12-01-2020, 05:00 PM | #326 |
Re: slammed 57
Hey bud thanks for asking, the first one that is labeled (different) is used to stiffen up the frame to help strengthen the frame ( to help keep from a twisting movement).. I cant take credit for it , I borrowed the Idea from Art Morrison frames . the other (what are these for ) label , I have a T56 transmission which its tranny mount is way towards the rear , so if i ever have to pull the motor out with out the transmission I would need to to use something to support the tranny , most people use another jack or wooden blocks to support it to keep the tranny from hanging down and putting all that stress on the rear tranny mount. I just added those little mounts and build a brace that I can put in and take out to make it easier to help for support.... some people will say just pull the motor and tranny out as one unit which works , but its also a large mass to move around and trying not to band up against the truck causing dents and scratches.
12-01-2020, 09:44 PM | #327 |
56 - autocross
Re: slammed 57
Makes sense - thanks for the detailed response. Doing a chassis now and getting close to the center section. Good to learn from others.
12-03-2020, 09:03 AM | #328 |
Re: slammed 57
anytime my brother, post some pics, I would love to see your progress
12-03-2020, 09:32 AM | #329 |
Re: slammed 57
This thing looks so nasty man. Can't wait to see it done.
12-06-2020, 08:41 PM | #330 |
Re: slammed 57
thanks bud
12-06-2020, 08:50 PM | #331 |
Re: slammed 57
Well I had a Major detour this past 2 weeks , after I got the cab back from the media blaster , when I got home and prepping the cab for epoxy I noticed the roof got warped during the blasting. ( yeah I was pretty ticked off!) So I had to put a new skin on. since it was off I went ahead and epoxied the inner skin.
12-07-2020, 12:27 AM | #332 |
Re: slammed 57
Bummer, but new roof looks great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-07-2020, 09:19 AM | #333 |
Re: slammed 57
Getting ready to send mine to blast also. I already have a big dent in the top and it’s tin canning. How had was it to replace?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
12-07-2020, 09:22 AM | #334 |
Re: slammed 57
That sucks out the warping, but outstanding job on the repair...Plus the peace of mind on the rust coating is assuring.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-07-2020, 11:23 AM | #335 | |
Re: slammed 57
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
12-07-2020, 05:11 PM | #336 |
Re: slammed 57
that media blaster must have been rough, you gotta try to warp the metal on our trucks
i had my whole truck sandblasted without any issues i think he stood way back and took his time removing 4 layers of paint
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-08-2020, 06:30 PM | #337 |
Re: slammed 57
its not a bad job and pretty straight froward. Mine was more difficult because the drip rails were removed, so it is quite a bit more welding. but if your keeping your drip rails then the hardest part is drilling all the spot welds out after that put it on ,alien everything , clamp it down all the way around and weld the spot welds, the aftermarket roof skin is spot on and fits great.
12-08-2020, 08:10 PM | #338 | |
Re: slammed 57
12-08-2020, 08:22 PM | #339 | |
Re: slammed 57
https://www.cpitruck.com/ |
12-08-2020, 11:20 PM | #340 |
Re: slammed 57
Warped metal when blasting ?
Call dustless blasting for a tech near you . No more warped metal . They will even come to you , no mess beyond the project . My neighbor had them over to do his chassis in the driveway . They put down a tarp did the job and no mess . I even had the guy do a sway bar for me . Very quick , clean and I didn't have to go across town to some other blaster .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
12-09-2020, 01:34 PM | #341 |
Re: slammed 57
Nice job on the roof skin. Looks great
12-24-2020, 11:11 PM | #342 |
Navy Radioman Veteran
Re: slammed 57
Great Thread... /Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
02-27-2021, 06:37 PM | #343 |
Re: slammed 57
The cab is getting the complete work over. Next week or two I will be spraying SPI epoxy to seal the body work in and then a few rounds with polyester along with MORE sanding. I took a break from sanding (my hands needed it) and worked on some dash trim (half round aluminum stock)and shaped the end to finalize it.
02-27-2021, 09:55 PM | #344 | |
Re: slammed 57
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
02-28-2021, 09:30 AM | #345 |
Re: slammed 57
Hey Steve, Iam torn between clausen ALL u Need/ z chrome or slick sand/ featherfill... really want to use clausen but its just about double the price for just a little better sand-ability... at least from what others say... do you have any insight?
02-28-2021, 10:16 AM | #346 |
Re: slammed 57
I have been using slick sand. It sands tough until you break through the top layer. I have not tried anything else and my one friend uses slick sand with the same results. Can't wait to get to that point of my build. Steve
02-28-2021, 11:01 AM | #347 |
Re: slammed 57
Looking great! I’m not looking forward to all the sanding either, but it means your almost ready for final paint. Keep up the progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
02-28-2021, 11:07 AM | #348 |
Re: slammed 57
Looks great! I was also thinking of something to go under the dash to hide that line. Still haven’t found what’s in my head yet.
02-28-2021, 07:15 PM | #349 |
Re: slammed 57
nice work what kind of aluminum did you use and where did you get it. is that round stock or d shape
02-28-2021, 08:01 PM | #350 |
Re: slammed 57
its D- shaped, its about $10 for about 5 or 6 ft piece of 3/8" . I bought 2 pieces incase I messed up. see link below
https://heathmooreinteriors.com/ |
