Old 02-09-2015, 11:04 PM   #301
99 to Life
99 to Life's Avatar
Re: Loadmaster '47 COE
now thats a true first start there, unlike most guys that fire it up, tune it a bit and claim its a first start!!!!! Man I'v been pumped to do an LS for a few years now, have one sitting, almost not looking forward to all the variables involved, but I'm sure its well worth it. 20 plus MPG and plenty of torque, can't beat that.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-10-2015, 11:21 AM   #302
66farmer
66farmer's Avatar
Congratulations on your first start up. Watching your video made me think of another question to ask. How tall is the truck and how do you fit in it. I'm 6'5" and I'm thinking it might be a little tight.
66farmer is offline   Reply With Quote
Old 02-10-2015, 01:53 PM   #303
Advanced Design
Advanced Design's Avatar
Rob, your first start video was awesome! Fuel leak, someone standing by with fire extinguisher, mouse nest out of exhaust, and a running engine..best thing I've seen all day!
Advanced Design is offline   Reply With Quote
Old 02-10-2015, 06:37 PM   #304
47 Fasttoys
47 Fasttoys's Avatar
Thanks all, it's a good feeling for sure. Of course I have some bugs to work out but that goes with any build. Farmer, I am using a '90 Silverado seat which helps give a little more space. I'm 6'2" and I fit fine. I'll shoot a picture next time I have the seat in for a reference. For total height right now I'm at 6'11 1/2" that's with a 7' garage door. Yes, it's gonna be close. I do have a smaller set of tires for the front which should give me 1/4 to 1/2" That's also with suspension at stock ride height. If I really wanted, I could drop it to the bumper using drop spindles and bags. I may go the bag route later but more for load then the slammed look.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 02-10-2015, 10:52 PM   #305
ghettoluxury
ghettoluxury's Avatar
The LS engines take a few times of running to learn there idle. When I bought my 2000 Z71 it had set for 2 years with a blown engine and no battery. After putting in a new engine it took about a week of driving before it fully picked up is idle.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-10-2015, 11:08 PM   #306
47 Fasttoys
Yea, I was kinda thinking that. I ran a scan on it and I've got no codes so that's a good thing. I'm kinda in a holding pattern on a whole lot of run time. I'm waiting on my gauges so I can install the temperature sender in the head and then I'll put some water in it and run it up to temp. Trust me, I've got plenty of other things that still need addressed before my first road test. I'm looking at later this month for that with a short road trip (say 500 miles) next month. In April it gets a real test with over 3000 miles planned so I better get it right.
Rob
My '47 C.O.E build
Old 02-10-2015, 11:35 PM   #307
99 to Life
99 to Life's Avatar
My guess is the temp sending unit isn't even reading if there isn't water in it. That might be setting the idle off. I'd def run it up to temp and its good to know sometimes they take a min to gather their memory.
Old 02-12-2015, 06:32 PM   #308
47 Fasttoys
Parts are coming in now. My gauges arrived (on time) with a free T shirt. My tool box also arrived. I will end up cutting it in half for a 36" box for each side. Got my new heater blower motor installed and mounted the unit in the cab. A little elongating of the mounting holes was required with the 12V replacement motor. I have started to notice a trend here, the heater is on my wife's side, she has the painted door, she has glass in her door, an armrest etc...
Rob
My '47 C.O.E build
Old 02-12-2015, 07:12 PM   #309
401ton
Originally Posted by 47 Fasttoys View Post
Wheelbase is 143.5 (extended cab). Yes, I would use the same donor. Why? Drive by wire, correct track, easy steering hook up, strong aftermarket support (LS based engine) most donor parts are reusable with little of minor mods. on the down side: good donors are not cheep, 5K in my case. Only the 1/2 tons use the rack and pinion steering. Not a lot of examples to build from on the net so you need to figure out most of the mods on your own.
I've been watching your build thread and wondered if a guy wanted to have a shorter pickup bed type truck, would a standard/non-extra cab workout OK or is there something else I would run into?
I was thinking 8' ish bed.
401ton is offline   Reply With Quote
Old 02-12-2015, 11:19 PM   #310
lower50's
lower50's's Avatar
cool
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-13-2015, 05:18 PM   #311
47 Fasttoys
I would think a shorter bed would work, the issue may be drive shaft length. For mine the drive shaft is 37". I have seen much shorter (my FFR Cobra is 8") but on a truck I would want a minimum of 12". Now if you where to mount the engine more under the cab then yes an 8' bed would work.
