#351 |
Re: "Old Olive" 1970 C10 porterbuilt build
that is one sweet truck!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#352 |
The exhaust looks great! I do have a couple questions. I can't really figure out how its mounted from the axle back. It looks like it's under the rear axle but also mounted to the frame near the rear bumper. Or am I seeing things? Can you explain how the exhaust is going to move when you air up the suspension, or put it on a lift (suspension droop)?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#353 | |
Posted via Mobile Device |
#354 | |
#355 |
No problem. Ya I wanted it to be clean and just peek out a bit. Plus didn't want to just dump it under the truck.
Josh 1970 Chevy C10 SWB build thread http://67-72chevytrucks.com/vboard/s...d.php?t=639787 1976 Chevy k10 Silverado Bought new in '75 by my Grandfather 1965 Lincoln Continental Convertible - SOLD 1965 Lincoln Continental Sedan - SOLD |
#356 |
#357 |
You can get rid of that bracket and make a flat one that will move the booster back to the firewall I made mine I can send you a pic of the template or there are ones that you can buy
My Name is Rusty Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=570083 |
#358 | |
How much did you need to trim the threaded shaft that connects to the brake pedal?
#359 |
I didn't have to but I have a 5 speed and it moved the clutch pedal up to match the brake pedal so you may have to cut it down to where you like it. What brakes do you have if there big and you talk to wilwood you can get a master cylinder that you dont need power brakes for
My Name is Rusty Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=570083 Last edited by blake's first; 12-05-2015 at 12:46 PM. |
#360 |
This one is on my blazer so it not very clean but it shows how much it can be moved back
#361 |
This is the template you will have to make the metal one is a stock off a one ton Chevy so you have to make the plate to off set to the c10 you can see the tab on the stock one I just put a weld on it and filed it tell a had the tab.. They sell billet ones my friend has bough two on pro touring
My Name is Rusty Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=570083 Last edited by blake's first; 12-05-2015 at 11:47 PM. |
#362 |
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#363 |
I have one of the hydratech units. It has a billet mount plate you can sort of see in the pic ajgriffin posted. Also, the hydro boost booster is mounted 180 degrees opposite of what you have yours at now.
I have pics of my install starting on page 4 in my build thread, and pics with my wilwood master/prop valve setup on page 21, if you're interested.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 12-06-2015 at 04:14 PM. |
#364 |
Theres not a problem with mine being mounted that far out right? The kit I bought is specifically for the 67-72 trucks.
#365 |
![]() Join Date: Jul 2015
Wow, that is looking better by the day. I would be proud to do that kinda work to my rig.
Your truck is turning out to be Da Bomb! |
#366 |
Haven't had an update in a little while so figured I'd add one!
Started rewiring tbe whole truck using an EZ Wiring 21 circuit kit. ![]() Wired the Dakota Digital VHX gauges control box and fitted the gauges into the original bezel. ![]() Vintage air is installed. ![]() Kept tbe smooth firewall look ![]() Hidden stereo that looks like a stock radio but is totally modern with am/fm, aux and ipod hookups, preamp 4 channel and amplifier outputs ![]() Started bending hardlines for the AccuAir air ride ![]() ![]() The shop that is going to do my custom brake and fuel lines is moving locations, hopefully I can get the truck in there in the new year. After that it's pretty much ready to rock!
#367 |
Looking really damn nice!!
#368 |
sweet!
#369 |
![]() Join Date: Jul 2012
Coming together very nicely!
#370 |
![]() Join Date: Apr 2010
Josh, what did you do for bracing from the bottom of the bedside back to the bottom of the bed floor since you raised it? In front and behind the wheel opening. Sorry if I missed it
Thanks, Wade |
#371 |
Still Learning
Very nice! Keep up the good work
#372 | |
I used the original support rods, cut the ends off and made new, longer ones with steel rod. Bolted them to the factory spots on the fenders and attached the other ends to tbe frame. I'll take some pictures today.
#373 |
I apologize if I missed it, but what drive system did you use on the engine? Alternator, PS, AC, ETC?? Looks great man!! I love this truck
#374 |
What gauges are these?
#375 |
