Old 11-25-2012, 02:18 AM   #301
99 to Life
99 to Life's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
looking good, yeah a v8 wouldn't weigh much more than a 4.3 and and inline 6 with bell housing was a tank. a 2/3" drop spindles or springs even, would really make this look proper IMO.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-29-2012, 12:42 AM   #302
Atommik
Atommik's Avatar
Well, today I put the order in for all of the steel I will need to build my box from scratch. I'll be using the original fenders, but everything else I will fabricate. It will have the basic stock look, with a few custom touches. Thanks xpickup for the inspiration. The materials will be ready to pick up in one week!! I'm really looking forward to this next phase of the build!!
Atommik is offline   Reply With Quote
Old 11-29-2012, 10:34 AM   #303
xpickup
xpickup's Avatar
Atommik, No problem. Glad to help.
Shannon
xpickup is offline   Reply With Quote
Old 12-01-2012, 06:57 PM   #304
Atommik
Atommik's Avatar
Spent a good deal of time today trying to figure out the PS pump mount. The pump would hit on the ps gear of the s10- frame. I tried several different positions and even considered trying to figure out a remote electric pump, but was finally able to get it to work. I moved the pump up slightly and in closer to the crank pulleys and was able to make it fit. I still need to make one supporting bracket off the back side and have a new high pressure line made. I'll also need a new ps belt about 4 inches shorter than the original.
Just to have a little extra clearance, could I remove the "rag joint" form the end of the steering gear and just put a swivel joint in there? That would give me an extra 1/2 clearance.
Old 12-02-2012, 02:24 AM   #305
gregw98
gregw98's Avatar
I am going to be using a 1997 Buick Park Avenue Power Steering Pump. Much smaller and you can mount it high on the engine. I was using one like it on my P/S Vega. I'll try to post a pic later,
http://www.partsgeek.com/catalog/199...ring_pump.html
gregw98 is offline   Reply With Quote
Old 12-02-2012, 12:56 PM   #306
54 jimmy
54 jimmy's Avatar
i put a manual steering box on my truck to solve this problem. it steers great except when your at a dead stop. could be something to consider. i also have a bigger steering wheel it helps out.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-02-2012, 04:00 PM   #307
Dirty Doug
Dirty Doug's Avatar
Borgeson makes a joint that does away with the rag joint.
Dirty Doug is offline   Reply With Quote
Old 12-02-2012, 09:56 PM   #308
Atommik
Atommik's Avatar
54 jimmy, I thought about the manual steering, but my daughter may drive it someday so power would be nice...
Dirty doug, Thanks for the info, I'll check out Borgeson online. I see you are from the twin cities...any "speed shops" or "hot rod shops" around here that you know of? I like to find stuff on line, but I'd rather put my hands on it before I buy!!
Old 12-02-2012, 11:56 PM   #309
BlueJeep
BlueJeep's Avatar
I replaced my rag joint with a u-joint from Speedway, worked great. I had to move my 5.3 over 5/8" to the passenger side for steering box clearance in mine.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-03-2012, 12:04 AM   #310
99 to Life
99 to Life's Avatar
I didn't have any clearance issues. Wonder if you mounted your engine up a bit more than me. I think a ujoint would definitely be the way to go.
Old 12-03-2012, 11:25 AM   #311
Coach529
Coach529's Avatar
Looks like an awesome build. Definately jealous of your work space!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-03-2012, 09:59 PM   #312
Atommik
Atommik's Avatar
Yes, I am very lucky the bosses at work are letting me keep it there and letting me work on it evenings and Saturdays...However where it is parked is where they store some of the new car inventory and they are expecting many more new cars to be delivered in January. I'm trying to get far enough along to be able to paint it before I have to move it out and bring it home. Then I'll do most of the put together at home in my limited space. Hopefully I'll have it legally drivable by spring/early summer, so I can drive it to work and work on it there!!
I'm watching craigslist for some s10 swap headers...
Old 12-03-2012, 11:41 PM   #313
99 to Life
99 to Life's Avatar
yeah I like your plan, drive it to work to work on it. CL never fails. But worst comes to worst, those headers are cheap and you can just get a new set.
Old 12-04-2012, 07:17 AM   #314
Dirty Doug
Dirty Doug's Avatar
There are no real speed shops left that I know of. TNT closed its doors a few months ago. I can check with my friend Curt at Creative Metalworks to see if he keeps one in stock, or my buddy Bob at C&F Racecars . That's where I got the last one I used. Otherwise I get them off of E-Bay . I'll see Curt tonight and I can ask him. He's just in Blaine , not far from you .
Old 12-04-2012, 08:01 AM   #315
Atommik
Atommik's Avatar
Thanks DD
Old 12-05-2012, 08:26 PM   #316
Atommik
Atommik's Avatar
I got my steel to start building the box. They fabricated the side panels wrong!! The correct ones will be here Friday. Everything else looks good. Started working on the front box panel today after work...pics tomorrow!!
Old 12-07-2012, 12:24 AM   #317
Atommik
Atommik's Avatar
Here's a few pics of the front panel of the box going together. I've been measuring the original box (whats left of it) and sketching out my plans, so it's exciting to see it finally coming together!!
The correctly fabbed side panels should be delivered tomorrow, so I'll be starting on those Saturday.
Old 12-07-2012, 12:36 AM   #318
oldman3
oldman3's Avatar
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 12-07-2012, 01:02 AM   #319
99 to Life
99 to Life's Avatar
cant wait to see all that together.
Old 12-08-2012, 06:48 PM   #320
Atommik
Atommik's Avatar
I started on the box sides today...
Old 12-08-2012, 06:57 PM   #321
Atommik
Atommik's Avatar
Also started on the stake pockets for the sides...only got 2 stake pockets cut out. I should have time to finish the other 2 this week.
Old 12-08-2012, 08:12 PM   #322
mknittle
mknittle's Avatar
looks great.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-08-2012, 08:41 PM   #323
cleanshaven84
cleanshaven84's Avatar
Looking good!
1949 GMC Pickup
Project "No Time '49"
Currently working on S-10 chassis swap.
Philippians 4:13 - "I can do all things through him who strengthens me."
cleanshaven84 is offline   Reply With Quote
Old 12-08-2012, 09:14 PM   #324
Chevette
Chevette's Avatar
Lookin' good, Atommik. Is that 18G? I really like the way you fabbed the tailgate.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 12-09-2012, 10:49 AM   #325
Atommik
Atommik's Avatar
Thanks all, for the comments!
The sheet metal is 16 gauge, including the tubing. The rectangle tubing for the stake pockets is 14 gauge. That is the thinnest wall material they had in that size (2X4).
Chevette, the first panel I made is actually the front of the box. The tailgate will be similar construction, but smooth on both sides.
