Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-20-2011, 10:58 PM   #301
bruin_d
bruin_d's Avatar
Re: 72 Suburban Build
Decided to take a break from wiring and put the shifter in today. I still need to do the carpet before it completely done. I really like the shifter.
bruin_d is offline   Reply With Quote
Old 07-20-2011, 11:10 PM   #302
budnikguy
budnikguy's Avatar
That looks PIMP!!
budnikguy is offline   Reply With Quote
Old 07-20-2011, 11:18 PM   #303
YBNORML
YBNORML's Avatar
That's looks wicked. What kind is it?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-20-2011, 11:20 PM   #304
jmedero
jmedero's Avatar
Were they all out of long ones? Lol
Looks killer bro. You have motivated me seeing your post everyday. Keep it up.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-20-2011, 11:21 PM   #305
bruin_d
bruin_d's Avatar
Its the 16" Lokar for a TH400.
Old 07-21-2011, 08:39 AM   #306
gcburdic
Restoration Virgin!
gcburdic's Avatar
Chief...stay focused on that wiring....I know it's pretty easy to get sidetracked when you don't like to wire...I wa slike you and ALWAYS found something else to do instead of wiring!!! Shifter looks awesome!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-21-2011, 01:38 PM   #307
bruin_d
bruin_d's Avatar
I know. I have to be in the right mindset to do electrical because it requires thinking for me. Metal working/mechanical stuff doesn't require much thinking for me. Before getting to work on the Burb yesterday I mowed/weedwacked my half acre in the 107 degree heat which pretty much ruined my motivation for the day. I was lucky I even got the shifter done yesterday. I'm going to wire the fuel pump, ignition box, and fans today though since my "chores " are done.
Old 07-21-2011, 05:28 PM   #308
bruin_d
bruin_d's Avatar
My new Autometer carbon fiber face gauges got here today!
Old 07-21-2011, 05:31 PM   #309
bruin_d
bruin_d's Avatar
Forgot to add a picture...
Old 07-21-2011, 06:48 PM   #310
67cheby
67cheby
67cheby's Avatar
Sweet
67cheby is offline   Reply With Quote
Old 07-21-2011, 08:34 PM   #311
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
lOVE THE GUAGES....Does your hand fall comfortably to the shift knob in the the seated postion?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-21-2011, 09:29 PM   #312
bigpun
Great thread Brother.
Give me a shout when you get to SD I want to check out your burb.
bigpun is offline   Reply With Quote
Old 07-21-2011, 11:44 PM   #313
bruin_d
bruin_d's Avatar
Well today SUCKED! I was making a bracket to mount my coil with the grinder with a cutoff wheel on it. Well the blade caught and ripped the grinder out of my hand. Unfortunately my knee was there to stop it as it jumped away. Two hours later I have 2 layers of stitches (4 on the bottom and 7 on the top). Definitely my worst wrenchin' injury.
Old 07-21-2011, 11:52 PM   #314
kev2809
low n' slo
kev2809's Avatar
damn! that does suck!
had a similar injury last year..grinder got caught as i was cutting out my rocker panel..kicked back and hit me in the face! cut my chin and broke my tooth...i feel your pain!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-22-2011, 12:40 AM   #315
Mulk
Mulk's Avatar
That sux Chief..... I think we've all been there at some point. It's the hazards of metal work. I can't count how many times I've been a victim of the cut-off wheel.
They should make some kinda safety guard... Oh wait they do. That's that big chunk I take off and throw away, when I get a new grinder.
Get well, and heal up.
Eric
'68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Mulk is offline   Reply With Quote
Old 07-22-2011, 01:34 AM   #316
jmedero
jmedero's Avatar
Sorry to hear that brother. Take it easy for a few days and heal up good. You need both legs to drive this beast.
Juan
Old 07-22-2011, 08:36 AM   #317
67cheby
67cheby
67cheby's Avatar
Safety third...thats what i always say, fun and irresponsibility first and second...!!!!!!!!!!!!
Old 07-22-2011, 10:31 AM   #318
bruin_d
bruin_d's Avatar
Same thing I do to. You HAVE to, otherwise you leave like 40% of useful blade. Plus you can't get into most spots with it.
Old 07-22-2011, 10:38 AM   #319
bruin_d
bruin_d's Avatar
I think I need to buy a new grinder. This one has been bad luck. The first one happened a month or so ago while I was working on the firewall. The paint removing wheel caught the only freakin' wire that I had coming through the firewall. It wrapped the wire around the spindle, seized the wheel,'ripped the grinder out of my hand which then spun around at 4,000,000 rpm (at least that's what it felt like) and hit my hand like 3 or 4 times. Still not sure if it broke my hand or not. The second 2 are from last night's festivities.
Old 07-22-2011, 06:54 PM   #320
BlackTopMotors
You ok? Stitches?
BlackTopMotors is offline   Reply With Quote
Old 07-22-2011, 07:20 PM   #321
bruin_d
bruin_d's Avatar
Ya, I'm fine. Ended up needing 2 layers of stitches, 4 on the bottom and 7 on top.
Today I finished making my coil mounting bracket (the piece I was working on yesterday...) and made a piece to mount my ignition box. I'll get it wired tomorrow and work on the fan wiring.
Old 07-22-2011, 08:03 PM   #322
Mulk
Mulk's Avatar
Looks great.... Both the leg and the engine bay.
Another great addition the the grinder family, is the wire "cup" wheel. Awesome for removing undercoat, surface rust, and the first 17 layers of skin on your belly, when it decides to fight back... Just sayin'
Eric
Old 07-22-2011, 08:14 PM   #323
jmedero
jmedero's Avatar
Haha stupid wire cups. My enemy is the cutting wheel. Thank god for my wrist bone... Stoped it from going right mu whole arm. Cool scar though... Good table discussion. Lol
Old 07-22-2011, 09:18 PM   #324
lolife99
67-72 parts collector,…
lolife99's Avatar
What radiator and electric fan set-up are you using?
Keith
Convert to disc brakes.
Old 07-22-2011, 09:25 PM   #325
bruin_d
bruin_d's Avatar
Entropy with their larger, low profile fan setup that they sell. They don't list it on their website (the last I checked they didn't) but if you ask, for $150 more, they'll do dual 14" fans and a lower profile shroud.
