Old 01-16-2015, 05:53 PM   #276
47 Fasttoys
47 Fasttoys's Avatar
Re: Loadmaster '47 COE
Thanks all. The kits are 764-10120, 20 circuit trunk mount kit and 764-70920 Powerbraid Chassis kit. The Powerbraid kit came free on a Christmas sale. I bought them through Jegs.
In other good news I got the truck registered and tagged today. Yes, it's a bit early but with it registered I can get some free tires from work...Michelin.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-18-2015, 03:52 PM   #277
47 Fasttoys
More progress, I finished the majority of the engine wiring. I still need to build a mount for the alternator and an intake pipe for the MAF sensor so those are not finished. Not anything special looking on the engine wiring but that was the intent. I checked my records and I have 66 hours in the wiring so far not counting the electric shifter project. The sad thing is I still need to do the dash and the whole chassis. I also built the exhaust this morning. I used as much of the donor as I could and only ended up with $13.00 total in the exhaust, probably the cheapest thing I'll do on the whole build. Finished the rack and pinion mount.
Rob
My '47 C.O.E build
Old 01-19-2015, 10:58 AM   #278
reaper71
reaper71's Avatar
Looking good Sir!!!
reaper71 is offline   Reply With Quote
Old 01-19-2015, 07:46 PM   #279
Advanced Design
Advanced Design's Avatar
X2!...$13 exhaust is a great deal.
Advanced Design is offline   Reply With Quote
Old 01-23-2015, 06:44 PM   #280
47 Fasttoys
Well, no pictures today but I did build a mount for the alternator, received my ECU back from programming, and ordered some more parts.
Rob
My '47 C.O.E build
Old 01-28-2015, 07:00 PM   #281
47 Fasttoys
More progress, I built a alternator mount for the lower right side of the engine. I'm running the 4 rib belt normally used for the AC. I also built and installed a idler pulley for the main belt. After getting the new belt I was able to install both belts and adjust the tensions. Installed both PS hoses after I had a new pressure hose made. Started on the fuel lines, ran another hose for the coolant and installed a air filter/air pipe for the MAF sensor. The Air filter will end up end in a tool box mounted to the frame rail. The battery will be inside another tool box on the other rail.
Rob
My '47 C.O.E build
Old 01-28-2015, 10:36 PM   #282
99 to Life
99 to Life's Avatar
kicking ace man, lotta little details people will never know or understand how much work went into getting something like this done. nice work.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-28-2015, 10:46 PM   #283
mud.man.rj
mud.man.rj's Avatar
I bet on a project like that the amount of thinking and planning is equal to more work than the actual work itself.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-29-2015, 12:01 AM   #284
Advanced Design
Lotta work done! The tool boxes on the frame will be a neat touch.
Old 01-29-2015, 10:43 AM   #285
reaper71
reaper71's Avatar
Looking really good..
Old 02-02-2015, 08:49 PM   #286
47 Fasttoys
Dang, it looks like everyone has been making a lot of progress lately. I got pushed all the way to page 2. Well anyway, I started working on the wiring some more, I got the wires to the fire wall and traced out the needed wires for the tail lights. I'll be re-using the donor wires for the rear, also tested the tail lights I picked up while working in China ($8.00) big LED units so hopefully someone will not clip me in the rear.
Rob
My '47 C.O.E build
Old 02-02-2015, 09:28 PM   #287
Kim57
Kim57's Avatar
Looking real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-02-2015, 09:33 PM   #288
Advanced Design
Good progress on the wiring Rob. The tail lights look bright! Looks like they have back up lights too. Great deal for $8.
Old 02-07-2015, 07:30 PM   #289
47 Fasttoys
More progress: trans lines are done, fuels lines are done except for supports, ignition switch switch is wired and heater has been stripped and repainted. I'm still waiting on the core to be tested and the 12V motor to arrive. Seat belts arrived. Waiting on gauges (SpeedHut). I also scored a bumper today for $25, it had a small bend in one area but with a little heat and a hammer that came out. As it turns out, the 1 1/2 ton and up standard and the COE share the same bumper. Great news for me.
Rob
My '47 C.O.E build
Old 02-07-2015, 08:51 PM   #290
Advanced Design
Nice score on the bumper Rob. You are making great progress!
Old 02-07-2015, 10:12 PM   #291
47 Fasttoys
Thanks AD, I may try a first start tomorrow.
Rob
My '47 C.O.E build
Old 02-08-2015, 12:58 AM   #292
99 to Life
99 to Life's Avatar
nice score on that bumber. I believe I got that one on my 54' 6400. Even got two tow hooks on it. Man you better shoot some video on the first start up. I love the adrenalin of the first start. All the hard work and its either gonna be a really bad day or something spectacular, that suspense is truly living.
Old 02-08-2015, 08:28 PM   #293
47 Fasttoys
Baby got some new shoes (work perk). A look at the heater parts, I've had water in the core with no level drop for 24 hours so I'll call it good. Now for the third picture: that would be the remains of a mouse house. How did I find it? It came out of my tail pipe. That's right, my COE now runs. Video will follow later.
Rob
My '47 C.O.E build
Old 02-08-2015, 09:21 PM   #294
Advanced Design
Nice work perk! You must be a "Michelin Man"? Looking forward to the video and congratulations on the start.
Old 02-08-2015, 11:14 PM   #295
Kim57
Kim57's Avatar
Real nice.
Kim
My build thread
Old 02-09-2015, 10:46 AM   #296
66farmer
66farmer's Avatar
I have read through your thread, I like what you have done and where your going with the truck. Know for the question, I'm looking for a COE as well as a donor truck for my next project. If you had to do it over would you use the same donor and could you give me the wheel base of your donor.
66farmer is offline   Reply With Quote
Old 02-09-2015, 07:17 PM   #297
47 Fasttoys
Wheelbase is 143.5 (extended cab). Yes, I would use the same donor. Why? Drive by wire, correct track, easy steering hook up, strong aftermarket support (LS based engine) most donor parts are reusable with little of minor mods. on the down side: good donors are not cheep, 5K in my case. Only the 1/2 tons use the rack and pinion steering. Not a lot of examples to build from on the net so you need to figure out most of the mods on your own.
My '47 C.O.E build
Old 02-09-2015, 07:52 PM   #298
66farmer
66farmer's Avatar
Thanks for your input
How long of a bed will you end up with
Old 02-09-2015, 08:34 PM   #299
47 Fasttoys
OK so here is the video of my first start.
Rob
http://youtu.be/zpOcOlLyclY
My '47 C.O.E build
Old 02-09-2015, 08:39 PM   #300
47 Fasttoys
If I go from back of cab (with clearance) to bumper about 11'6". Because the cab is to the front it would look better if I run it out to 12 to 14 foot. At 12' I could put my Cobra on the back. Of course I would need come frame and suspension mods for the extra weight.
Rob
My '47 C.O.E build
