Old 09-04-2016, 12:33 PM   #226
riddinlow99
Re: 67 C10 "Green Gobblin" straight from the field!
just went through the whole post. man you were in the same boat as me with all the rust. I'm doing a 70 bagged laying frame and rockers. anyway keep it up looks like your doing a great job Im sure some time ill see ya at a truck show.
riddinlow99 is offline   Reply With Quote
Old 09-04-2016, 12:38 PM   #227
TrshTrk
TrshTrk's Avatar
Seeing updates on your truck makes me want to get over to the garage and get some work done.
Trash Truck
69 GMC
TrshTrk is offline   Reply With Quote
Old 09-08-2016, 09:37 PM   #228
6t9camaro
6t9camaro's Avatar
Ok so my little helper and I dug back in and tore down the front end so I could get the lower control arms out and cupped. Once again I have a lot of pics incase someone wants to do the same.
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 09-08-2016, 09:44 PM   #229
6t9camaro
6t9camaro's Avatar
Cutting and fitting the rings, I cut slowly alternating between control arms as to not warp them.
Build
67 Green Gobblin
Old 09-08-2016, 09:46 PM   #230
6t9camaro
6t9camaro's Avatar
Fitting the bags and setting the angle of the cups
Build
67 Green Gobblin
Old 09-08-2016, 09:50 PM   #231
6t9camaro
6t9camaro's Avatar
Once their set time to weld them up!
Build
67 Green Gobblin
Old 09-08-2016, 09:54 PM   #232
6t9camaro
6t9camaro's Avatar
And just like that the bags in and the control arm can still go up enough to hit the crossmember! LOL
Build
67 Green Gobblin
Old 09-09-2016, 09:51 PM   #233
toms68cst
toms68cst's Avatar
Hello from another North Dakotan! (Bismarck)
I got a great kick out of all the pictures with the kids. I have a Boy and Girl who were about the same age as yours when I first got my truck. We have a lot of great memories. They are grown and in college now.
I am in awe of all your cutting/welding skills. If I ever get the shop/skills/time etc to do a restoration, I'd take it along the same lines as your are. I love the old patina look you are going after.
Where are you from? I am getting a Red River valley vibe from the pictures.
Tom.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 09-10-2016, 09:35 AM   #234
6t9camaro
6t9camaro's Avatar
Tom.
Thanks toms68cst
I try and get the kids involved in this project as much as possible! I've had cars in the past where i couldn't let them go near it in case of a scratch! But not on this patina project and thats a big part of why I'm building this truck this way. Your right on with your red river valley vibe! lol
Build
67 Green Gobblin
Old 09-10-2016, 10:19 AM   #235
6t9camaro
6t9camaro's Avatar
So once the lowers were back in i had some ball joint binding at full drop. So even though this truck will probably never go this low due to the tire hitting the fender I still wanted to get max drop!
Build
67 Green Gobblin
Old 09-10-2016, 10:37 AM   #236
6t9camaro
6t9camaro's Avatar
I decided on the lower arm Caster mod to get a better positive angle and also reduce some of the negative camber once dropped. I took out and moved the ball joint in 1/2" and moved it forward until I had 5deg of positive Caster. I also took out some ball joint angle (10deg) so they wouldn't bind when slammed. You can see in the pics the difference between the two since I compared and did them one at a time.
Build
67 Green Gobblin
Old 09-10-2016, 10:42 AM   #237
6t9camaro
6t9camaro's Avatar
Before and after 10 deg angle out. I put new ball joints and cross shafts in and a coat of por 15 on them. Even had my daughter come out to help clean them after. (she wanted to use the vacuum???) lol
Old 09-10-2016, 11:47 AM   #238
jlsanborn
jlsanborn's Avatar
Great looking work!!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-10-2016, 08:39 PM   #239
garmar
garmar's Avatar
Nice project! Following.
garmar is offline   Reply With Quote
Old 09-10-2016, 11:25 PM   #240
6t9camaro
6t9camaro's Avatar
I had to finish up the upper arms to match the lowers so I took out the same degree by putting a slice into them and bending them down. It worked pretty good now I can drop the front right down onto the control arms with no binding!
Build
67 Green Gobblin
Old 09-10-2016, 11:33 PM   #241
6t9camaro
6t9camaro's Avatar
First pic is with a 1" block holding the suspension up (mock up bump stop) and the 2nd 3rd pics are front on the ground! Last pic is a-arms welded up, new ball joints, cross shafts,tie rod ends to see how it all fits!
Build
67 Green Gobblin
Old 09-11-2016, 12:07 AM   #242
Aus69c20
Aus69c20's Avatar
Great progress.
I love seeing the work that goes into making these trucks sit low.
Are the cups in the lwr control arms necessary for an airbag install or purely to get the truck as low as possible?
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 09-11-2016, 08:46 AM   #243
6t9camaro
6t9camaro's Avatar
Thanks Aus69c20
The cups are just to get a extra few inches of drop. Most airbag kits come with a flat plate that sits on the control arm for the bag to rest on or aftermarket arms have that drop built into them.
Old 09-11-2016, 01:52 PM   #244
Advanced Design
Advanced Design's Avatar
Great build! I enjoyed catching up and will tag along for the rest.
Advanced Design is offline   Reply With Quote
Old 09-11-2016, 05:50 PM   #245
Aus69c20
Aus69c20's Avatar
Thanks for taking the time to answer 6t9.
John
Old 09-15-2016, 10:41 PM   #246
6t9camaro
6t9camaro's Avatar
I have finally decided on the motor! After debating to just slap in my 350 (burn victim motor) or go modern and run a 5.3 or 6.0L I've decided to go old school 454! I'm seeing way to many ls conversions these days and i figured a old school short box big block would be cool! Ive been looking for all of the above motors for a little while now but nothing has really caught my eye until last week! A 1975 454/400 out of all things a 75 Chevelle! Owner says its got 80,xxx original miles ran great when pulled out car was sent to the shredder about 3 years ago etc etc....
It didn't really matter to me as it matched the patina look and was old school orange and was complete carb to pan! If it ran that would be a bonus since I'm going to go through it anyway. So i hopped in the truck drove 8hrs dropped it onto the trailer (nearly crushed my trailer) and drove the 8hrs back! Now that was a long day
Build
67 Green Gobblin
Old 09-16-2016, 11:59 AM   #247
jlsanborn
jlsanborn's Avatar
Awesome! We'll want full reports on the overhaul. Retro roller?
Old 09-16-2016, 03:37 PM   #248
Phill0406
Phill0406's Avatar
Man, just caught up on this thread from page 1. Absolutely amazing work, very inspiring. Builds like this are the reason i read this board.
Great work, will continue to follow.
Phill0406 is offline   Reply With Quote
Old 09-16-2016, 05:33 PM   #249
6t9camaro
6t9camaro's Avatar
Lol Yes i will keep you up to date on the overhaul! I thought about doing a Retro roller but I'm not sure i want to go that route? I might just match up a cam to my combo with a nice lope at idle and some good tire burning torque!?!?
Build
67 Green Gobblin
Old 09-16-2016, 05:35 PM   #250
6t9camaro
6t9camaro's Avatar
Right on and Thanks! I hope some pics/info can help somebody along the way! I know I've sure learnt a lot from these builds.
Build
67 Green Gobblin
