is gonna crash with the hood but I could be wrong? You may be able to notch the hood for it to clear as far as the motor goes it don't look like its anywhere even close to fitting.. Is the oil pan sitting on the rack? I'm assuming you do not have the trans cross member in and its no where near close enough to bolt up,but I could be wrong.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 07-10-2011 at 08:25 PM. Reason: added to.... cant spell.. |
07-10-2011, 08:39 PM | #245 | |
As far as the pan goes, I can slide a piece of paper between it and the rack right now. I don't have the tranny cross member in yet. Was going to going to try to do that today but ran into a big problem. After emailing Nate back and forth for the last hour or so, he thinks I have a SBC drop member. He has a jig made up (its happened before) to Fab up some different motor mounts .
07-10-2011, 08:52 PM | #246 |
PROJECT 7DEUCE
Damn hope nate fixes you up right..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-10-2011, 09:00 PM | #247 |
Sucks man. Always something ain't it. Mistakes happen but still sucks, you should be driving this baby by now. Hey it's only time and money right. Lol
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
07-10-2011, 09:02 PM | #248 |
I have NO DOUBT that Nate will whip up some new mounts in no time! He always takes care of me.
07-10-2011, 09:09 PM | #249 |
I have had all KINDS of issues with parts man! I am curious, does everyone have this many issues or am I just "lucky"?
07-10-2011, 09:19 PM | #250 |
Id say youve been getting the crap end of the stick if ya know what I mean? I hope for your sanity that nothing more arises lol
