09-09-2015, 10:04 AM | #401 | |
///Relaxed Atmosphere
Re: original-71 update pics after new shoes and drop
thank you buddy appreciate the compliment
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
05-28-2016, 02:46 AM | #402 |
06-29-2017, 04:44 PM | #403 |
been away for a while so thought I would share some updates on my 71.. finally started back in January of this year with the new engine and tranny install. I was never really satisfied with my engine bay cause I knew it good have been a lot cleaner so that's what has lead me up to this point. once the tear down began I have found myself finding more dirty areas than I realized so basically everything from the firewall forward has been cleaned and repainted including the frame. im still in the process of the cleaning and painting some things and work takes a lot of my time so basically only on weekends I get to work on it so I'm looking by august to be done hopefully. thanks to the help of some good buddies and some cold ones it has been fun working on my own truck.
06-29-2017, 04:47 PM | #404 |
more of the frame
06-29-2017, 04:50 PM | #405 |
cleaned and repainted everything I could use still
06-29-2017, 04:54 PM | #406 |
staying factory ac
06-29-2017, 04:56 PM | #407 |
same core support and inner fenders
06-29-2017, 05:02 PM | #408 |
same steering gear box just a lot cleaner and fresh look, and pic of the motor sitting in on the clean frame. right now the brake booster is off to be painted also. ill update in a few weeks hopefully.
06-30-2017, 12:04 PM | #409 |
What a huge difference the paint makes, nice to have it all apart and do it correctly, twice the truck w a little paint and effort, nice work.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
06-30-2017, 06:20 PM | #410 |
Looks good, What did you use to paint the frame?
07-03-2017, 09:57 AM | #411 | |
thank you, I used por 15 super starter kit gloss black and top coat is john deere blitz black
07-10-2017, 10:22 AM | #412 |
Looking great! What primer and paint did you use for the inner fenders and core support? Same as frame or something different?
07-10-2017, 03:44 PM | #413 |
Great work. Not a quick job and it'll look like a million bucks under there now.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
07-10-2017, 03:48 PM | #414 |
Thank you appreciate compliment. to be honest my buddy painted the inner fenders, ac box, and core support so I'm not sure what primer he used but I do know the paint is called Medallion Satin Hot Rod Black.
07-10-2017, 03:53 PM | #415 |
thanks brother appreciate the compliment.
07-10-2017, 04:16 PM | #416 |
Thanks!
07-27-2017, 10:39 PM | #417 |
Beautiful truck! When mine gets the necessary time & finesse, if it turns out a fractional amount of yours, I'd be learning a new happy dance!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
01-08-2018, 05:56 PM | #418 |
thank you brother
01-08-2018, 06:04 PM | #419 |
been a full year finally got some updated pictures and a running truck just a few more touch ups and Ill start showing it again.
01-08-2018, 09:08 PM | #420 |
Well done! So clean and tasteful.
1970 SWB Build |
01-08-2018, 09:14 PM | #421 |
Very nice Hector
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-08-2018, 09:39 PM | #422 |
67-72 parts collector,…
VERY nice!
01-08-2018, 10:43 PM | #423 |
Truck looks great! Did you find the power you were looking for? Also from North Houston. Nice to see this truck so close to home.
01-09-2018, 10:39 AM | #424 |
thank you appreciate that
thank you brother thank you brother thank you for the compliment. yes I did get the power i was looking for 350/365HP the engine has vortec heads but with a set of valve cover adapters for center bolt heads from speedway you cant really tell kind of just looks like a stock engine but sounds like a beast. i actually live in kingwood close to you also.
01-09-2018, 10:50 AM | #425 |
these are the valve covers i went with from summit not bad for the price and powder coated to match. Trans-Dapt Performance part number 9916
