02-14-2021, 05:05 PM | #376 |
Re: New 64 Stepper Project
Dadgum, that's shiny
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-16-2021, 02:04 PM | #377 |
NICE. It's looking real good.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
02-19-2021, 04:18 PM | #378 |
Moderator
We were without internet in my area for a few days, but I worked some on it.
02-22-2021, 10:17 AM | #379 |
Moderator
Got my tans pan and TC cover back from the powder coater.
02-22-2021, 10:28 AM | #380 |
Nice. Still waiting on my cover
02-22-2021, 12:03 PM | #381 |
02-22-2021, 01:31 PM | #382 |
Moderator
I lost interest.
02-23-2021, 02:36 AM | #383 |
Man, that looks so good!
02-25-2021, 10:07 AM | #384 |
Moderator
Still a long way to go but it's moving in the right direction.
02-25-2021, 10:33 AM | #385 |
Yes it is!!!
John 3:16 - Saved me... God Bless |
02-25-2021, 10:36 AM | #386 |
Bling bling. That compartment looks clean.
02-25-2021, 10:57 AM | #387 |
SCOTI took the words out of my mouth...looks clean! Well played sir!
02-25-2021, 09:53 PM | #388 |
Great work.....
02-26-2021, 09:15 AM | #389 |
Moderator
Thank you gentlemen.
This morning I checked the pinion angle at ride height and I'm .7% between the two. Whew what a stroke of luck that was.
02-28-2021, 12:10 AM | #390 |
Moderator
Got more of the front end done today, worked on the headlights relays and wiring, just have to finish the trans cooler tubing when that comes in. Seems like everyone is using the bad weather excuse on shipping.
My hood hinges are woefully weak, so I'll have to replace those.
02-28-2021, 10:17 AM | #391 |
I ran into the shipping thing too. My package took 10 days to get from California to Atlanta. Says it will be delivered tomorrow.
Your truck looks like it's almost ready to hit the road again
02-28-2021, 02:43 PM | #392 |
Moderator
Well if I can get the firewall insulated on the p-side I can install the heat/AC unit and run the heat/ac hoses and plug it in electrically. Install the drive shaft, get a battery, term those cables, fill it with all the oils/fluids... Yep maybe I could at least start it.
But I bought another set of headers so I have to change those out first. After I start it I can get to the glass shop, then the muffler shop, Get tires and wheels, then the upholsterer in Houston. Get it inspected, go the county to register it... Oh, I forgot to buy the wood, get it and finish it and install it.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 02-28-2021 at 03:04 PM. |
02-28-2021, 06:23 PM | #393 |
Almost
02-28-2021, 07:10 PM | #394 |
Moderator
03-01-2021, 10:56 AM | #395 |
Progress is progress. The list just seems to grow the closer you get.
03-01-2021, 11:06 AM | #396 |
that list never seems to stop!! Whatever you do, if you track your parts, DO NOT DO A TOTAL!! LOL
03-08-2021, 02:56 PM | #397 | |
I'm just glad to be here!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-08-2021, 03:33 PM | #398 |
Moderator
Wow. I'd a canceled that long ago.
03-10-2021, 02:14 PM | #399 |
I had for got all about it. Lucky for me no body else had the part in stock, so I never actually ordered it from another source. Now its on its way and I can finish that part of my build...
03-19-2021, 11:26 PM | #400 |
Moderator
Working on the bed wood. Few more coats to do
