Old 07-20-2016, 04:43 PM   #301
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project Beatrix
Yeah, your truck is looking killer!!!!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-20-2016, 05:31 PM   #302
mooseknuckles
mooseknuckles's Avatar
Re: Project Beatrix
omg!
mooseknuckles is offline   Reply With Quote
Old 07-20-2016, 09:33 PM   #303
knomadd
knomadd's Avatar
Re: Project Beatrix
Nice!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-21-2016, 10:48 AM   #304
boostedc10
boostedc10's Avatar
Re: Project Beatrix
Originally Posted by mcbassin View Post
Originally Posted by mooseknuckles View Post
omg!
Originally Posted by knomadd View Post
Nice!
Thanks guys. Hopeing to spend some more time on her this weekend. Want to get the frame for the bed floor done so I can get some wood in it and install my Chub Tubz!!!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 08-14-2016, 04:26 AM   #305
7wolf
Re: Project Beatrix
SO badass! any updates?
7wolf is offline   Reply With Quote
Old 08-15-2016, 07:18 AM   #306
boostedc10
boostedc10's Avatar
Re: Project Beatrix
Thanks 7wolf! No updates as of yet. Got a bunch of parts at the blaster and im trying to get the raised bed floor frame done. Should have some new pictures in the next few weeks. Goal is still to have it running by the end of summer. We will see if that happens.
Brandon
Instagram: DRVFSTR
Old 08-15-2016, 07:42 AM   #307
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Project Beatrix
You have a Beautiful truck started there. I really like the grey powder coating on the frame. I have been looking at the same for mine...what grey did you use?
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 08-15-2016, 08:21 AM   #308
mcbassin
Still Learning
mcbassin's Avatar
Re: Project Beatrix
We need pictures....
mcbassin is offline   Reply With Quote
Old 08-15-2016, 09:24 AM   #309
knomadd
knomadd's Avatar
Re: Project Beatrix
^^^What he said^^^
-Duane
Old 08-16-2016, 08:15 PM   #310
TrshTrk
TrshTrk's Avatar
Re: Project Beatrix
Trash Truck
69 GMC
TrshTrk is offline   Reply With Quote
Old 08-16-2016, 08:24 PM   #311
shores6
shores6's Avatar
Re: Project Beatrix
Man this thing is coming along. Lookin awesome, man.
Todd
https://www.instagram.com/shores6/
Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419
shores6 is offline   Reply With Quote
Old 08-18-2016, 07:57 AM   #312
boostedc10
boostedc10's Avatar
Re: Project Beatrix
Thanks, the name of the grey I used is craftsman grey.
They are coming slowly but surely!
^^^What he said^^^
Thanks shores
Originally Posted by TrshTrk View Post
Brandon
Instagram: DRVFSTR
Old 08-18-2016, 07:58 PM   #313
TrshTrk
TrshTrk's Avatar
Re: Project Beatrix
I feel like you probably read up a lot on your set up and I have a LQ4/4L80e questions!!!! Can you run that set up with a ls1 style intake without changing the truck harness to the f body engine harness? and if you do have to change to the f body harness... do the transmissions (4l80e and 4l60e) share the same connections?! I know f body guys get 4l80's built and use them with the factory PCM... Hopefully I'm making sense. If you can shed a little light on the subject or have a link to something, thank you. If not... thanks for building a badass truck and documenting it.
Trash Truck
69 GMC
Old 08-19-2016, 07:51 AM   #314
boostedc10
boostedc10's Avatar
Re: Project Beatrix
You can run an F-body harness but you will have to either use the F-body injectors or change the connectors. As for the transmission you can run an 80e by adding a input speed sensor and wiring 2 wires to the PCM. The rest of the connectors are the same, the only other mod you will need to make is to the round connector on the transmission. Terminal U gets moved to terminal S and the original wire in S is no longer used. Hope this helps.
Brandon
Instagram: DRVFSTR
Old 08-19-2016, 06:00 PM   #315
TrshTrk
TrshTrk's Avatar
Re: Project Beatrix
very helpful! thank you.
A friend tried to steer me away from the 4l80 saying it was "more work than what its worth" and said to just built the th400.
Trash Truck
69 GMC
Old 08-25-2016, 02:05 AM   #316
jerimy75
jerimy75's Avatar
Re: Project Beatrix
Brandon - great looking pickup so far! I'm loving the frame and engine colors. Sorry if you provided already, but can you let us know what tire sizes you are running?
Thanks!
jerimy75 is offline   Reply With Quote
Old 08-29-2016, 09:12 PM   #317
boostedc10
boostedc10's Avatar
Re: Project Beatrix
Finally got the mount built for my Accuair Exo mount. Wanted to keep everything together and out of the way so I designed a mount to hold the whole unit and float it over the gas tank. Think it turned out pretty good for a simple design that bolts to the notch with rivnuts!
Brandon
Instagram: DRVFSTR
Old 08-29-2016, 09:15 PM   #318
boostedc10
boostedc10's Avatar
Re: Project Beatrix
Thanks!
Jerimy I am running 265/35R22 up front and 285/35R22 in the rear.
Brandon
Instagram: DRVFSTR
Old 08-30-2016, 08:21 AM   #319
mcbassin
Still Learning
mcbassin's Avatar
Re: Project Beatrix
Looks great Brandon!
Old 08-30-2016, 08:28 AM   #320
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Project Beatrix
Looking good man!
--Josh
Old 08-30-2016, 09:43 AM   #321
boostedc10
boostedc10's Avatar
Re: Project Beatrix
Originally Posted by STOCKISH View Post
Looking good man!
Thanks fellas!
Brandon
Instagram: DRVFSTR
Old 08-30-2016, 10:34 AM   #322
MMcMasters
MMcMasters's Avatar
Re: Project Beatrix
Brandon, that is awesome!!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 08-30-2016, 11:02 AM   #323
knomadd
knomadd's Avatar
Re: Project Beatrix
That looks great!
-Duane
Old 08-30-2016, 02:52 PM   #324
boostedc10
boostedc10's Avatar
Re: Project Beatrix
That looks great!
Thanks guys, hopefully I will get my elevel sensors mounted up tonight and start plumbing the airlines. Once that is done I can get the bed floor frame figured out.
Brandon
Instagram: DRVFSTR
Old 08-30-2016, 02:56 PM   #325
jerimy75
jerimy75's Avatar
Re: Project Beatrix
Thanks Brandon!
