Old 05-02-2016, 12:42 AM   #276
tinydb84
tinydb84's Avatar
Re: Used Parts Build
Got the tank mocked up. Need to extend the frame a hair and build some mounts for the front.
David
Instagram: myfabguy
Old 05-04-2016, 12:56 AM   #277
tinydb84
tinydb84's Avatar
Took off early to get some work done. Took forever and didnt get much done....I hate drilling holes....
Extended my frame just a bit to fit my tank (bad pic)
The brackets moved in a bit when I was welding and made it difficult to get the link in and out without muscling it so I added a little piece inside at the right distance and welded it up.
Then spent forever with a hole saw.
David
Instagram: myfabguy
Old 05-04-2016, 08:07 AM   #278
daddyjeep
daddyjeep's Avatar
You did spend some quality time with your drill didn't you.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-04-2016, 08:30 AM   #279
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Well it's looking good.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 05-09-2016, 12:52 AM   #280
tinydb84
tinydb84's Avatar
Spent a whole lot more time with it today too!
Thanks man. Chipping away slowly....
Taking some measurements to narrow my rearend. Its 63.5'' from mounting face to mounting face. I have some mock up wheels but I am thinking of narrowing it 2 inches per side to give me more space.
Finish drilling out the other side.
My buddy down the street builds custom choppers for people as a side job. He stops by and points out **** I did wrong or what I should have done. He has a great eye for planning **** out. Just wish he'd stop by before I did ****..... Here is something he said I should have done.
David
Instagram: myfabguy
Old 05-09-2016, 03:03 AM   #281
ruffrida2005
Holess look good. But on your long watts bars why did you use what looks like 3-4 different sizes?
Paul
Old 05-09-2016, 12:54 PM   #282
daddyjeep
daddyjeep's Avatar
The holes definitely add some character. They are a little random for my OCD, but look good.
04 1500 crew cab
Old 05-09-2016, 01:05 PM   #283
tinydb84
tinydb84's Avatar
Was trying to follow he shape of the piece a bit.
I was too lazy to go buy a bunch of hole saws to match the shape as much as a should. (they need an emoji for lazy)
Tossed some paint on last night just to keep it from rusting.
David
Instagram: myfabguy
Old 05-11-2016, 02:15 AM   #284
tinydb84
tinydb84's Avatar
Went a bit OCD on my gas tank mount. Now I have to redo the front one to match....
Had to tack it outside while sitting on the ground, inverted, using my leg on the peddle.
Welding the sides on
Mounting tab
Probably not necessary but makes it look more finished.
Before and after!
Weld shot
David
Instagram: myfabguy
Old 05-11-2016, 12:56 PM   #285
daddyjeep
daddyjeep's Avatar
Way nicer than what I built for securing my tank. Now you're just showing off.
04 1500 crew cab
Old 05-15-2016, 11:14 PM   #286
tinydb84
tinydb84's Avatar
haha thanks. I got all ocd and redid the frount mount to match. They are a bit much but whatever.
And done!
David
Instagram: myfabguy
Old 05-23-2016, 03:02 PM   #287
tinydb84
tinydb84's Avatar
Been busy with life stuff. Spent some time reassembling my rear suspension after I painted the frame. Tossed the wheels on and laid it out. It actually has a bit lower to go but with the front end so high up the brackets in the rear will hit first. I need to buy the rotors, bearings, etc for the front to reassemble it.
David
Instagram: myfabguy
Old 05-25-2016, 01:51 AM   #288
tinydb84
tinydb84's Avatar
Installed my bags and cycled the rear suspension a few times. No video yet though.
Dragged my bed into my garage to start reassembling and figuring out the mounts. Man I need a bigger garage and a helping hand sometimes.
David
Instagram: myfabguy
Old 05-25-2016, 08:17 AM   #289
Joe Pass
Joe Pass's Avatar
Nice.....
Joe Pass is offline   Reply With Quote
Old 05-25-2016, 12:47 PM   #290
daddyjeep
daddyjeep's Avatar
Bring it over to my place, I have lots of room and a well stocked beer fridge. I'm only 4,000 miles away from you.
04 1500 crew cab
Old 05-25-2016, 06:44 PM   #291
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Just read your thread from the beginning. Awesome work! I enjoy seeing how your skills have progressed with the build. Keep up the good work!
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 05-26-2016, 10:31 AM   #292
aggie91
I'm just glad to be here!
aggie91's Avatar
I think I may have asked already, but did you swap the torch on that alpha TIG? if so, which torch did you go with?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-26-2016, 06:22 PM   #293
tinydb84
tinydb84's Avatar
If you were closer I would rent some space from you! AND I don't even like beer.
Mike
Thanks Mike. This is my learning project. I hope to have my skills much more fine tuned by the time I start on my 66.
I did replace the torch. It is a CK9 with the super flex hose. Very nice. You need an adaptor to use it though. Here are the links.
Torch: Amazon.com: CK CK9-12-RSF RG Torch Pkg 125A Gas... Amazon.com: CK CK9-12-RSF RG Torch Pkg 125A Gas...
Adaptor: CK SL2-35QD SafeLoc Male Dinse 35 (1/2")... CK SL2-35QD SafeLoc Male Dinse 35 (1/2")...
David
Instagram: myfabguy
Old 05-30-2016, 02:48 AM   #294
tinydb84
tinydb84's Avatar
Got a really good deal on some DLOE valves off instagram:
Got a new tool and did a practice piece before I started working on my bed:
Started laying out the new floor/mounts:
Started installing the nutserts:
Need some bolts so I couldnt finish it. Started working on some of the plates that I will use to cap the ends on the bed mounts. Hopefully it will look good.
David
Instagram: myfabguy
Old 05-30-2016, 08:53 AM   #295
Joe Pass
Joe Pass's Avatar
I have set a lot of "nutserts" or "thinserts" being from aviation background...since leaving the career, finding them for reasonable price was an issue until I found this Ebay seller
http://www.ebay.com/itm/291682191947
check them out...Joe
Old 05-30-2016, 11:15 AM   #296
DblTrbl
DblTrbl's Avatar
Wow. That's a great price! I usually spend 3 times as much.
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 05-30-2016, 09:53 PM   #297
Joe Pass
Joe Pass's Avatar
That seller will do volume deals if you contact him and also he lists ones with imperfections in the finish for a lot less....
Old 05-31-2016, 01:07 AM   #298
tinydb84
tinydb84's Avatar
Thanks for the link! I ordered some extras when I bought the tool on Amazon but these look good.
David
Instagram: myfabguy
Old 05-31-2016, 01:08 AM   #299
tinydb84
tinydb84's Avatar
Little more work with the bed.
Got the mounts bolted in but am waiting for the rest of the steel I ordered to come in:
Got rid of the other post support and rattle canned it to keep it from rusting:
David
Instagram: myfabguy
Old 05-31-2016, 09:04 AM   #300
aggie91
aggie91's Avatar
Bed looking great. Thanks for the TIG Torch info.
Karl
The LST Challenge:
