Closed Thread
Old 11-19-2016, 05:05 PM   #2551
LVPhotos
LVPhotos's Avatar
Re: What did you do to your truck today part III
Show n shine Las Vegas!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 11-19-2016, 10:13 PM   #2552
62 Barnfind
62 Barnfind's Avatar
Installed my chrome grill and front disc brakes.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 11-19-2016, 10:43 PM   #2553
Backpayne
Getting her nekkid to paint!
Backpayne is offline
Old 11-19-2016, 11:49 PM   #2554
DPowers
DPowers's Avatar
Installed the topper I picked up the other day.
DPowers is offline
Old 11-20-2016, 07:19 PM   #2555
coyn
It's doesn't look like much but to me it is a big step. I was able to finally get the inner rocker panel after getting the lower A & B pillars tack welded in. It's been a slow process with only being able to get a few hours a week to work on it.
coyn is offline
Old 11-20-2016, 08:28 PM   #2556
62 Barnfind
Installed the cluster and went on the first test drive. Found out the brakes won't hold pressure and the OD trans sis bad.
John Z
62 Barnfind
Old 11-21-2016, 05:32 PM   #2557
forestb
forestb's Avatar
Got my tail gait and grill letters on this weekend.
forestb is offline
Old 11-21-2016, 06:53 PM   #2558
Northwest Outlaw
Northwest Outlaw's Avatar
finally got the engine wiring done. used the Front Wire Harness and Engine Harness from www.ClassicParts.com and new spark plug wire kit from Jegs.
Video of installing the engine/trans last weekend: https://youtu.be/61QrMdg9BKE
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 11-26-2016, 10:18 PM   #2559
Lugnutz65
Lugnutz65's Avatar
Installed a 1974 PS box using the CaptainFab bracket.
Joined a safer 1974 telescoping lower steering rod to the upper steering column using a U-joint I bought on eBay. The U-joint has DD female connections with through bolts. My original 1965 steering shaft was shortened and the end milled to a DD shape. I also moved my steering wheel 3" closer to the dash for a more comfortable position. The inner and outer column sleeves were sectioned and re-welded to make things look more original.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 11-26-2016, 10:20 PM   #2560
Lugnutz65
Lugnutz65's Avatar
More pics.
Old 11-26-2016, 10:26 PM   #2561
Lugnutz65
Lugnutz65's Avatar
More.
Old 11-27-2016, 04:58 AM   #2562
phraza
phraza's Avatar
Half way through installing a set of gauges. Next free weekend I'll finish them off. Just need to plug in the oil pressure and the lights
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline
Old 12-14-2016, 11:11 AM   #2563
earl84
Installed these. I used to have some really rusty West Coast junior mirrors on, changed to smaller stock ones. Decided I didn't like the look nearly as much on my C20, and I couldn't see chit. Love these with the chevrons, but they still need a little tweaking and adjusting. Also, I have a lot of old holes to weld up. On to brake troubleshooting.
earl84 is offline
Old 12-17-2016, 04:28 PM   #2564
rvrfoot
Size:  65.0 KBtook my flatbed off
rvrfoot is offline
Old 12-30-2016, 12:32 AM   #2565
TJ's Chevy
TJ's Chevy's Avatar
Kinda throughout the week. Got the tank installed. Fuel pump and rest of the line routed this evening.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 12-30-2016, 01:00 PM   #2566
forestb
forestb's Avatar
Found out my transmission is trashed.
It has only barely started to slip.
forestb is offline
Old 01-02-2017, 11:44 AM   #2567
vin63
It's Better With Nitro
vin63's Avatar
I hung the rear bumper, gravel guards, and installed my master cut off switch and actuator rod...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 01-02-2017, 02:19 PM   #2568
oldies1938
Installed my bluetooth mic where the choke knob was.... i hollowed out a windshield wiper knob and added a piece of tubing to support the mic
oldies1938 is offline
Old 01-02-2017, 06:21 PM   #2569
64shortbox
64shortbox's Avatar
oldies1938,
That's pretty ingenious! Great job and thanks for sharing with pics. I'm definitely going to do this to my 64.
64shortbox is offline
Old 01-02-2017, 08:22 PM   #2570
Hugh in NC
Hugh in NC's Avatar
I touched up the paint behind the grill. I didn't like seeing the white and red thru the white grill. Painted with rattle can semi-flat.
Before photos:
During repaint:
After touch up:
Hugh in NC is offline
Old 01-05-2017, 08:38 PM   #2571
Northwest Outlaw
Got my engine fired up after the swap! was a inline6 250 (not sure why or where from) with an old 3 speed. put in a SBC 350 and th400 combo.
Engine Install:https://youtu.be/61QrMdg9BKE
Engine Starting: https://youtu.be/txtKBJ_lQXc
Old 01-09-2017, 01:27 AM   #2572
Kenfuzed
Kenfuzed's Avatar
Got around to swapping out my 6 lug axles for a new set of 5 lugs w/new drums. My new wheels will arrive this week.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline
Old 01-09-2017, 10:21 AM   #2573
coyn
Working on getting the cab floor replaced. Started on the passenger side and got a few pieces tacked in this weekend around family activities. Now on to the rest...
coyn is offline
Old 01-09-2017, 10:28 AM   #2574
aggie91
I'm just glad to be here!
aggie91's Avatar
I worked on setting up a new rear for my stepside.
Still have a bunch left to get it finished, but its a start...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 01-09-2017, 12:22 PM   #2575
rvrfoot
Size:  76.4 KB installed my led
rvrfoot is offline
Closed Thread
