Old 11-30-2014, 12:44 AM   #226
ghettoluxury
ghettoluxury's Avatar
Re: Loadmaster '47 COE
Looking good, Rob.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-30-2014, 12:55 PM   #227
Advanced Design
Advanced Design's Avatar
Good progress Rob, thank you for sharing.
Advanced Design is offline   Reply With Quote
Old 12-01-2014, 09:44 PM   #228
47 Fasttoys
47 Fasttoys's Avatar
Got a good start on rotating the rack. To start with I welded a position reference to the frame. In my case I used some angle iron with one end butted on a step on the rack tube and a couple of hose clamps. By doing it this way I could turn the rack but still maintain the correct position for alignment issues. Next I removed the mounting bolts, loosened the hose clamps and rotated the rack. I ran into 2 minor issues: The cap bolt on the rack would hit the frame cross member and the hose would hit the cross member. Used a hole saw to solve #1 and a hot wrench and a big hammer to solve #2. After I had enough rotation, I just started building up a new mount for the rack (3/16 plate). If you do this type of work I recommend a profile gauge. It really helps when making templates. I first make cardboard templates. I have also found that Natural Lite 12 packs make the best template materiel. Sometimes I have friends over and we work on building up template stock. From there I go from cardboard to steel and weld it all up.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-01-2014, 10:10 PM   #229
99 to Life
99 to Life's Avatar
keep chipping away, looks good
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-01-2014, 11:16 PM   #230
reaper71
reaper71's Avatar
looks good!!! One more off the list?
reaper71 is offline   Reply With Quote
Old 12-02-2014, 10:14 PM   #231
47 Fasttoys
Boy, you have to stay busy to keep anywhere near the top of this forum. Did a little more work on the steering, I still need to build the right side rack (ran out of steel) but I did hook up a U joint and all looks good. I also added a high tech turn signal switch. I'm trying to keep the interior simple with not a lot of bells and whistles showing.
Rob
My '47 C.O.E build
Old 12-02-2014, 10:21 PM   #232
Kim57
Kim57's Avatar
You're doing a nice job on it.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-07-2014, 07:39 AM   #233
47 Fasttoys
Thanks Kim. I did a little work on the rear of the cab. I bent and welded in place a brace for across the rear, I also cut the opening above the engine a little higher for clearance. Later I test fit the the radiator and modified the PS/Alt. mounting bracket to remove the Alt. mount.
Rob
My '47 C.O.E build
Old 12-07-2014, 06:16 PM   #234
mud.man.rj
mud.man.rj's Avatar
So many different things to address compared to a normal truck, nice work, coming along very nice.
mud.man.rj is offline   Reply With Quote
Old 12-07-2014, 07:18 PM   #235
47 Fasttoys
You are correct about that Mud, seems like just about everything needs addressed in one way or the other.
Made a little more progress rear of the cab: boxed in the sides and built a cover for the rear section. Now for the bad news: I think my welder is taking a dump. It tripped a few times today, the weld is fine but it just won't run for any amount of time and takes longer and longer to reset. I guess I really can't complain, I gotten 10+ years and 4 complete builds out of it.
Rob
My '47 C.O.E build
Old 12-09-2014, 06:26 AM   #236
47 Fasttoys
Well I bit the the bullet and bought a new welder. It turns out I bought my Lincoln 135 MIG back in '98 so I would say I got my use out of it. I bought a Hobart Handler 190 Amp. The reviews where good and I wanted some more power so this unit should do the trick.
Photobucket started working again also here are some picks.
Rob
My '47 C.O.E build
Old 12-09-2014, 10:36 AM   #237
reaper71
reaper71's Avatar
Looking good Rob!!
New toy are always fun!!
Old 12-09-2014, 11:52 AM   #238
99 to Life
99 to Life's Avatar
nice progress. You'll love the hobart.
Old 12-09-2014, 04:17 PM   #239
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work, it's looking awesome!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-09-2014, 05:20 PM   #240
Advanced Design
Looking really good Rob!
Enjoy the new welder.
Old 12-24-2014, 08:45 PM   #241
47 Fasttoys
OK, a little more progress. I picked a pair of Ford Taurus radiator fans. These are the widest I could fit and still get inside the frame rails. I built a shroud from 16 ga. and a mount from square tubing. It looks like I will be able to reuse the stock donor hoses with a little trimming.
My '47 C.O.E build
Old 12-25-2014, 02:28 AM   #242
Kim57
Kim57's Avatar
Nice job.
Kim
My build thread
Old 12-25-2014, 11:25 AM   #243
reaper71
reaper71's Avatar
Fit's really nice!!
Old 12-25-2014, 06:21 PM   #244
mud.man.rj
mud.man.rj's Avatar
Nice build on the fans and shroud.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
Old 12-25-2014, 11:24 PM   #245
99 to Life
99 to Life's Avatar
that came out really good. One of the last things on my list is def a fan shroud, not necessarily just for cooling but something to mount my fan to and tie my rad support together.
Old 12-30-2014, 06:29 PM   #246
47 Fasttoys
A little more progress on the cooling system. I am reusing the overflow tank from the donor. I welded a couple of pieces of 1/2" tube to the fire wall and mounted the tank there. I also ran the lines back to the engine and reused the original system as far as the tank is concerned. for the donor it uses the overflow tank as a pressurized unit with a 16# cap on it. The idea here is to be able to check the fluids under the hood with the exception on the oil and trans fluid which will be accessed behind the cab. I will build a cover for the brake linkage later. I remounted the front sheet metal and will start to work out the support for that.
Rob
My '47 C.O.E build
Old 12-30-2014, 09:01 PM   #247
Advanced Design
The firewall looks really good! Clean and organized.
Old 12-30-2014, 09:36 PM   #248
47 Fasttoys
Thanks AD, I also ordered a Painless wiring kit and will be mounting the electronics behind the seat. Lets see here: ECU for engine, TAC module, fuse box, relays (fans, fuel pump, horn), control circuit board for the shifter. What am I missing?
Rob
My '47 C.O.E build
Old 12-30-2014, 10:35 PM   #249
Advanced Design
For engine start / controls....Battery cables?
Old 12-30-2014, 11:13 PM   #250
mud.man.rj
mud.man.rj's Avatar
I must say, every step on that build is a stop and think about it step, not a usual build at all, so considering that, beautifully thought out, each and evry part. Must be time consuming and head scratching too.
5.0 4spd std.
7" lift w 35's.
