Old 12-06-2013, 08:16 AM   #351
dubie
dubie's Avatar
Re: 56 shop truck build
thanks bud, we're going to be prepping git for body work and paint in the near future
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 12-06-2013, 06:05 PM   #352
OrrieG
OrrieG's Avatar
Originally Posted by dubie View Post
we also had the Beaumont to the American Chevelle
That used Pontiac grilles if I remember right...
OrrieG is offline   Reply With Quote
Old 12-07-2013, 05:00 PM   #353
Red Foreman
Red Foreman's Avatar
Dubie, awesome work so far, have been enjoying this build!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 12-08-2013, 11:57 AM   #354
dubie
dubie's Avatar
I spent a little time yesterday removing the badging, wiper arms, bumpers, head light bezels and the entire bed is unbolted and ready to remove so we can get started on some body work and sanding this week. First step will be to sand the entire thin gang get a couple coats of black epoxy primer on it, then we will smooth some of the body out with filler. This will be our starting point for the weathered paint finish
Old 12-08-2013, 12:44 PM   #355
sqrlnts
Can't wait to see how your paint comes out. Stay warm and keep truckin!
sqrlnts is offline   Reply With Quote
Old 12-08-2013, 01:22 PM   #356
dubie
dubie's Avatar
Staying warm is key. It's been dipping down into the -40 range every night this week.
Old 12-08-2013, 01:53 PM   #357
Flames97
Flames97's Avatar
I like your build, can't wait to see the weathered look process. Keep up the good work.
-Aaron
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 12-23-2013, 10:46 AM   #358
dubie
dubie's Avatar
New Years day we plan on starting the sanding process so we can clean up some surface rust, level most of the truck out and get to shooting some black epoxy primer over the entire body
Old 01-02-2014, 02:00 PM   #359
OrrieG
OrrieG's Avatar
I never did post up a completed door panel pic. The blue is Hot Rod Flatz Diamond Blue Metallic and the mexican blanket wraps were done by my better half.
Did you just use a spray glue on the door panel, or thin panel and velcro or ?? to attach the fabric??? Truck is looking great.
Old 01-02-2014, 03:54 PM   #360
dubie
dubie's Avatar
The fabric and the thin wooden backing layer were both sprayed with 3M spray adhesive and allowed to sit and tack up before being bonded together. Then we made relief cuts for the the corners and the 2 holes so it could wrap around the edge without being to raised.
we placed the door panel on a flat surface, sprayed the back of the upholstered panel with spray adhesive, put it in place and then used 50lbs of weight to compress and hold it for 24 hours.
Old 01-02-2014, 04:06 PM   #361
OrrieG
OrrieG's Avatar
Thanks for the details, what I plan on doing, nice to see it works.
Old 02-03-2014, 09:57 PM   #362
nuke1
nuke1's Avatar
Just want to let you know. That your truck is looking amazing!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-04-2014, 05:13 AM   #363
Red Foreman
Hey Tim, you see alot of Rally's around on almost everything but they just look real cool on your truck. Mate that combo including the stance is a winner! Cheers George.
My Build 56 GMC
Old 02-04-2014, 03:30 PM   #364
dubie
dubie's Avatar
Thanks guys. I've had a clear vision of how I wanted this truck to look for a lot of years. It's encouraging to know that others can see my vision of this build as clear as I can. We should finally be able to start sanding the body and get it prepped for the black epoxy primer by next week. I had some airbrush jobs to get done and clear coated before using the shop for play time so now that the last one will be out of the shop by the weekend, I get some room to spray
Old 03-02-2014, 12:51 PM   #365
dubie
dubie's Avatar
Alright, we finally got started on sanding. A couple more hours of scuffing and we'll shoot a couple coat of black epoxy primer.
Old 03-02-2014, 12:52 PM   #366
dubie
dubie's Avatar
Had some help from my side kick.
Old 03-02-2014, 12:56 PM   #367
dubie
dubie's Avatar
Sanding and more sanding. Good thing I have good help
Old 03-02-2014, 12:58 PM   #368
dubie
dubie's Avatar
More sanding
Old 03-02-2014, 03:16 PM   #369
Kim57
Kim57's Avatar
That looks like fun.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-02-2014, 03:26 PM   #370
dubie
dubie's Avatar
It's always fun when we spend time in the shop together
Old 03-02-2014, 08:16 PM   #371
Flames97
Flames97's Avatar
Very cool. Trucks looking good, can't wait to see the final product.
-Aaron
Old 03-03-2014, 10:58 AM   #372
dubie
dubie's Avatar
I hope to be shooting epoxy primer by the weekend.
Old 03-03-2014, 12:20 PM   #373
05snopro440
05snopro440's Avatar
Glad to see you making progress, but are you sanding the entire truck by hand???
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 03-03-2014, 01:34 PM   #374
dubie
dubie's Avatar
No, just feathering out a few spots by hand.
Old 03-09-2014, 01:20 AM   #375
dubie
dubie's Avatar
We're going to spray the first round of black epoxy primer tomorrow.
