Old 03-11-2018, 01:15 AM   #276
Tikal48
Tikal48's Avatar
Re: Harold's '48 S10 LS1 Build
Finally getting a little time to work on the truck between work and the rain. I fabricated the rear bumper mounts. The S10 frame was narrower that the original frame, and I had to come out 2 1/4" per side. There is not much room behind the shackles and rear of the bed. So I had to cut a bit more clearance for the shackles to pivot.
I tucked the bumper up just under the bottom of the roll pan, and closer in than original. I happy with the look of the '53 bumper paired with the roll pan.
I remounted the S-10 spare tire hoist. I have a recess behind the tailgate where I am planning to mount a control shaft to the hoist. Just got to get this all figured out. More on this later.
Tikal48 is offline   Reply With Quote
Old 03-11-2018, 11:04 AM   #277
Advanced Design
Advanced Design's Avatar
Nicely done!
Advanced Design is offline   Reply With Quote
Old 03-11-2018, 10:49 PM   #278
99 to Life
99 to Life's Avatar
looks great, glad to see yo back on it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-04-2018, 08:38 PM   #279
Tikal48
Tikal48's Avatar
Here is a few pics of my spare tire hoist. I made use of the space behind the tailgate and under the bed to conceal the tire hoist control shaft.
I turned down a 1/2" extension and used a piece of 3/4" tubing for the shaft. It was cheap and turned out per what I imagined.
I didn't want to carry a spare tire around in the bed.
Old 05-04-2018, 09:50 PM   #280
Tikal48
Tikal48's Avatar
I wasn't very happy with the look of the gap under the the grill, so I started fabricating an air dam to even up the look between the fenders. A little bit more massaging and I will bolt everything back in place and finish the ends.
Old 05-05-2018, 12:17 AM   #281
99 to Life
99 to Life's Avatar
skills and vision. nice job
Old 05-05-2018, 03:10 AM   #282
joedoh
joedoh's Avatar
super nice work but where is your apron? I havent ever had a gap under the grille I can remember.
linked picture instead of posting so as not to distract from your awesome thread
http://67-72chevytrucks.com/vboard/c...pic31966_7.gif
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-20-2018, 09:54 PM   #283
Tikal48
Tikal48's Avatar
I'm not going to use an apron.
I finished shaping the air dam and adding a filler piece on the fenders to eliminate the gap where the fender radiuses up to the grille. I have the pieces tacked in, and will weld it out the next time I pull the fenders off.
Old 05-20-2018, 10:00 PM   #284
Tikal48
Tikal48's Avatar
I finally finished the passenger side door gaps. I've been avoiding this like the plague. Now I just need to start the driver side.
Old 05-20-2018, 10:29 PM   #285
Tikal48
Tikal48's Avatar
I fabricated new trunnions for the tailgate, and raised the tailgate 1/8" to get a little clearance under the tailgate. When I previously added the filler piece in the roll pan, I did not give it enough clearance, and it was barely touching when I let the tailgate down.
The new trunnions give a bit if a different look from the original ones. I did have to shorten the tailgate pivots about 1/4" on either side, where I could get these tight up against the sides.
Old 05-20-2018, 10:44 PM   #286
Tikal48
Tikal48's Avatar
Since I was working on the tailgate, I mounted my Mar-K stainless tailgate linkages. These worked out nice. Now I just need to pick up some hidden tailgate latches.
Old 05-21-2018, 05:55 AM   #287
kameltoes2015
Where did you get that awesome looking roll pan
kameltoes2015 is offline   Reply With Quote
Old 05-21-2018, 10:14 PM   #288
Tikal48
Tikal48's Avatar
Thanks, I bought the roll pan at Ecklers, but I spent a bit of time modifying it to reduce the gap between the roll pan and the tail gate.
It started out with about an inch gap. I just welded it to the rear cross sill since there were screws just below the tailgate. I cut a couple of access slots on the back side where I could add my license plate lights.
Old 05-26-2018, 10:43 AM   #289
Cautrell05
Looking good
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
Old 05-26-2018, 11:19 PM   #290
68blackbird
68blackbird's Avatar
I have gotten soooo many great ideas from this and a few other builds. The level of craftmanship here, and a couple of others, ogre, and Roger55, is truly inspiring. Well done sir(s). Kel
Kel's 1950 GMC 1/2 ton build
68blackbird is offline   Reply With Quote
Old 05-28-2018, 10:00 AM   #291
99 to Life
99 to Life's Avatar
very nice
Old 05-28-2018, 09:33 PM   #292
Tikal48
Tikal48's Avatar
When I bought these Frenched Headlights, the original pivot plates were a cheap brittle plastic with sheet metal screws for adjustment. These would have broken on the first good bump.
Well I finally finished one of the headlight spring plate assemblies. I used 1/8" stainless plate for the three rings and the headlight adjusting screws and nuts from a Mustang. It took a little bit of grinding on the adjusting nuts to get the assembly in the bucket.
This was a very tight fit, but I was able to make the adjusting screws accessible through the headlight retaining ring. That way I can pull the headlight and still maintain the adjustment.
Old 05-29-2018, 09:38 AM   #293
99 to Life
99 to Life's Avatar
slick mod, where did that kit come from? does that outter filler piece just snap in?
Old 06-08-2018, 10:09 AM   #294
lower50's
lower50's's Avatar
I like the exhaust tips and inner fender louvers. Your interior is looking killer.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-08-2018, 05:37 AM   #295
lv2tri2
So many helpful pictures and impressive work
lv2tri2 is offline   Reply With Quote
Old 08-18-2018, 09:32 PM   #296
Tikal48
Tikal48's Avatar
I finally decided to finally bite the bullet and start the driver side door. I've been working on the gaps and the flush mount door handle.
I drilled a couple of 1/4" dowels in the hinges to help re-align the door each time I had to re-install it. This definitely speeded up the process of re-alignment.
I have a little more grinding to do on the gaps and to start the final body work.
Old 08-19-2018, 08:55 AM   #297
8man
Nice work.
8man is offline   Reply With Quote
Old 08-19-2018, 09:26 AM   #298
99 to Life
99 to Life's Avatar
awesome, nice tip on the realignment
Old 08-19-2018, 10:39 AM   #299
Advanced Design
Nice work! You, sir, are very talented.
Old 09-30-2018, 02:53 PM   #300
Tikal48
Tikal48's Avatar
I recently picked up a pair of tailgate latches on Ebay and finally got the chance this weekend to install them. These are stainless and of nice quality. They were actually very easy to install. Well worth the money!
'48, bearclaw, ls1, s10
