Old 05-29-2016, 04:45 PM   #251
Speedbumpauto
Speedbumpauto's Avatar
Re: 55-57 one piece windows
I used Trique latches and a Brothers power kit. My build is a few years old but the Brothers kit works really well and had all the components I needed so I guess it's "fixed." The latch is a close fit but works, even on my chopped top.
Speedbumpauto is offline   Reply With Quote
Old 06-04-2016, 11:02 PM   #252
Az. Hank
Az. Hank's Avatar
I just read the whole thread and watched the vids. I cannot find a mention for the "channel" that you have to weld a 3" extension. Does anyone have a part number or a link?
Found the felt stuff...
http://stores.restorationspecialties.com/y630p-96/
http://stores.restorationspecialties.com/mr172x-96/
http://stores.restorationspecialties.com/ym54r-96/
Thanks Hank
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 06-04-2016, 11:07 PM   #253
Az. Hank
Az. Hank's Avatar
the one in this picture.
My 55 Build 55 C-4
Old 06-04-2016, 11:16 PM   #254
Az. Hank
Az. Hank's Avatar
Ooops. found it at Tuckers
http://www.tuckersparts.com/1955-195...nnel-Pair.html
My 55 Build 55 C-4
Old 06-04-2016, 11:19 PM   #255
dwcsr
Hollister Road Co.
dwcsr's Avatar
http://www.classicparts.com/1955-59-.../#.V1OaN5ErKM8
dwcsr is offline   Reply With Quote
Old 06-05-2016, 09:16 AM   #256
Az. Hank
Az. Hank's Avatar
Nice half the price^^^
Thanks Hank
My 55 Build 55 C-4
Old 06-05-2016, 02:41 PM   #257
Az. Hank
Az. Hank's Avatar
I went to order the PDF file on line at Kinko's and all I could seem to order was in a poster format and they wanted $43.00 so I went in and told them what I wanted and it only cost $3.30. Just wanted to let everyone know.
Thanks for this thread everyone.
My 55 Build 55 C-4
Old 06-05-2016, 02:44 PM   #258
Az. Hank
Az. Hank's Avatar
I also decided to go with power windows. It looks like you don't need that metal "C" channel as it comes with the kit.
http://www.black-ridge.com/el2000-su...-glass-kit.htm
My 55 Build 55 C-4
Old 06-06-2016, 08:14 AM   #259
Kim57
Kim57's Avatar
Would like to know how this kit works out.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-06-2016, 06:53 PM   #260
Az. Hank
Az. Hank's Avatar
Changed my mind on the regulators, I think I'm going to use Nu-Relic's. The reviews I've read have all been positive and they replace the old regulators lifetime warranty also.
My 55 Build 55 C-4
Old 12-31-2016, 12:40 PM   #261
Ferminator10956
Originally Posted by blackdiesel View Post
We put 1 peice glass in mine, dads, and gradpas trucks. No need to cut any extra holes in the door. I can send you a timplet for the glass if you like. and yes it's easier than rebiulding stock.
I been restoring my truck down in Monterrey Mexico. Do you still have that one piece window template available? Thanks. Fernando.
Ferminator10956 is offline   Reply With Quote
Old 12-31-2016, 12:56 PM   #262
dwcsr
Hollister Road Co.
dwcsr's Avatar
The file is here
http://www.thehollisterroadcompany.c...ecewindow.html
I don't have any install information, I only host the file
Old 12-31-2016, 01:01 PM   #263
Ferminator10956
Thank you! Very Appreciated!...
Old 12-31-2016, 07:28 PM   #264
OrrieG
OrrieG's Avatar
FWIW I used the template and made "glass" with of 1/4" tempered hardboard for mock up and fitting. Later I got a deal on some Brothers Glass another member did not need. The template and Brothers Glass are almost exactly the same, the small variance will be concealed by the U channel.
OrrieG is offline   Reply With Quote
Old 02-28-2017, 08:01 PM   #265
T-P Auto
blackdiesel;
I know it has been a few years since you posted about the one piece window info;
I just got a 57 chevy panel n want to do the one piece window set up.
