Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-16-2009, 08:38 PM   #276
Rokcrln
Rokcrln's Avatar
Re: LFD's 4dr Tahoe Build
Here is todays progress. I hope to get the other side done Sunday then I can start on the lower door section.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-16-2009, 09:33 PM   #277
hotrodhomi
hotrodhomi's Avatar
looks good.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-16-2009, 10:32 PM   #278
Old 01-17-2009, 03:54 AM   #279
Frizzle Fry
Frizzle Fry's Avatar
Mine looked like that once upon a time ...until I decided to notch the frame and run 22's in the back
Looking good!
Frizzle Fry is offline   Reply With Quote
Old 01-17-2009, 09:25 AM   #280
Rokcrln
Rokcrln's Avatar
Mine will be staying this way even with the step notch and 22's. My mock up tires are 31" and I still have enough room, yours are what about 30"? Also as I build the rear 3 link wish bone set up I will be sliding the rear end further back to keep it centered up as right now they are just a tad forward. Now I may end up running a slight inner tub but the door opening should stay as is. Am I missing something? If so please chime in as I will be starting the other side on Sunday I have a Nor-Cal meet today to go to and dinner with my wife and friends for her Birthday.
Kevin
LFD Inc.
Old 01-17-2009, 09:53 AM   #281
MrBeast
high-Tech Red Neck
MrBeast's Avatar
So when are you installing the machine guns behind the headlights?
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 01-17-2009, 10:33 AM   #282
Rokcrln
Rokcrln's Avatar
Sorry thats not my style. The parts of Oakland I drive through you want those sucker sticking right out of the hood so they know you mean business!
Kevin
LFD Inc.
Old 01-17-2009, 01:23 PM   #283
hotrodhomi
hotrodhomi's Avatar
Kevin
LFD Inc.
I know what you mean. I have to go to Oakland before the meet today.
'66 impala ht
Old 01-17-2009, 11:08 PM   #284
Frizzle Fry
Mine are 31.6" overall (305/40/22). We took slightly different approaches to this so you may be fine. But it's amazing how quickly that space goes away when you get close to the ground (mine doesn't even lay frame). With a 2" longer wheelbase those tub protrusions will naturally be smaller.
Old 01-18-2009, 12:16 AM   #285
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Kevin
LFD Inc.
So a Hummer style turret then?
Old 01-18-2009, 01:37 AM   #286
Rokcrln
Rokcrln's Avatar
No doubt it will be close. I will use these tires for fitments and see how it goes. I sent a little something back home with Brad for you so make sure you hit him up!
Kevin
LFD Inc.
Old 01-18-2009, 02:16 PM   #287
Frizzle Fry
Hah, cool!
Old 01-18-2009, 03:31 PM   #288
Rokcrln
Rokcrln's Avatar
Slight change in plans for the new rocker area. I liked how it turned out but it just didn't flow right. It looked home made so I cut parts out and built some new parts today. Here is the new version.
Kevin
LFD Inc.
Old 01-18-2009, 03:35 PM   #289
Frizzle Fry
Definately better and allows you to have a curved door corner rather than squared off.
Old 01-18-2009, 04:09 PM   #290
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Yeah that looks better. As you said the roundness of it does flow better. Looking very sweet, you have got some of the best metal working skills i have seen. Daren
Daren
04 Chevy Extend cab 2500HD 6.0 Liter 4x4
71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY
Rip El Jay
RIP BOBBO'S MOM
88JRFAN is offline   Reply With Quote
Old 01-18-2009, 04:49 PM   #291
nuke1
nuke1's Avatar
looking good
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-18-2009, 04:59 PM   #292
38chevyhotrod
38chevyhotrod's Avatar
Yes it looks much better this way, I already thought that you would change it.
This is the only way it has to be, indeed great metal work.
I like every picture I see from you. you make it look so easy(I know that it isn't)
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 01-18-2009, 07:00 PM   #293
Rokcrln
Rokcrln's Avatar
Here are a few more progress pic's. I still have a few small pieces to fill in but you should get the idea. I first made the new inner corner piece then I cut a thin strip, curved it to fit the door edge then spot welded it to the inner piece and hemmed the door edge to the outer skin. It has a nice almost factory look now and it is very Strong.
Kevin
LFD Inc.
Old 01-18-2009, 07:24 PM   #294
PHAT TONY
PHAT TONY's Avatar
How many hours do you have in a day there? I work at home(doing what you're planning to do-restos&customs) and find it hard somedays to spend ANY time at all on my junk, never mind having 2 or 3 projects on the go!
PHAT TONY is offline   Reply With Quote
Old 02-01-2009, 11:48 PM   #295
Rokcrln
Rokcrln's Avatar
Well just an up date on the Hoe. I got it all DP90'd the other day and here it will sit until I build up my toy fund a bit. On a good note I sold my 70 2wd Blazer to Carter Hickman and with than money I will try and get the rest of my suspension so I can fill in the rear floor after the rear suspension is done and then drop in the 5.3/4L60E once the front is in. I also have a customer truck to get started on in the next few weeks, it is a 41 Chevy PU that will be getting a custom chassis built for it with IFS and IRS. That will also help fund this build.
Now just because I am out of money does not mean I am not out in the shop building cool stuff. I pulled my son's truck (51 F1 barn find) in the shop last week to put in it's suspension because the customer's truck will get the same set up and he wanted a ball park figure at what we are looking at so he can decide if paint is in the budget as well.
My son's truck was put in a barn in about 1962 and we bought it 2 yrs ago when we found out we were having our first kid. It WAS a completely stock truck with 46K on the ticker that was until last week. First thing I did was pull the front sheet metal, motor and trans and all the front suspension. Then I boxed the front frame and installed a TCI MII kit with tubular arms and air bags. I want this truck to drop into the weeds but still be able to drive the fair grounds this low. Then Saturday I pulled the bed and rear suspension to start on the IRS unit. For this I used a 95 T-Bird rear suspension set up because they are cheap, strong if you get the 8.8 unit and come wrapped in it's own sub frame making set up real easy. So here are a few pick for you guys that need your LFD fix.
Now I know it is not Chevy but this IRS unit would work out well in one of our trucks and here is a link to a How-To I did on it for another site.
http://www.ford-trucks.com/forums/81...ll-how-to.html
Kevin
LFD Inc.
Old 02-02-2009, 12:18 AM   #296
nuke1
nuke1's Avatar
Hey Kevin, that F**d is kick @$$ i do not care what others say but i am drooling!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 02-02-2009, 02:06 AM   #297
thelonerife
thelonerife's Avatar
That is a nice job on the ford. Keep your son interested. Mine lost interest in the 68 Camaro project and I sold it. Now I wish I would have kept it for myself. Good luck with it.
thelonerife is offline   Reply With Quote
Old 02-02-2009, 02:09 AM   #298
67ChevyRedneck
67ChevyRedneck's Avatar
Wow, what a clean truck and what a difference!
The rear suspension looks like it was made for the truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-02-2009, 05:27 PM   #299
BlueJeep
BlueJeep's Avatar
What's the width on that IRS, WMS - WMS? 5 on 4.5 pattern right? Thanks.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-02-2009, 06:37 PM   #300
kyull67
kyull67's Avatar
Looks good, Lucky son!
kyull67 is offline   Reply With Quote
