#401 |
Re: 61K10 build
Truck looks great! Great idea for installing the hood.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#402 |
![]() Join Date: Aug 2008
Re: 61K10 build
Truck looks amazing! And provides good motivation for slackers like me.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#403 |
Re: 61K10 build
Jason--you are young and have plenty of time, enjoy other things. on the t/f case you put new clevises (if that right name) I could not get it adjusted with them. couldn't get it to go into 2h. put my old ones on and got it to go into 2h. might have been just me. have to drain it as one of the rounds plates is leaking a bit. my pto is leaking a little also. and i hate oil leaks!
take care my friend----------kimble
1961 chevy K10 my build is------------61K10 build |
#404 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Re: 61K10 build
The truck looks amazing!! Great job!!
#405 |
Re: 61K10 build
well another problem with my fuel gauge--does not work, so i took out the cluster (pita) and put in another gauge that came with the tk. still no=workie. have a new sending unit and the old org one also. both test ok. So I'm putting new gauges, not stock. heres the gauges that i will put in the stock cluster. we will see if i can make these work and look some what stock.
#406 |
Re: 61K10 build
Is the sending unit well grounded?
#407 |
Re: 61K10 build
Is that the only guage not working? And if you are sure it's the guage and not any wiring issues, ie ground as Argonaut suggest, I could send you another guage. If you've already got those in the pic, tho, they look pretty nice upgrade.
'62 Chevy K10 |
#408 |
Re: 61K10 build
will see if i can make these work. two sending units Jason, new in the tk and one on the bench. wiring is new american auto wire as i had dash problems with the org wiring. the ground is good as is power to the gauge. tired of 50yr old junk.
I bought a gauge cluster on e-bay when i started. the speedo was set back to ooooo and it looks like new # were installed. when i drove the tk for the first time getting into 4g all of a sudden one big buzzing noise out of the speedo (has new speedo cable) so i put my org one back in but haven't driven the tk yet as my dash cluster is out. this thing is spooky to drive lol. moves around a little (probably my used steering box) every time i try to save some $$$ it bite's me in the you know where lol.
#409 |
Re: 61K10 build
Are you going to retrofit the existing cluster with the new gauges behind the faceplate? Or are you making a new baseplate with all new surface mount gauges like these?
I do like the classic style of those new gauges.
#410 |
Re: 61K10 build
Jason--yes i am going to put them behind the face plate. I mocked one up with another gauge 2-1/8". took the bezel and glass off. will take a pic. I hope the new ones come apart easy.
#411 |
Re: 61K10 build
Very cool. The one thing I love about the original gauges is the big sweeping speedometer. I have swapped in a volt meter from a later model chevy. I I adapted the gauge faceplate to it and then modified the back of the cluster to make it fit. Anyway, my point is that it is doable.
#412 | |
Re: 61K10 build
ron |
#413 |
Re: 61K10 build
ron--not the org t/c. bought it from argonaut. it was not an org from his tk as the tag was from some tk shop and there are no # stamped on it. Jason re-gasketed and new seals. the leek was just a weep. seems like it has stopped? pto weeps some also. time will tell.
#414 |
Re: 61K10 build
couple of pics of my fuel gauge. volt gauge is coming from Ohio. the v-gauge in the left is no good, got it to work a couple of times then nothing. might get a clock to match my gauges later at $101.00 way later. I would like to replace all with new but too much $$$. the gauge in the batt window will be a new green face one
#415 |
Re: 61K10 build
That's perfect! Be sure to save the two old gauges though, just in case you ever go back & figure out why they didn't work.
Add the temp and oil pressure and it'll "look" normal. Most people won't know.
'62 Chevy K10 |
#416 |
Re: 61K10 build
well got my gauge cluster back in, gas and volt gauges work. as usually another problem. rear end is shot. when i had it apart i readjusted the backlash that was way loose. It makes big noise now. removed d/s to t/f case--trans was quiet. put d/s back in and removed d/s to rear--t/f case was ok, a little noisy but that was expected. hooked d/s back to rear and put the rear on jack-stands. rear is very noisy on acceleration and d-acceleration. and yes no ring & pinion's in 3.90 avl. as the party goes on and the road never ends!
#417 |
Re: 61K10 build
Cluster looks good! Sorry to hear bout the ring & Pinion. Try a couple junk yards in your area. Those Eaton rear ends are all over the place here in Tx and Okla. Just have to take the cover off a couple to see which ones are good.
Got a question for you tho, since you just did everything. I'm putting a gauge cluster in my dash as well, but keeping the orig fuse box and wiring. Will the dash cluster harness with gauges plug into my orig harness? Thought , I'd ask before calling.
'62 Chevy K10 |
#418 |
Re: 61K10 build
Kimble I hate to hear that after all the work you've done. I had to replace my rear yoke on mine and I just installed another one and just tightened it up pretty good...I was wondering about that crush sleeve. I haven't driven mine on the road since I got it 2 yrs ago... Other than when I tried it out when I bought it, it was very slow with 4:56's gears and 4 spd and the V-8 with a mild cam just didn't act like it had the power it should have had.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#419 |
Re: 61K10 build
Mitch--have maybe a line on one from an old friend i grew up with. Randy--my rear is 3.90 so a little more highway friendly. I had a feeling that is was gonna make noise. I hate to put in a 12 bolt--we will see i guess.
#420 |
Re: 61K10 build
Mitch--forgot to answer your question about the gauge cluster. the gauge wiring is a little different, can't remember all the details. you would need a new temp sending unit(???) and tubing from eng to manual oil gauge. I would not use the amp gauge myself. I know you can buy the gauge cluster wiring.
kimble
#421 |
![]() Join Date: Aug 2013
Re: 61K10 build
sneeky dash cluster, i like it!!! updated with vintage look and shouldnt break the bank
#422 |
Re: 61K10 build
Thanks Kimble. Hey, You never said if you opened the diff cover on your rear end or not. As long teeth on the ring & pinion are not worn, you might wanna check out the differential rebuild kit that Ecklers sells for the eaton diffs. It's listed as 1955 2nd series - 62 rebuild kit. Comes with all the needed bearings & races. Maybe its just a bearing going bad.
'62 Chevy K10 |
#423 |
Re: 61K10 build
'62 Chevy K10 |
#424 |
Re: 61K10 build
Mitch--I had the hole third member out of the housing as it was leaking,also to ck axle bearings (which were good as was the axles). the R&P had about .250 slop (loose) i readjusted the back lash to spec. so it was worn by being out of spec, and it's not the org one either. I thank the date was 1959. might just rebuild it with 3.38's till i come up with a good 3.90. the closes r&p for the ft dana44 3.31's which is stretching it a bit. probable never use 4wd anyway. going to fix all my leeks in the t/f case and figure out the R-end. I've built a few rear ends some years ago when i was Drag racing.
#425 |
Post Whore
![]() Join Date: Mar 2013
Re: 61K10 build
That gauge cluster looks super! Yer truck is coming along nicely! You've done a job well done.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