Rob
My '47 C.O.E build
Old 02-13-2015, 09:40 PM   #312
lower50's
lower50's's Avatar
Just finished reading your whole build, your doing an amazing job. It's very rewarding in the end to build something that there is no manual for. Good luck on making your goal. I have very similar travel plans with my '52 but not for 2 years. Always liked the COE's. I'd go with the rendition of 8.2!!
1951 MG TD
Old 02-18-2015, 09:55 PM   #313
47 Fasttoys
Not a lot of great pictures but progress just the same. I now have a working headlight switch, blower fan motor for the heater with 3 speed control, working 2 speed wipers and 1 side working park and turn lights, and on a good note the engine is running silky smooth. I put anti-freeze in it and ran it up to temperature a few times and things cleared right up, no more up and down on the idle or hesitation when I press the go pedal. Still some leaks to correct for the brake lines but the the brakes do function. If I can keep up the pace (25 hours a week now) I should be ready for a test drive in less then 2 weeks.
Rob
My '47 C.O.E build
Old 02-18-2015, 10:11 PM   #314
Advanced Design
Great progress Rob! All those details take a lot of time.
Old 02-18-2015, 10:23 PM   #315
47 Fasttoys
You got that right AD, it seems like every part needs to be rebuilt or modified in some way when doing a modern chassis swap. Heck, even going from 6 volt with cloth covered wiring to 12 volt takes a bit of work.
Rob
My '47 C.O.E build
Old 02-19-2015, 08:40 AM   #316
lower50's
lower50's's Avatar
Good job with the motor. Can't wait to see this.
1951 MG TD
Old 02-21-2015, 09:04 PM   #317
47 Fasttoys
Well, I got all the exterior lights and turn indicators working, also hooked up control cables for the heater, works great. I installed the electric shifter for the first time. I decided to pass on the auto position function for now and just use a DPDT toggle switch for control. I tested the function and it seems to work good but may be a little under sized, on flat ground I think it will be fine but I think on a hill it will not have the power to come out of park. I will order a larger and slower actuator and give that a try. Right now one bump may overshoot the gear indent and I have to go back to get a good set.
And on another note: The wife informed me that before we go on the first road trip next month I need to remove the donor bed and build some type of a flat bed. Just what I needed, one more thing to add on the to do list.
Rob
My '47 C.O.E build
Old 02-21-2015, 11:10 PM   #318
Advanced Design
The actuator is a cool idea. Nice design work on that Rob...that schematic was pretty impressive.
Old 02-22-2015, 11:11 AM   #319
99 to Life
99 to Life's Avatar
congrats on the next hurdle there. wiring can be fun. I always like turning the key and hitting the head lights. just makes it really feel alive to me.
Old 02-24-2015, 10:37 PM   #320
47 Fasttoys
Test fit the gauges, also more wiring on the dash. Still waiting on some bushings I will weld to the dash to fill the gap. The gauges light up blue at nightThat's the advantage of doing a rattle can paint job on the interior make some mods and just sand it back and respray. Who knows I may start a new trend, the card board dash. I also rebuilt and the column (new bearings and horn contact bushing.
Rob
My '47 C.O.E build
Old 02-24-2015, 11:42 PM   #321
mud.man.rj
mud.man.rj's Avatar
It just gets better and better, do you sleep at all or live in the garage.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 02-26-2015, 06:04 PM   #322
47 Fasttoys
Lately I think I live in the garage, I really want to have this thing on the road in the next 3 weeks so I'm pushing pretty hard right now. About 25-30 hours a week, and yes, I have a normal job also. My wife is very understanding and supportive and that makes all the difference.
Rob
My '47 C.O.E build
Old 02-26-2015, 07:37 PM   #323
iowaboynca
iowaboynca's Avatar
If your wife is like my wife, she wants it on the road too, wanting to take it for a spin!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-26-2015, 09:30 PM   #324
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work and progress! It is looking awesome, and that is awesome on firing it right up! Do have to back over seas anytime soon for work, or are you back state side for a while?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-27-2015, 06:10 PM   #325
47 Fasttoys
Nope, I'm done with the overseas work (as far as I know). I did start a new position a couple of weeks ago with a good crew on a new production line so it's all good.
My '47 C.O.E build