Would like to have the temple n the DVD if you still have the info.
Thank You;
T-P Auto
Timothy Ponzer
P O Box 3451
Milan, N M 87021
T-P Auto is offline   Reply With Quote
Old 03-01-2017, 06:41 PM   #266
OrrieG
OrrieG's Avatar
[QUOTE=T-P Auto;7872833]blackdiesel;
Hollister has the files, scroll down in this thread about 4-5 replys.
Old 05-12-2017, 12:15 PM   #267
ptc
ptc's Avatar
Im doing this mod with the stock regulators for now, just need some roll up windows. maybe change to power later on.
Does anybody have any spare pieces for the window guide add on they'd like to share? Before I buy an entire new set for 6".... or if anybody else needs pieces we can buy one set and divy it up between all of us?
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 08-21-2017, 01:56 AM   #268
QBRacing
Sorry to rehash an old thread again but what better place than in this thread.
I am about to start this mod on my truck in NZ. Obviously its a bit harder down here with the lack of suppliers but I have a good exporter in LA which helps heaps.
I was looking at the extension needed to extend 3" for the channel run. I know its been linked above a number of times but is it the same part as #7 on this page from LMC.
I was going to be getting a few small parts (roof skin and visor) from them shortly and thought I might just add it at the same time......
Finally - the 3 links from restorationspecialies - Do I just need 1 of each piece to complete or multiples.
Q
QBRacing is offline   Reply With Quote
Old 08-21-2017, 08:17 AM   #269
idbeast
Q
I used restorationspecialies for the C Channel. You will need 2 one for each side.
On the other links you only need 1ea the last number of the part number is 96 meaning it is 96 inches long.
idbeast is offline   Reply With Quote
Old 08-22-2017, 01:06 AM   #270
QBRacing
Why did you use the http://stores.restorationspecialties.com/10-m-96/ rather than the http://stores.restorationspecialties.com/y630p-96/ as per the original parts lists.
Looking at the dimensions its a totally different size ???
Old 08-22-2017, 08:27 AM   #271
idbeast
Go to this page and start reading at post #7, it has pictures and explanations...
http://67-72chevytrucks.com/vboard/s...st#post7987617
Old 10-01-2017, 05:11 PM   #272
LDO
LDO's Avatar
idbeast,
sent you a pm.
LDO is offline   Reply With Quote
Old 10-19-2017, 12:28 PM   #273
ptc
ptc's Avatar
Originally Posted by oldcouple View Post
Ordered the replacement felts for my B robbers trucks kit yesterday from these guys, http://stores.restorationspecialties...Categories.bok, they shipped today, cost is $100 plus with shipping. I made my own track for the front its easy to do.
These guys are the best and they have everything you need for all your glass, interior, exterior, extrusions, seals, hard rubber, fasteners etc. needs.
Talked with Jeff, he knew exactly what I was doing - there are actually two different felts if you are cutting up and reusing the front division bar as your glass guide. He has all the stuff to make both tracks work RIGHT, no slop!
The best customer service Ive had!...... --- Brothers?
Old 10-19-2017, 10:44 PM   #274
Old57
Did you buy everything to do the 1 piece windows from them, or just the stuff you needed to make the brothers kit work?
My 57 GMC build
Old57 is offline   Reply With Quote
Old 10-22-2017, 07:46 PM   #275
clegg
I have a 1955 TF truck converted to one piece side glass. I used the Specialty Power Windows kit and the window run trim from Restoration Specialties part #10M-96-WIN. It requires 2 each. One for each side, these fit perfectly. They come in a long straight piece. You can pre shape them with the glass before it's installed.
The Specialty Power Windows kit comes with a template for the glass shape. The motors in the kit are fast and quiet running like my new Silverado. I have to still order the window felts that attach to the door openings horizontally.
Additionally, the Specialty Power Windows kit comes with the forward channels that fit down in the doors, switches and decent instructions to complete a one piece window project and was what I needed as my truck had no existing windows or regulators (you will have to source the glass).
clegg is offline   Reply With Quote
