05-25-2015, 11:59 PM | #226 | |
Re: A different approach to a LWB to SWB conversion
Is this something a qualified body man would find easy.? Do you guys just bang it in line with a hammer and dolly of some sort.? I'm planning on doing the frame cutting myself and to get a mobile welder to come by and weld my frame. And I'm looking for a bodyman to do the bedsides for me. So I'm just learning how it is done so I can find someone that knows what they are doing. Really nice work here by the way.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
05-26-2015, 12:42 AM | #227 |
Ok I'll be brave and ask, what exactly is a falling body line anyway, is this where the body protrudes outward about 4" below the top of the bed rails?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-26-2015, 09:10 AM | #228 |
I think it looks nice. When I did mine, I was concerned about the falling body line also (Swamp Rat, if you look at the upper body line on the bed it actually tapers down at the rear) but after reading one of the other tutorials, I did the screwdriver trick of prying the bed out a little to match the seams, it worked perfectly and you can't tell there was a difference in the drop since the outer skin is so flexible.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
05-26-2015, 11:23 AM | #229 |
Amazing work, certainly an inspiration to the rest of us. Thanks for sharing.
Posted via Mobile Device |
05-26-2015, 09:15 PM | #230 |
6>8 Plugless........
Great work on the side markers and the bed over all! How's your COE project going anyway?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-26-2015, 10:51 PM | #231 |
Insane skill!
05-27-2015, 12:12 AM | #232 |
I knew there had to be a different method than the traditional cut, butt and weld. I have a SWB box that has the most trashed bedsides you've ever seen and a pair of LWB sides that are near perfect I'm gonna give this a try. Thanks for sharing.
05-27-2015, 12:15 AM | #233 | |
06-14-2015, 12:24 AM | #234 |
67-72 parts collector,…
Anything new?
Bumping this thread to the top,...
06-14-2015, 01:48 AM | #235 | |
If you look at the bedside in the last pic above, note that the horizontal bodyline isn't parallel with the the top of the bed, but falling (quote) at the rear. Great thread. If the OP wants to drop by N. TX and do my rockers and cab corners, I'm all ears |
06-14-2015, 02:32 AM | #236 |
WTF?!
I'm always amazed when I log into this site!!!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
06-14-2015, 10:24 AM | #237 |
Any new updates? |
06-14-2015, 06:44 PM | #238 |
I've changed out the dash harness, turn signal switch, and fixed the messed up heater system. I'm just waiting on a new cigarette lighter, drive shaft support bearing, and back up light switch. Then everything will be working 100% and ready for the state police to inspect it.
Oh, and I changed out the gold bow ties on the caps to blue Boeing ties. I wanted the caps more period correct.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker Last edited by 65standard; 06-14-2015 at 06:59 PM. |
06-14-2015, 08:07 PM | #239 |
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-14-2015, 08:26 PM | #240 |
amazing work..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
06-14-2015, 08:31 PM | #241 |
Seriously, awesome work.
Great before and after shot to. |
06-14-2015, 10:08 PM | #242 |
awesome fab skills!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
06-14-2015, 11:32 PM | #243 |
Before and after shots are amazing! Great work Tony
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
06-15-2015, 10:41 AM | #244 |
looks great! I really wish you could do mine next!
06-17-2015, 12:30 PM | #245 |
Great job on shorting the bed. The side marker mold wow!
check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=659403
vehicle's I own 1968 gmc 3/4 ton camper special 1972 gmc jimmy 1972 Chevrolet nova 1947 ford 1.5 ton dully 1997 f-350 1 ton 2007 Chrysler 300 with hemi |
06-17-2015, 04:45 PM | #246 |
Still Learning
Awesome metal work! I always wondered if it was possible to do that type of cut at the front
06-17-2015, 04:55 PM | #247 |
Love the before and afters. The first pic the trees are bare and there's dead leaves and twigs all over the driveway, and then the second BAM! leaves on the trees and nice green grass.
In all seriousness; what a fun build to watch.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord......... |
10-22-2015, 02:13 PM | #248 |
Under Construction
very nice, thanks for documenting your steps...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
10-22-2015, 03:52 PM | #249 |
beautiful and seamless work. I plan on making a die myself for other projects.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
10-22-2015, 10:12 PM | #250 |
Did you get things worked out at the BMV?
