Closed Thread
Old 09-29-2016, 08:59 PM   #2501
Railroadman
Railroadman's Avatar
Re: What did you do to your truck today part III
Finished removing the doors from the Stahl utility body on my '66. Tomorrow they go for sandblasting, then the fun starts of fixing/replacing the rusted out areas. This one is not bad but some are a bit worse for the wear.
[IMG][/IMG]
Railroadman is offline
Old 09-30-2016, 05:46 PM   #2502
lowslow64
lowslow64's Avatar
Sprayed the firewall and frame with Raptor bed liner. Looks great and easy to spray.
lowslow64 is offline
Old 09-30-2016, 08:36 PM   #2503
RDrancher
RDrancher's Avatar
Drug this '64 out from it's resting place for the last 16 years. Amazingly enough, the tires were still aired up! I'll have it home this weekend.
Romans 10:9 - The Truth
RDrancher is offline
Old 10-02-2016, 12:18 AM   #2504
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Bottom of the cab in two coats of rust tough primer for temporary. Tomorrow the epoxy goes on.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 10-02-2016, 09:44 PM   #2505
forestb
forestb's Avatar
New seat belts and old seat. She is now ready to drive on the street after over a year.
forestb is offline
Old 10-03-2016, 08:44 AM   #2506
curvedglass
curvedglass's Avatar
reconnected my heater, general de-greasing and crud removal of the block, valve cover and side cover gasket replacement, cleaned up the ignition wires, and polished the air filter cover on the weber.
--Life looks better through a curved windshield--
curvedglass is offline
Old 10-03-2016, 09:34 AM   #2507
joesscamaro
That Raptor Liner looks good! I read good reviews on their product, but haven't gotten around to spraying the underside of my cab yet...and I've never seen any pictures of it in use.
joesscamaro is offline
Old 10-03-2016, 06:40 PM   #2508
coyn
Been getting everything pulled out of the dash and off the firewall. Now to start replacing sheet metal. Lots of work ahead.
coyn is offline
Old 10-09-2016, 09:47 PM   #2509
Jimal
Jimal's Avatar
https://www.youtube.com/watch?v=b_VGMx2-qoE
Something a little different.
Jimal is offline
Old 10-11-2016, 02:18 PM   #2510
66Submarine
66Submarine's Avatar
Why not me??? 50MPH on the straights? I'd have given them a real show!
Neat.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 10-11-2016, 05:27 PM   #2511
Jimal
Jimal's Avatar
Neat.
Yeah, the lap didn't include the long front straight, so I didn't have to worry about cooking the brakes in Big Bend. That being said, with the rudimentary safety equipment (old lap belts and not much else) I wasn't motivated to push it.
Jimal is offline
Old 10-16-2016, 09:32 AM   #2512
62 Barnfind
62 Barnfind's Avatar
Got the timing right and tested the overdrive trans to see if it works.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 10-16-2016, 11:57 AM   #2513
davbowen
davbowen's Avatar
LED lights in my shifter knob
davbowen is offline
Old 10-16-2016, 08:37 PM   #2514
testerdahl
Finally got time to get the glove box back together with a new insert.
Broke down and pulled off the back bumper. I realized the lights "issue" could likely be replaced with ATV or motorcycle lights. I'm going to work on finding them.
Also, needed the bumper off to pound out a dent in order for the rear driver wheel to have more clearance as well as attempt to get the top bolt off the rear shock. It has been "stubborn" so far.
testerdahl is offline
Old 10-17-2016, 07:51 AM   #2515
jb9281
jb9281's Avatar
Got my bedside stripes and letters hand painted today. Local sign shop painted them for me. They are metallic silver
jb9281 is offline
Old 10-20-2016, 09:27 PM   #2516
BEK&TBKinNC
Not today but Monday, pulled it out of its resting place for the last 9 years and brought home.
Bought it as a non runner, but got it running Wednesday evening.
Brian and Tina
1972 Chevy C10 Bella (sold)
1990 Suburban 4x4 B1GNA$TY (sold)
2008 GMC Sierra Crew 4wd dd
1965 C10 (Bervin)
BEK&TBKinNC is offline
Old 10-23-2016, 07:00 PM   #2517
coyn
Was finally able to get the cab off to do some rust repair today. I put some new cab supports in also. It's not much but it sure feels good to get some new parts welded in.
coyn is offline
Old 10-23-2016, 07:20 PM   #2518
62 Barnfind
Installed the power booster/ hydro clutch today. Still have to run the brake lines and linkage.
John Z
62 Barnfind
Old 10-24-2016, 09:49 AM   #2519
shp4man
shp4man's Avatar
Figured out that the aftermarket AM radio that was in the old truck when I got it actually works. It's so old, it was made in Japan, not China.
shp4man is offline
Old 10-24-2016, 12:02 PM   #2520
forestb
forestb's Avatar
I took the truck out for it's maiden voyage (sense it was painted). I have not driven it for over a year and a half. The doors rattled like crazy but I think that is because the whether stripping is falling off. The inside door handle also fell of but that is not a big deal.
Sorry no pictures.
forestb is offline
Old 10-27-2016, 11:07 AM   #2521
idbeast
my efforts![IMG]image hosting free no registration[/IMG]
20mb image hosting
idbeast is offline
Old 10-27-2016, 12:33 PM   #2522
shp4man
shp4man's Avatar
Figured out that Chevy designed the side mount spare to be movable depending on what access was needed to the bed. So I'm putting it back to where the spare fits in the indent on the fender.
Got that old box setup out of the bed. The thing is steel and heavy. Had to use my motorcycle jack to get that crap out of there.
shp4man is offline
Old 10-27-2016, 03:02 PM   #2523
AngryPirate
AngryPirate's Avatar
Man, I like that breather you have on there. Do you mind if I ask what it is and where you got it?
Also, it looks like you have a hydraulic clutch set up like my '60 GMC...what part did you use to set up your brakes and clutch?
Thanks!
AngryPirate is offline
Old 10-27-2016, 03:40 PM   #2524
The Rocknrod
Moderator
The Rocknrod's Avatar
62 Barnfind truck is awesome! Hope he answers where he got those.
I have seen air cleaners "Like" those also, I think Speedway http://www.speedwaymotors.com/Nostal...ner,34533.html
Mooneyes http://www.mooneyesusa.com/product-p/jehe9600c.htm
http://shop.kustomcarparts.com/Chrom...?categoryId=-1
http://shop.kustomcarparts.com/7-1-2...?categoryId=-1
The Rocknrod is offline
Old 10-28-2016, 11:44 AM   #2525
n8op
Trying to get first gear back in.-------------------actually just fixed a bad grease fitting and removed a broke manifold bolt.
n8op is offline
Closed Thread
