08-09-2013, 08:17 PM | #276 |
Re: DURG's Black 65 C10
Decided to just do a couple short 90 degree tips on the end of the exhaust dumps. Installed the Lokar shifter bracket and shifter. I am going to cut a new hole in the hump where the shifter is now which is behind the OG hole the standard 4 speed shifter came through. I will weld a flush patch there and use a Lokar billet round boot ring and black "leather" boot.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
08-09-2013, 08:52 PM | #277 |
looks good....is that the tranny mount style shifter?....how long is the handle?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
08-09-2013, 08:55 PM | #278 |
Yes. 16" I believe.
08-12-2013, 09:31 AM | #279 |
ok yeah i have to tag this thread, that truck is amazing
Aerodynamics are for people who can’t build engines. – Enzo Ferrari - 64 Chevy C10 SWB- 440 BBC, Pro touring build in progress SLOWLY - 73 Camaro LT RS- Pro touring build eventually - 71 Bronco- my dirt monkey and current focus The military doesn't pay nearly what it should |
08-12-2013, 10:38 AM | #280 |
killer lookin work man!!!
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
08-22-2013, 08:25 PM | #281 |
I did a few more things on the truck and then took it apart in anticipation of final welding, grinding, and re-sandblast so I can get some paint on the frame and gear up for final assembly. These pictures may not be in perfect order and possibly some of the same stuff I have posted before but I took some over the past week and today so I will post them anyway. I have installed the bracket that holds the gas pedal studs, cut a rectangular hole for a larger Lokar boot and ring, and installed a couple braces back from the driveshaft loop/cross member back to a plate on the inner frame where the 4 link front mount attaches. This cross member and brace is removable even though it should never need to be. I put a couple more pictures of the discontinued Porterbuilt hood hinge relocation brackets I attached my front bracing to also. I took a picture of a deluxe wheel installed on the Ididit column and also a small gusset I welded in where I notched the cross member support where I relieved it for steering column clearance.
08-22-2013, 08:27 PM | #282 |
08-22-2013, 08:32 PM | #283 |
Motor is out and everything is off the frame in front too. I just need to take out the 4 bolts and the cab will be off and I can move the frame around in finish prepping for black paint.
08-23-2013, 05:48 AM | #284 |
Great.clean work!
08-29-2013, 06:48 PM | #285 |
This thing is officially blown apart for final welding, grinding, blasting, and paint on the frame and suspension. Greg at Extreme Powder Coating has offered me a killer deal on powder for the suspension stuff but I think the shipping kills the deal. def going black on the frame for sure. Probably charcoalish gray on suspension stuff.
08-29-2013, 07:16 PM | #286 |
Rollin' Old Skool
Cool! Look forward to seeing it reassembled & looking purdy
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
08-30-2013, 09:14 AM | #287 |
Looks awesome! Are you still going to do more bracing in the middle of the frame or did you decide against it? I'm still trying to figure out what I'm going to do. We boxed the frame on my Father's 57 but that was all weld in stuff (fatman IFS, no limit 4 link). There are a lot of different opinions regarding boxing and/or bracing.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
08-30-2013, 10:04 AM | #288 | |
08-30-2013, 07:38 PM | #289 |
killer work man!!! the extra bracing looks awesome
08-31-2013, 11:22 AM | #290 |
08-31-2013, 12:22 PM | #291 |
Nice build. Look forward to seeing the end result.
09-01-2013, 10:40 AM | #292 |
09-01-2013, 11:49 AM | #293 |
67-72 parts collector,…
POR-15 or paint?
09-01-2013, 12:32 PM | #294 |
Rollin' Old Skool
09-01-2013, 12:35 PM | #295 |
It's gloss black paint. Tractor Supply has an equipment paint for tractors and stuff. I did use POR-15 on my Impala. Just figured this paint would be fine on the frame.
09-02-2013, 07:42 AM | #296 |
All your pics are gone, that sucks!
09-02-2013, 08:00 AM | #297 |
Yeah, I have so many pictures on here and Chevy Talk I exceeded my free bandwidth. I had to upgrade my Photobucket account. The pictures are back now.
09-02-2013, 10:24 AM | #298 |
09-03-2013, 04:27 AM | #299 |
Wow that looks fantastic!
09-03-2013, 03:31 PM | #300 |
Glad to see it looks that BLOODY GORGEOUS! I have a gallon of it with hardener on the shelf, just a-waitin'!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
