Old 06-08-2012, 12:16 PM   #326
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Here's some good pics of your c-57 wheels in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=528287
Keith
Convert to disc brakes.
Old 06-08-2012, 12:28 PM   #327
CC69Rat
CC69Rat's Avatar
You're killin me man..
Wow, that looks good. Maybe do big brakes instead of stockers and go with these wheels? $2300 for the Centerlines and $1300 for the drop kit with stock / 12" rotor kit = $3600 OR $1050 for the Coys and $1800 for the Big Brake / Modular drop kit with 13" rotors, etc. = $2850. For that matter, .. four wheel disc?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-08-2012, 12:55 PM   #328
raull
raull's Avatar
second package better , more bang for the buck !!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 06-08-2012, 01:14 PM   #329
CC69Rat
CC69Rat's Avatar
Keith -- Quoted from Active Member 'DKN' on the forums (found it on an earlier post) if I am not mistaken, it looks like he works for CPP.
The track with on an OE drum brake truck is 1” narrower (0.5” each side) than an OE disc brake truck. The CPP modular spindle was designed to pull the wheel away from the fender lip as much as possible. Trucks often rub the outer portion of the inner fender.
The change from a drum brake spindle and hub- CPP modular is .25” narrower each side.
The change from an OE disc brake spindle and rotor- CPP modular is .75” narrower each side.
Danny Nix
CPP
So it looks like the modulars would pull my GMC (original drum brake) in .25" on each side. (?)
Chad
Old 06-08-2012, 01:32 PM   #330
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Maybe I'm recalling incorrectly but I thought.... adding disc increased the trackwidth by 1.5" overall (.75 each side). If the CPP modular spindles pull the wheels back then there wouldn't be any increased track width.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-08-2012, 01:35 PM   #331
darkhorse970
darkhorse970's Avatar
I've got my eyes on a set of Centerlines too. They are nice and just different enough to be interesting. I'd sell the bike and expedite the trucks completion. (Its easy for everyone to say that when we don't have a connection to the bike) Just my .02 cents.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 06-08-2012, 02:07 PM   #332
CC69Rat
CC69Rat's Avatar
Nate - just thinking out loud here.. not disagreeing.
If I were a GM engineer in 69 for example. If the rear housing is 55.5" on my drum brake trucks. I have been tasked to change to discs in 71 model year. Would the track width on the front of the 69/70 not match the rear? Explaining why in 71(late 70) they widened the rear by 1.5". Adding discs up front to equal the rear and vise versa.
So just thinking logically. (The way I understood the guy from Cpp) lets say the front and rear track width on a factory drum brake 69 is 55.5. (Using the plate to plate theory)
Compared to an original disc brake truck with 57" track front and rear.
In stock configuration the 69 drum truck is .75 narrower each side than the 71. Before anything is done to it. The added width cometh from the disc rotors, not the a arms etc.
So adding modular to a 69 ? Over stock it is. 25 more narrow.
adding modular to an original disc 71? Over stock it is. 75 more narrow
The end result is that cpp modular spindle is in the same position regardless of year. The way i undetstand is the variable comes in depending on the original configuration of the truck. Modulat has more impact on a 71+ than it would a pre- disc truck.
69 track width - 55.5
71 track width - 57
CPP MODULAR track width - 55
ALL approx... just thinking it through.
Chad
Old 06-08-2012, 03:28 PM   #333
67barnfind
67barnfind's Avatar
I'm on board !@!
67barnfind is offline   Reply With Quote
Old 06-08-2012, 04:18 PM   #334
lolife99
lolife99's Avatar
No it wouldn't.
The front track width has always been wider on the truck, no matter if its a drum brake truck or disc brake truck.
That's why you offset the wheel width and backspacing to make them fill the bedsides and front fenders equally.
Keith
Old 06-08-2012, 04:28 PM   #335
CC69Rat
CC69Rat's Avatar
I was just thinking / speaking / typing hypothetically ..
New plan.
I am going to order the CPP Big brake kit tonight. Modular spindles, all of it.
Slam the truck. Measure with my Wheelrite, and order my wheels. Done.
I'll post up some pics in a few weeks.
Chad
Old 06-08-2012, 04:40 PM   #336
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Words of wisdom and the only way it should be done.
