Old 03-08-2014, 09:14 PM   #326
mikeleeshields
mikeleeshields's Avatar
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
Finally a day in the 50's. Amazing how much can be done with a whole day above freezing. I finished up bending my brakelines. The only thing left to do is to flare some of the ends. Other than that I have them ready to run into the distribution block when I get it mounted.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 03-08-2014, 09:22 PM   #327
mikeleeshields
And finally I got the cab mounted today. A little backyard enginuity with some ratchet straps and and an engine hoist. Not exactly the easiest one man job but it worked for taking it off so I figured is should work for putting it back on and it did.
Now I can finally start to make some progress on getting this thing drivable. I am so pleased with the stance.
Mike
Old 03-08-2014, 09:27 PM   #328
lolife99
67-72 parts collector,…
lolife99's Avatar
What kind of fittings are you using on the front steel brake lines?
Keith
Convert to disc brakes.
Old 03-08-2014, 09:32 PM   #329
mikeleeshields
I have used 1/4" nut and ferrule compression fittings for a lot of brake line fittings. I am using some 3AN fittings to hook up the flexible lines to the front calipers and the rearend.
Mike
Old 03-08-2014, 09:37 PM   #330
ridinlow68
ridinlow68's Avatar
Looks awesome! Have you been able to stop staring at it since you put the cab on?!? Haha
Rick
1968 Chevy C10 Shortbed, 383 w/4L80E, Extreme Dropmember, Accuair I-Level, Bonspeed Big Blocks
ridinlow68 is offline   Reply With Quote
Old 03-08-2014, 09:41 PM   #331
mikeleeshields
Thanks. It is such a feat. I had to stop staring so I could take a shower and eat dinner, haha. After I dropped it I realized I forgot to drill my holes in carrier bearing crossmember, oops. I will just have to jack it up extra high to do so. But I couldnt take it anymore.
Mike
Old 03-08-2014, 09:43 PM   #332
lolife99
lolife99's Avatar
You might want to reconsider using a brass compression fitting on a stainless line,... or for brake lines period.
The 37 degree AN fittings or 45 degree double flare is the standard.
If you have to use compression,... use a stainless fitting like Swagelok brand fittings.
They use a stainless ferrule to crimp into the harder stainless line.
Keith
Old 03-08-2014, 09:47 PM   #333
mikeleeshields
Thanks for the advise Keith. Nevermind, I did a little research and it is more of a pressure issue. I will have to rethink the compression fittings I have in place then.
Mike
Old 03-08-2014, 10:11 PM   #334
lolife99
lolife99's Avatar
Thanks for the advise Keith. Is it more of a leaking concern. It isn't a pressure concern correct?
EDIT:
Sorry for my slow typed response,...
Pressure and the ability of the ferrule to not grip the tube.
The tube nut on a AN fitting or a double flare is captured by the flare and cannot come off the tube.
Plus compression fittings are illegal in many states.
We use Swagelok fittings at my work.
http://www.swagelok.com/products/fittings.aspx
Brass fittings on copper and soft lines.
Stainless on stainless lines.
Never brass on stainless.
Plus these are rated much higher than the average parts store compression fitting.
Do yourself a favor and flare the brake lines.
There is a ton of info on the internet about NOT using compression fittings for brake lines.
Keith
Old 03-08-2014, 10:20 PM   #335
mikeleeshields
EDIT:
Thanks again Keith. My lines were a combination of flared and compression. Looks like I will be going with all flared now lol. IMAX look into the swageloks though since I am set up for compression lengths. One more question what sealant do you use on your npt fittings?
Mike
Old 03-08-2014, 10:25 PM   #336
lolife99
lolife99's Avatar
My opinion,... loctite 545 is the best for hydraulic fittings (brake line NPT) and also NPT end of air ride fittings.
Let is set up the required 24 hour cure time and you will be leak free.
But the fitting has to be clean and dry.
(no oily fittings)
Keith
Old 03-08-2014, 10:27 PM   #337
lolife99
lolife99's Avatar
The worse part about your current compression fittings,... is that the ferrule will have to be cut off the line to reuse the line.
Then it will be too short.
Plus Swagelok fittings are expensive!
Keith
Old 03-08-2014, 10:47 PM   #338
mikeleeshields
The compressions only indented the tube about a 1/4 back the flare may still work. I will try it. I may be able to get some stainless fittings from a supplier of mine. I will check my options.
Mike
Old 03-09-2014, 12:05 AM   #339
Bennett68C10
Bennett68C10's Avatar
Congrats on getting the cab on Mike, it looks great
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-09-2014, 12:07 AM   #340
mikeleeshields
Thanks Keith
Mike
Old 03-09-2014, 12:15 AM   #341
suspect
suspect's Avatar
Lookin nice! I know that feeling looking at it with the cab finally on. Wait til you lean a bed side up to it. Blood really starts pumping!
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 03-09-2014, 10:11 AM   #342
mikeleeshields
Thanks dan. I've got some other things to do before I tease myself with that lol
Mike
Old 03-09-2014, 06:00 PM   #343
builtbyKane
builtbyKane's Avatar
It's amazing how you can see the light at the end of the tunnel when the cab gets set on. Just take it one little task at a time and you'll have done before you know it.
builtbyKane is offline   Reply With Quote
Old 03-09-2014, 06:06 PM   #344
mikeleeshields
Thanks buddy. Now I can start to wire things up among all the other crap to do lol.
you driving yours around regularly yet.
Mike
Old 03-09-2014, 06:16 PM   #345
builtbyKane
Sadly no. It just needs a weekend worth of work to finish but instead I took on another project this winter so Double Tap will remain in storage until April.
Old 03-09-2014, 09:01 PM   #346
mikeleeshields
Crazy man. I barely have time and money for one project let alone multiple ones. Although I'd like more lol
Mike
Old 03-09-2014, 11:38 PM   #347
mcbassin
Still Learning
mcbassin's Avatar
We have been using some 1/4" Swagelok fittings at my job for a test stand that has to withstand 10,000 PSI sustained. They are expensive but very good product. Their benders are very nice too.
mcbassin is offline   Reply With Quote
Old 03-10-2014, 01:53 AM   #348
jlsanborn
jlsanborn's Avatar
Ditto on the Swagelok fittings. They are the cat's meeeoww! If you're gonna spend the dough, they have a go/no-go type gauge that slips between the tube nut and fitting for tightening them down. Fel-Pro also makes an anaerobic gel type sauce that's pretty sweet for NPT. Similar to the Loctite, it cures hard.
Cab looks awesome on there man!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 03-10-2014, 07:24 AM   #349
mikeleeshields
Thanks for the Info. I will figure something out. Either I will try to get some swagelok fittings from a vendor of mine or I will change them all to flare fittings.
Thanks for the info also. And thanks for the compliments.
Mike
Old 03-12-2014, 10:14 PM   #350
mikeleeshields
Good news. A vendor of mine that deals with hydraulic equipment is giving me all the necessary SS compression fittings I need to redo my lines.
Mike
