Old 02-12-2013, 08:58 PM   #376
1956cameo
1956cameo's Avatar
Re: 67-72 Chev Crewcab Build
Very impressive!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 02-13-2013, 10:29 AM   #377
doubleb's69
doubleb's69's Avatar
Looks awesome with the steelies!
Bud
doubleb's69 is offline   Reply With Quote
Old 02-16-2013, 12:21 PM   #378
atvpro
atvpro's Avatar
A nice video of the truck.https://www.youtube.com/watch?v=5FSv4gxIrbo
atvpro is offline   Reply With Quote
Old 02-17-2013, 02:58 AM   #379
NewType72
NewType72's Avatar
very period correct video love it need more rolling videos!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 02-17-2013, 02:17 PM   #380
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Very cool! Have you seen the 57 napco promo? It would be cool to do a video with a some kind of filter to make it look old then add the narration from an old video like that. Unless you know somone that talks like that because that would work too. Lol
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-17-2013, 06:12 PM   #381
classicchev
classicchev's Avatar
Do you have rear quarters from one of your burbs, both sides?? We will be in Spokane in May, could pick up then..
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 02-26-2013, 01:20 PM   #382
atvpro
atvpro's Avatar
Yes but just call me for details
Old 03-07-2013, 04:23 PM   #383
atvpro
atvpro's Avatar
Went ahead and installed the goose neck hitch so that I can convert our 5th wheel to a goose neck. I prefer towing with a goose neck rather than 5th wheel. Hated to cut a hole in my bed but it is after all a truck and my tow vehicle. I will be installing a bed mat to finish this job.
Old 03-07-2013, 09:54 PM   #384
jbclassix
Junk Yartist
jbclassix's Avatar
Randal,
Was the rear section of your frame originally a trailing arm 2wd set up? I never paid attention to that until now. I noticed how the frame rails kick out right where you installed your hitch.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-07-2013, 11:49 PM   #385
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Originally Posted by jbclassix View Post
Randal,
I'm not trying to speak for him, but yeah. That's exactly what it is.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-07-2013, 11:55 PM   #386
atvpro
atvpro's Avatar
It was a 2wd 3/4 ton leaf spring GMC
Old 03-08-2013, 01:06 AM   #387
jbclassix
Junk Yartist
jbclassix's Avatar
Cool. When I get the bed off my brothers 3/4T 2WD Leaf truck I want to compare it to my 3/4T 2WD Trailing arm frame... see how interchangeable they are. I really like your hitch set up.
-Jeremy
Rebuilding an NP205
Old 03-18-2013, 07:58 PM   #388
atvpro
atvpro's Avatar
Well I made the mistake of believing the person that I bought the original motor from that I put into my crew cab who said that it was JUST rebuilt and had sat for a few years. Low and behold I noticed some oily smoke coming out of the tailpipe when compression braking downhill while towing. So I decided to have a set of heads built for it assuming it was just old valve seals and I was going to take this opportunity to sneak in a performer manifold and edelbrock carb as well as an electronic ignition distributor. When I pulled my heads off I noticed that things were not as they should be, ie) the ring ridge was screaming 150,000 miles.....so I now have a new motor that I know is new with an RV cam, new carb, new manifold and ignition. Can't imagine how much better this truck is going to tow considering it had done a good job with a worn out motor.
PS Let me save you the trouble it is corporate GM blue because I can't stand Chevy orange motors.
Old 03-18-2013, 08:25 PM   #389
atvpro
atvpro's Avatar
Old 03-18-2013, 09:56 PM   #390
jbclassix
Junk Yartist
jbclassix's Avatar
Don't mind the blue at all! I really like paint matched intakes
-Jeremy
Rebuilding an NP205
Old 03-18-2013, 11:26 PM   #391
Dieselwrencher
Very nice Randall. Sorry to hear about the tall tales on the original engine.
Ryan
Old 03-18-2013, 11:27 PM   #392
71-blazer-half-cab
71-blazer-half-cab's Avatar
Randall, The engine looks great, but if you are going to use the Edelbrock carb they make real clean banjo fitting chrome line that goes straight down from the fuel fitting them forward to almost meet up with the steel line you have coming up from the fuel pump. It is easier to fit the air cleaner and it eliminates a bunch of the rubber hose. If you need the part number or to borrow one until you can get it call me.
Ralph
71-blazer-half-cab is offline   Reply With Quote
Old 04-02-2013, 10:54 AM   #393
atvpro
atvpro's Avatar
For those of you heading to the Portland (Oregon) Swap Meet this weekend I have a booth at the Raceway #6041, come by and say hi - it would be great to meet you.
Old 06-20-2013, 11:58 AM   #394
atvpro
atvpro's Avatar
Decide to sell this truck to fund my C50 crewcab. For selling details please go visit the "For Sale" part of the forums.
Old 06-20-2013, 12:04 PM   #395
jeffg1010
jeffg1010's Avatar
Dang... Im jealous. Wish business was better. I would love to be pulling our camper with it. (I must've beat the ad upload... I dont see it up yet)
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 06-20-2013, 02:10 PM   #396
NewType72
NewType72's Avatar
Bummer to hear but the c-50 looks to be an incredible workhorse and statement maker that's for sure
- Dylan
(209)-985-7721
Old 06-20-2013, 09:42 PM   #397
widewhite70
widewhite70's Avatar
Looks great!
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 06-21-2013, 10:37 AM   #398
LODI3QTR
LODI3QTR's Avatar
Randall can you post a link to the For Sale Post? I tried to find it to no avail.. Thanks, Mike........
LEFT LANE IS FOR PASSING!!!! SLOWER TRAFFIC KEEP RIGHT!!!!
My C20 & Cars... http://67-72chevytrucks.com/gallery/...&ppuser=111212
LODI3QTR is offline   Reply With Quote
Old 09-23-2013, 11:40 AM   #399
atvpro
atvpro's Avatar
Hey guys, wanted you to know I've been busy with a new build. Try to put it under trucks but since I am using a C50 cab but with a 3/4 ton frame it got moved to heavy haulers. Here is a quick pic and the link over to that forum page. Please take a look if you get a chance
Drill Sergeant
Old 09-30-2013, 10:26 AM   #400
K20chevy
K20chevy's Avatar
That crew cab looks amazing! I love the colors and the steel wheels!
I´m still looking for a Chevy or GMC K20 with a manual transmossion myself, between 68 and 72. No luck finding a good one yet though!
I just added your truck as my desktop background!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