-Nate
Old 06-08-2012, 05:50 PM   #337
shawno72
C/10 junkie
shawno72's Avatar
X2
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 06-09-2012, 08:35 AM   #338
raull
raull's Avatar
Wooo hoooo !!!!! Good move chad !!!!
raul
Old 06-11-2012, 02:46 PM   #339
CC69Rat
CC69Rat's Avatar
I have been doing some research on the stuff from CPP. I am hearing a lot of bad reviews on them. Yikes.
I think I am going to try to put together a Big Brake kit of my own and get exactly what I want. I used to use Hotchkis stuff in my Camaros, so I'm kinda leaning that direction. I have Hellwig swaybars for it already (got them both new, off the forum and discounted pricing so I went that route.. nothing wrong with Hellwig )
I'm just a little spooked by the CPP reviews. Will update soon
Chad
Old 06-11-2012, 02:54 PM   #340
shawno72
C/10 junkie
shawno72's Avatar
What kind of bad stuff are you hearing. I've had no issues with the CPP suspension stuff that I've used.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 06-11-2012, 02:58 PM   #341
67cheby
67cheby
67cheby's Avatar
i have also used alot of CPP components, i have had good luck with them !
67cheby is offline   Reply With Quote
Old 06-11-2012, 03:06 PM   #342
Bennett68C10
Bennett68C10's Avatar
If you want another option lol, I have the McGuaghys big brake kit on mine. Was a really nice kit. You can get them from Porterbuilt for $700.00.
Here is the link: http://www.porterbuiltfabrication.co...p-Spindles-700
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-11-2012, 03:15 PM   #343
VA72C10
VA72C10
VA72C10's Avatar
mcgaughy's makes some nice stuff too!
Although with all the cpp issues I've had it's always been shipping or customer service related....never actual product issues....so if you deal with cppjeff up front or go through one of the forum vendors who sells them I think you'd be good...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-11-2012, 03:16 PM   #344
CC69Rat
CC69Rat's Avatar
http://www.classicperform.com/Store/...6GSK-55213.htm
Here's what I have been looking at. But, I have heard some bad stuff about them too..
http://67-72chevytrucks.com/vboard/s...d.php?t=463524
(just one of them)
Maybe this was just a single case situation (?) but .. My truck being a 70, I need to consider the 'conversion' spindles too and this kit would take care of the center link issues, etc. I'd just like to get everything I need shipped to me as one kit. Unbox it, and spend the whole day (s) dropping this truck.
I'd still love to have the CPP kit. You guys think it would be ok? I noticed that link was from 2011 too so they might have stepped up some since then? I'm sure some people have their stuff and I mean no offense. I just want to make sure it's cool to go that route.
Chad
Old 06-11-2012, 03:24 PM   #345
67cheby
67cheby
67cheby's Avatar
man that seems like a great deal !
Old 06-11-2012, 08:22 PM   #346
CC69Rat
CC69Rat's Avatar
One more question..
Option #1 - 4/6 drop, Big brakes (13) on the front, dual piston calipers, , modular spindles, and drums on the back ?
OR
Option # 2 - 4.5/6 drop, (12) on the front, single piston calipers, regular spindles AND disc on the rear?
http://www.classicperform.com/Store/...6772GSK-5D.htm
AND
http://www.classicperform.com/Store/...6366RWBK5E.htm
(upgraded rotors on both, drilled / vented)
Same money .. your thoughts?
Chad
Old 06-11-2012, 08:35 PM   #347
NoNeck
NoNeck's Avatar
I like option #1... being a daily driver, that extra .5" drop on the front will help on those burger joint speed bumps. Plus, you would get the modular spindles with those big brakes showing through those 20" wheels.
Just an old man's 2¢.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 06-11-2012, 09:19 PM   #348
CC69Rat
CC69Rat's Avatar
Thought I'd post a picture of my gauge cluster. Dad finished it up today. We have to paint the column and finish up with the dash detailing .. but this should make a difference
I think it looks great.. and yes, polished with Colgate ! (the lens) All the gauges are original and detailed, the outer bezel is repro.
Chad
Old 06-11-2012, 09:33 PM   #349
VA72C10
VA72C10
VA72C10's Avatar
dash looks great! was the toothpaste for the lens?
On the brakes, I think it's a win, win....I am not much help as I have the same debate because discs on the rear look great with big rims, but the modulars/bigger fronts look great also....
As far as braking performance, I really don't think you'll notice a huge upgrade with the discs on the rear....even many high dollar modern trucks use drum rears since most of the braking pressure is (and needs to be) at the front anyways....
Old 06-11-2012, 09:34 PM   #350
bigguy69
dazed and confused
bigguy69's Avatar
Man that looks awesome!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
